Pedal Order
Discussion in 'Tonefreaks' started by leduke, Mar 8, 2018.
  1. leduke
    leduke Junior Member
    13
    19
    Oct 8, 2008
    Hello.
    I wonder in witch order to put my pedal in the chain ?
    This is my suggestion, please comment and give me your opinion:
    Guitar
    TC Electronic Polytune 2 mini
    Jam Delay Llama
    Nocturne Atomic Brain (preamp and boost)
    BenRod Red Fuzz
    Amp
    Thanks !
  2. northernguitarguy
    northernguitarguy SWeAT hOg
    28,337
    47,013
    Feb 22, 2009
    I'd go
    Guitar-->Tuner-->FUZZ-->Boost-->Delay (in the FX loop, if possible)-->amp
  3. Duane_the_tub
    Duane_the_tub Senior Member
    2,013
    3,402
    May 31, 2015
    Agree with @northernguitarguy . In fact, depending on what type of amp you have (single-ended?), you may have no choice but to put the delay (and any other time-based fx) in the loop. Fuzz can go before or after the boost, depending what you're trying to accomplish.
    northernguitarguy likes this.
  4. Bobby Mahogany
    Bobby Mahogany Senior Member
    20,239
    29,217
    Feb 25, 2012
    Distortion, modulation, delay.
    You don't want to "fuzz the delay".
    You want to "delay the fuzz".
  5. northernguitarguy
    28,337
    47,013
    Feb 22, 2009
    Yeah, I dunno his FUZZ, but in my experience, FUZZ wants no interference.
  6. leduke
    13
    19
    Oct 8, 2008
    Hello Thanks for replies.
    My amp is a boutique amp based on Fender 50's Tweeds, no effect loop.
    Whan I use the fuzz, I use no effects with, only the Fuzz, exepted the preamp.
    The preamp il always on, the sound is more defined.
    The boost is used only for solos.
    The demay is often used (never with the fuzz), in a light splap back, to a little bit spaced (don't if it is understandable... :squint:).
    Thank you.
  7. Chakalawaka
    Chakalawaka Senior Member
    139
    202
    Feb 23, 2017
    tuner > wah > phaser > compressor > overdrive/distortion/fuzz > EQ > pitch pedals > modulation pedals > level pedals > noise gate > echo > Reverb
    This should be the order for your pedals, THEN AGAIN, this is only a starting point to sound good, but you're completely free to not adhere to this and find your own sound :)
  8. CRobbins
    CRobbins Premium Member
    7,670
    10,903
    Feb 20, 2012
    I use a snark tuner so its not even in the fx chain.
    Thumpalumpacus likes this.
  9. Thumpalumpacus
    Thumpalumpacus Senior Member
    75,908
    185,742
    Nov 28, 2010
    Gain pedals to the front of the line, that works for me.
    CRobbins likes this.
