PAFs with FAT mids?
Discussion in 'The Custom Shop' started by marshallplexi, Oct 16, 2017.
  1. marshallplexi
    marshallplexi Junior Member
    4
    0
    Aug 5, 2016
    Hello all,
    I have a very nice LP replica here that I'm having a hard time finding the right pups for...
    The guitar is light (8lbs even!!, not chambered) and has a pretty good tone BUT it definitely lack some weight in the mids/low mids department.
    I've tried several sets so far: BK Mules and PGs, Area 59s PAFs, SD Bonamassa Skinnerburst PAFs and Wizz LTD vintage wire.
    All sounded pretty good... The Mules were good except for the A4 mags which I don't care for, especially in this guitar. The Bonamassa set is nice especially the neck pup, not thrilled with the bridge.
    The Wizz vintage wire set (first edition) with A2 mags (my preference) sounds the best in this particular guitar but the mids sound a little too thin to my ears.
    Anyone could recommend a PAF set with some rich/pronounced mids/low mids, tight-ish low end while preserving some good clarity in the top end?
  2. freefrog
    freefrog Senior Member
    1,257
    704
    May 21, 2011
    IME, mids/low mids are not the kind of frequencies enhanced by vintage voiced pickups.
    Now, with a vintage set like the Wizz, I'd simply use... a "vintage" cable. IOW, a cable exhibiting high capacitance, wether it is a long cable or a coiled one.
    EDIT: a high capacitance cable can be emulated just by adding a small capacitor (500pF to a few nanofarads) between the hot and ground of a standard cable, BTW.
    Reason: as any passive pickup forms a LRC filter once associated to pots and guitar cable, cable capacitance shifts down its "resonant peak" and enhances the mids once high enough. That's how guitar heroes obtained warm tones from bright P.A.F.'s, back in the days.
    Now, if you prefer to shift down the resonant frequencies towards the mids by other means, there's plenty of "hot" pickups ready to do the job, going from overwound P.A.F. replicas to models like the Duncan Custom (or the JB, well known for its "mid hump").
    Good luck in your quest...
  3. Zoobiedood
    Zoobiedood Senior Member
    919
    334
    Sep 1, 2015
    Well, if you use A2 magnets that provide those buttery mids, they do it at the expense of tight lows. I like the buttery mids, so I use Alnico II Pros. They are vintage output, but the mids are really musical and dynamic.
  4. Pappy58
    Pappy58 Senior Member
    2,349
    4,705
    Dec 2, 2014
    Still too many variables..Unknown body composition, Pot values, what amp are you using, etc... But I would probably go with the Whizz based on your post and attempt to fix any annoyances downstream.
    Nice Tweed amp with one of these: cd9758_72bdf835a9a9489fb22ea6ed2ca93c6a.jpg
  5. The_Nuge
    The_Nuge Senior Member
    1,832
    1,296
    Dec 12, 2010
    I've had great success with Electric City Pickups (RD59) and Tyson Tone Lab (can't remember which model I have) in my "difficult" R7BB.
    Both are members here, and you can talk to them directly for advice and custom options!
    Wraptail likes this.
  6. ntotoro
    ntotoro Senior Member
    115
    39
    Jan 22, 2015
    I have a set of Rolph Pretender 58's in my Oxblood R4 and they definitely have a little thicker midrange without being honky. Really nice highs, but a nice bit of chunk, also.
    Nick
  7. Dilver
    Dilver Senior Member
    1,024
    1,540
    Apr 26, 2011
    I just went through the pickup quest. I found the OX4s to be pretty mid-forward, but they were too middy in my R8. But OX4s typically use A4 magnets. I’ve come to realize that I don’t like bridge pickups with A4s.
  8. moreles
    moreles Senior Member
    3,098
    1,753
    Apr 16, 2011
    Sticking with reasonably-priced PUs, I can second the Duncan Alnico II Pros. They are great OUs, and in my setup have great mid presence -- not overpowering, but not scooped away.
    Zoobiedood likes this.
  9. mdubya
    mdubya Senior Member
    17,582
    27,829
    Jan 25, 2010
  10. Duane_the_tub
    Duane_the_tub Senior Member
    2,104
    3,601
    May 31, 2015
    I'd just swap out the magnet in the neck of the Wizz.
    rockinlespaul likes this.
  11. AbbeSauniere
    AbbeSauniere Senior Member
    508
    290
    May 4, 2010
    I have a Burny RSA semi that is very light and bright and can be a little anemic with pickups that sound bigger in other guitars. I replaced the Wizz, which had some serious upper mid and high end emphasis in that guitar with Throbak Pre-Ts. Lost of lower mid range grunt, but well balanced from lows to highs. More compressed sounding than most PAF style pickups. Harmonically rich too.
    WCR Good Woods might work as well. Had a set in a light and bright Burny SG. Really mid forward, just verging on honky, mellow highs and pretty taught low end.
    Blue Blood likes this.
  12. Russ2
    Russ2 Senior Member
    183
    259
    Apr 11, 2014
    Here is my set of Woody's from Vaschenko. He hand carves the Bobbins of various woods. For this I chose Maple and Rosewood. Vaschenko worked as an engineer in the aerospace industry designing and installing electronics before building guitars (he apprenticed in his younger days with a Master violin maker). But you really cannot go wrong with Tyson Tone, tell Bobby him you want the '59's from the Flying-V and he will understand:
    You may want to spend the money on a pedal like the Green Tone shown here:
    Larcos_Unal likes this.
  13. guitarjoem
    guitarjoem Senior Member
    497
    259
    Dec 15, 2014
    ^^This all day long^^
    I like the Sheptone AB Customs for this. A hotter PAF variant. (Full disclosure - I've bought a few sets and resell Sheptones, both the Tributes and the AB Customs as they are the ones I like.) To get your mid-boost, use a slightly hotter pickup, simulate it with a small capacitor, or use an EQ pedal.
  14. 6077dino
    6077dino Senior Member
    140
    91
    Sep 23, 2012
    Klein Epic Wicked Paf. That worked for in a similar case.
  15. arthurkandziora
    arthurkandziora Senior Member
    379
    142
    Mar 24, 2012
    I have a dimarzio 36th in the bridge of my Les Paul and that pickup has the best mids on any pickup barre none
  16. Blue Blood
    Blue Blood Senior Member
    925
    773
    Dec 11, 2010
    WCR Godwoods
    BK Black Dogs
    Own/ owned both, very middy pickups.
    I prefer powerful, easier to dial down thru the guitar then dealing with it the other way around.
  17. RAG7890
    RAG7890 Premium Member
    15,047
    24,204
    Jul 11, 2010
    May I suggest the following & then go with the one you like best.
    Talk to James at ReWind.
    Talk to Mark at OX4.
    Get two Sets & try them out.
    Keep the one that suits the Guitar best. It is not uncommon to test several Sets of Vintage PAF’s or Boutique PAF’s until you find the right Set for a particular Guitar.
    Good luck.
    :cheers2:
