Peter Green & Other Magnet Mods in Humbuckers with Covers, Pic Heavy
Discussion in 'Tonefreaks' started by jonesy, Oct 10, 2010.
  1. Phostenix
    Phostenix Junior Member
    9
    1
    Aug 21, 2010
    It's all about coil splitting. When you start connecting individual coils in series or parallel (as the PRS 5-way does), if one of the coils is a north magnet & one is a south magnet, the combination will remain hum cancelling.
    So, for example, if the coils of the 2 humbuckers are like this:
    S-N N-S
    When you connect the inside or outside coils together in series or parallel, you get 2 coils with the same magnetic polarity and you lose the hum cancelling.
    Now, if the pickups are like this:
    S-N S-N
    When you connect insides or outsides, they remain hum cancelling.
    Since using inside coils together & outside coils together gives the most difference in tones, PRS went with alternating magnets. Peavey does this in some of their guitars that have humbuckers & a 5-way, too.
    With Gibson, Seymour Duncan, etc. humbuckers that are S-N N-S, you could still choose to combine coils that are opposite magnetic polarity, but the difference between the choices is less dramatic.
    Where this matters for LP guitars is if you just want to have a switch that splits the coils on a LP, I would suggest splitting to the front (neck side) coil of the neck pup AND the front (neck side) coil of the bridge pup, as well. That way, you will have a south magnet & a north magnet in parallel in the middle position & it would still be hum cancelling. I prefer the sound of the forward coil of the bridge by itself anyway, so that's a double bonus. :)
    b3john likes this.
  2. Phostenix
    9
    1
    Aug 21, 2010
    Do you find any difference in tone between swapping the magnet around & reversing the leads? It's certainly easier to swap the leads.
    I thought the only time people flipped the magnets was to get the proper magnetic polarity for coil splits. Or to match pickups.
  3. jonesy
    17,173
    4,389
    Mar 28, 2008
    I can't hear any difference between the magnet change or swapping the + and - leads, the Out of Phase "Oop" Tone sounds the same to me either way.
  4. Phostenix
    9
    1
    Aug 21, 2010
    Why would someone go to the trouble (and risk to their pickup) of switching the magnet around if switching the wires produces the same effect?
  5. jonesy
    17,173
    4,389
    Mar 28, 2008
    Changing magnets is really not that big of a deal or all that risky in most pu's, and besides the PG mod many players like to swap out A2's for A5's or maybe an A4 because it changes the Tonal characteristics of you pu. YMMV
    Switching the magnet to change the polarity eliminates grounding issues and noise associated with pu covers that you might get when just flip flopping hot to ground. Rotating the magnet is a much quieter way to get the "Oop" Tone in some cases. ;)
    Mookakian and Phostenix like this.
  6. b3john
    b3john Senior Member
    5,203
    3,792
    Jun 5, 2010
    Once you know what you're doing, you'll realize it's not nearly as risky as it sounds. The guys over on the Seymour Duncan forum (including the Lieutenant) have raised this to an art form. There are some videos that walk you through the process, I'll see if I can dig up the links...
    jonesy likes this.
  7. Phostenix
    9
    1
    Aug 21, 2010
    Ah, yes, the light bulb went on for me finally. I don't have any humbuckers with covers, so I don't tend to think about them. After looking at your pics again, it also looks like that's a 2-wire lead with the braid as the ground. If you wanted to reverse the leads, you'd not only have to run a new ground wire to the pup, you'd also have to separate that braid from the case & connect it internally, right? Or, are there 2 wires inside the braid (plus & minus leads) and the grounded braid is not connected to the minus lead?
    Changing types of magnets makes perfect sense to me as a reason to tear open a pup.
  8. Phostenix
    9
    1
    Aug 21, 2010
    Just in this thread, one guy sounds like he damaged his pup (Sånglöf) trying this mod.
    When people ask me if something is easy to do, I usually say, "If you know how to do it, it's easy." :)
  9. skynyrd67
    skynyrd67 Senior Member
    1,051
    305
    Jan 22, 2011
    If you wanna give your bridge pup a kick in the ass try a UnOriented A5 magnet, the dynamics will jump out of that pup, the growl and pinch harmonics will be much more lively, I swapped out the A2 in my Pearly gates bridge pup for the UOA5 and WOW, still has the same PG character just much more open and raw sounding, I wish pup makers would start useing the UOA5`s, they aren`t as mid scooped sounding as the A5 nor as Bassy, just great all around mag for the bridge.
  10. Robinv
    Robinv Senior Member
    389
    150
    Mar 9, 2011
    Hey, I just did the PG mod. Seems cool, very noticable. But for some reason when I have the switch in the middle position I seem to lose like half of my volume. Both humbuckers still have thier normal output, but when combined it's kinda like a coil tap going from humbucking to singlecoil (output wise)
  11. jonesy
    17,173
    4,389
    Mar 28, 2008
    Yeah there will be a drop in volume with the switch in the middle and both pu's out of phase, compared to the in phase wiring.
    Try rolling down either volume control just a little (switch in the middle) and you will hear your Tone Fatten up and your volume get just a bit louder.
  12. Robinv
    389
    150
    Mar 9, 2011
    Cool thanks man :)
  13. jonesy
    17,173
    4,389
    Mar 28, 2008
    Your welcome bro, anytime ;)
  14. CC53
    CC53 Member
    39
    4
    Jun 13, 2011
    Just curious if anybody recommends tightening the 4 brass screwws or the p/u screws first when reassembling.Seems to me that the 4 bras would be best to do first as I wouldn't want to strip em but want everything tight as I don't use any wax and I don't want any microphonics.
    Any thoughts?
  15. jonesy
    17,173
    4,389
    Mar 28, 2008
    Seems like I tighten up the pu screws first and then carefully tighten the brass screws so they do not strip or break off. YMMV
  16. CC53
    CC53 Member
    39
    4
    Jun 13, 2011
    Thanks Jonesy....The reason I do the 4 screws first is to cinch the coils up with the maple spacer on the slug side.Maybe that's wrong to do if it causes stress on the 4 screws after tightening the p/u screws all the way down? Maybe I'm just thinking too much and don't need to worry about tightening them too much.I don't really play with much gain anyways.
  17. jonesy
    17,173
    4,389
    Mar 28, 2008
    Not sure bro, I have never had any problems with that method YMMV
  18. Rock City
    Rock City Senior Member
    933
    330
    Dec 10, 2010
    Thanx making it looks so easy. I've always wanted to improve my sound just sitting at home doing almost nothing. And this is the way! Only I am afraid not to screw something in my style so I will ask some professional for a help.
    Still it bugs me to take screwdriver, find compass somehow and start... uh!
  19. dkirwan
    dkirwan V.I.P. Member
    445
    48
    Apr 22, 2007
    What is an A8? I've never heard of that???
  20. Penny Dreadful
    Penny Dreadful Banned
    6,199
    6,218
    Feb 21, 2008
    The reason for the volume drop is that because your pickups are now out of phase with one another, some frequencies will cancel each other out.
    This, results in a slight volume drop.
