out of phase
Discussion in 'Luthier's Corner' started by Weldaar, Jan 12, 2019.
  1. Weldaar
    Weldaar V.I.P. Member
    2,376
    405
    Mar 25, 2007
    Can the neck tone pot be wired to be an out of phase pot? I never use my neck tone knob as my guitar is fairly dark to begin with. Just curious if this could be done using the same pot.
  2. BadPenguin
    BadPenguin Senior Member
    896
    665
    Jun 13, 2015
    Uhhh, let's see if I get this.... you want to use the POT as a out of phase SWITCH?
    Technically, yes.... BUT you would lose the pickup as you turn it one way or the other. (by the time you hit, let's say 5, you would be grounding out the signal.) If you don't use the tone, pull it and add a switch, OR get a push/pull switch, and don't use the pot part of that.
    You know, many of my old friends would be aghast at me saying "don't use the pot...." Many too many smoky basements in my past.
  3. Weldaar
    2,376
    405
    Mar 25, 2007
    Pull it and add a switch. I find that confusing. I can wire most guitars, but how would I wire the switch?
  4. ARandall
    ARandall Senior Member
    12,462
    8,076
    Apr 16, 2012
    A well known search engine called google has an images section.
  5. Weldaar
    2,376
    405
    Mar 25, 2007
    Thanx, I’ll check it out.
