Original 50's ABR vs R9 ABR Video
Discussion in 'Vintage Les Pauls' started by Jakatone, Dec 1, 2018.
  1. korus
    korus Senior Member
    1,088
    396
    Apr 10, 2007
    Greater diameter? Thinner?
    If you have '50s ABR-1, what is the thickness of the top of the '50s saddle? 1/16"? More than that?
  2. UEF
    UEF Senior Member
    378
    302
    Feb 23, 2011
    E5CCF305-D9A6-4C71-8928-1210CF79D7A5.jpeg 714F726E-7B10-4BED-AE74-E5029E292927.jpeg D850D3CC-DEB1-4DCD-9235-A0031DF51041.jpeg
    The redder one is a 58, tea is 2018 R8
  3. MrWright
    MrWright Junior Member
    17
    5
    Aug 14, 2010
    do you think his videos are personally "enhanced"
  4. PierM
    PierM Premium Member
    4,090
    7,227
    Aug 19, 2016
    Not saying that, but I never managed to replicate those A/B my side with such extremely high magnitude. Usually the differences are subtle, and very hard to isolate in the form of a constant, but he seems always getting huge differences between everything he compares.
    Again, not assuming here, I do enjoy those video. I'm just not 100% sure those tests are clears from errors. (100% my very personal opinion that means nothing really).
  5. MrWright
    17
    5
    Aug 14, 2010
    ok, understood Piers ...this is the only video I've watched out of his 10,000 +/-
    PierM likes this.
  6. C.J.
    C.J. Senior Member
    179
    92
    Dec 28, 2015
    Johan does have a Ph.D in mechanical engineering. Kinda bugs me that he never gives any opinion about why things sound different in these kinds of tests but then, in fairness, that clearly isn't the sentiment of his content.
  7. Naquat
    Naquat Member
    63
    41
    Aug 14, 2017
    Here's Bernie Marsden's '59 L.P. "The Beast". The saddles don't look as flat as the one's mentioned on the vintage L.P. in this thread but they do appear to be Brass. True? And if so what else is different about it?
  8. Bruce Clement
    Bruce Clement Junior Member
    3
    0
    Jan 7, 2010
    Take a close look at his right hand position, particularly in the first pair of clips.
  9. zwiefldraader
    zwiefldraader Junior Member
    28
    17
    Oct 4, 2015
    Funny how different ears can percieve. To me, the 50s original is way brighter and articulate, with less bass - while the CS R9 sounds duller to me.
    But be careful. This might endanger some belivesystems. If the difference is that big, how Johan showed it, it might mean, the bridge and stoptail might be much more influencial than the WOOD. (Something I tend to believe for quite some time).
    Before we adress the different material, I guess the question should be how "anal" the modern ones are built. Maybe the tolerance in parts is higher now. You could even argue rust might have tightened the connections and screws on the old bridge, which might have a clearly audible effect (transfering more frequencies, less filtering).
    But for sure we should ask Johan if the strings with both bridges have been brand new.
  10. zwiefldraader
    28
    17
    Oct 4, 2015
    Wow first I did listen to the clip through smartphone speakers (better quality than my laptop) and then through cheapo laptom speakers and... it just turned around. The brighter one seemed darker on laptop an vice versa. We should take care of our audio system before deciding...
  11. zwiefldraader
    28
    17
    Oct 4, 2015
    btw. I am afraid if the vintage bridge is percieved brighter it´d be exactly why we´d rate vintage instruments superior - if warmer we´d praise that route, calling the modern ones thin and piercing. Perception is interpretation colored by preconceptions.
  12. treatb
    treatb Senior Member
    440
    83
    Apr 4, 2009
    the older ones were made with a different type of steel right or are they solid metal? the modern ones are chrome or nickel plated i believe. my r9's saddles have warn through a bit and you can see they are plated. are the vintage saddles plated? every little thing counts. what grind or grit did they edge the bottoms of the saddles with back then? it isn't just the thickness of the top of thesaddle that can add solidity to the tone. like those late 50's floated saddles in gibson acoustics, they killed tone. you need good connection, and those old bridges were probably all hand fit as well.
  13. zombiwoof
    zombiwoof Senior Member
    401
    303
    Feb 24, 2008
    I'm pretty sure ABR-1 bridges have always been made of zinc/Zamac and not solid steel, except maybe some early prototypes.
    Al
