Peter Green & Other Magnet Mods in Humbuckers with Covers, Pic Heavy
Discussion in 'Tonefreaks' started by jonesy, Oct 10, 2010.
  1. jonesy
    17,130
    4,364
    Mar 28, 2008
    Your welcome bro!
    Yeah it's a sticky :thumb:
  2. Barker
    Barker Senior Member
    2,854
    1,992
    Feb 21, 2010
    Thanks Jonesy!.... :thumb:.
    I did this mod today on the SD Pearly Gates in the bridge of my LP Standard and I'm very pleased with the results. It was very easy and didn't take long at all. I didn't use the middle position very often anyway, and this has given me a very usable sound, that is actually very pleasing to my ear :D.
  3. jonesy
    17,130
    4,364
    Mar 28, 2008
    Very cool Barker glad that PG mod worked out good for you. ;)
  4. 58_Iced_Tea
    58_Iced_Tea Member
    75
    4
    Sep 10, 2010
    Jonesy,
    Do you have, or could you do a photo tutorial on converting from 2 wires to 4 on a Humbucker? I have a print article, but, I'd like to "see" the steps as well just to be sure I get it right.
    Thanks,
    Randy
  5. jonesy
    17,130
    4,364
    Mar 28, 2008
    You know that is a really good topic and I actually thought about doing a pictorial on that mod. I have a 500T and a 496R that would be good candidates for the 2 to 4 wire conversion. :thumb:
    I am pretty swamped here at my shop right now so it may be a while before I have time to do that. I will either add it to this thread or start a new one and post the link here. ;)
  6. 58_Iced_Tea
    58_Iced_Tea Member
    75
    4
    Sep 10, 2010
  7. fretboarder
    fretboarder Senior Member
    1,807
    1,494
    Aug 19, 2008
    i love the sounds your getting in the first video with your sg!! what amp mate?
  8. jonesy
    17,130
    4,364
    Mar 28, 2008
    Thanks! :thumb:
    I am plugged straight into my Peavey Windsor Studio amp, EL34/12ax7's built in power soak at 50% out of a 12" Blue Marvel Speaker. ;)
  9. jonesy
    17,130
    4,364
    Mar 28, 2008
    The Man Himself :D
    [ame=http://www.youtube.com/watch?v=nB6zg05CxYg]YouTube - Peter Green - Jumping at Shadows[/ame]
    Duane71, paul1959 and Tchap like this.
  10. kindofbird
    kindofbird Junior Member
    22
    0
    Oct 25, 2010
    Thanks a lot for posting this, mate. I just did the mod earlier today and it sounds wonderful. I've already got the scraggly beard, so all I need to do is grow my hair a bit longer and I'll nearly be the man himself
  11. jonesy
    17,130
    4,364
    Mar 28, 2008
    Your welcome, I think it's a pu mod that's worth trying out and it does give you some pretty cool Tones. Sounds like you have the "Greenie" vibe going on :D
  12. cheeseflavor
    cheeseflavor Premium Member
    1,228
    207
    Dec 22, 2009
    Never did the magnet flip before. Did one today and cannot believe how easy it was. Thanks Jonesy!
    Steve
  13. jonesy
    17,130
    4,364
    Mar 28, 2008
    Hey your welcome Steve, yeah not really to bad of a mod to do...now you've got some "Oop" Tone ;)
  14. Sånglöf
    Sånglöf Senior Member
    244
    164
    Sep 24, 2010
    I've had som issues with a srange feedback using distortion after I made this MOD. Is it because of what you're mentioning here? Or is it just the way it will be if using heavy distortion on the neck pickup after mod being done?
  15. jonesy
    17,130
    4,364
    Mar 28, 2008
    Hard to say, it could because there is a gap between the pu and the cover now since you pulled it off and put in back on. Micro-phonic feedback will be a high pitched squeal.
    It is also possible you got the magnet flipped the wrong way way within the pu itself? Does the neck pu sound full like it did before? Or does it seems to have lower output now when used by itself? Even with the PG mod your pu should sound the same when used alone, just when it is combined with the other pu will it be out of phase and thinner sounding.
  16. Sånglöf
    244
    164
    Sep 24, 2010
    I do still have a fat sounding neck pickup. And the Green sound only comes alive when using the middle position.
    I used this manual, not yours:
    [Pictures!] Flipping a humbucker out of phase a.k.a. Peter Green Mod
    PG sound is great, though I've heard some people turn the magnet lengt wise. I've heard it doesn't matter.
    Like I said PG soun is there, just don't like the squeling feedback tone I get using distortion.
  17. jonesy
    17,130
    4,364
    Mar 28, 2008
    Ok, sounds like an issue with the pu cover then. You can wax it on or use a piece of tape or a bead of silicone between the bobbins and cover. If you do that and get the cover back on tight you shouldn't have any squeal, unless it has to do with the way the pu is wound to begin with.
  18. Sånglöf
    244
    164
    Sep 24, 2010
    Everything was nice. And then.... a few secs ago, the neck PU stopped working correctly. It Now has the PG sound by it self, and VERY low volume...
    So, whats this about? Guess I need to leave it to a real guitardoctor....
  19. jonesy
    17,130
    4,364
    Mar 28, 2008
    Hmm..The series link between the two coils may have come partially un-hooked, or you may have nicked a coil wire? You could take the pu back out an visually inspect to see if you can find the problem? Also make sure nothing inside your control cavity is bent or touching and causing this problem with your neck pu.
  20. 5F6-A
    5F6-A Senior Member
    9,365
    1,931
    Aug 16, 2007
    It's very interesting... I've installed the neck pickup with a bridge pickup of two different sets. Originally both sets were wound for an OOP tone but funnily enough the polarities of both sets ( from the same maker ) are different so I have to do the magnet swap trick to get the OOP tone back....
