OneSpot vs. Voodoo Labs Pedal Power II vs. Dunlop DC Power Brick vs. ..........
Discussion in 'Pedals' started by VictorB, May 6, 2010.
  1. VictorB
    VictorB Formerly LZF Super Mod
    33,346
    65,774
    May 31, 2007
    What's the best thing to power your pedal board with? I've heard the OneSpot could be noisy, the PP II is pretty expensive, but is probably high quality. I know nothing of the DC Brick...
    What's the general consensus?
    Lowdown likes this.
  2. Goostah
    Goostah Senior Member
    159
    10
    Feb 4, 2010
    PP2 is your hands down worry free best solution of the 3 you mentioned (assuming you are satisfied it has enough outputs and voltages to match your pedal requirements). Any noise generated will most likely be due to your combination of pedals and this is where the isolated outputs of the PP2 will be worth their weight in gold.
    Having said that the onespot will work just as well as a PPII if your pedals don't adversely react with each other to create noise. It really is something you have to experiment with based on your rig while also being mindfull of the max millamps you can put through the onespot when you daisy chain your pedals.
    Other benefits to the PPII over the onespot - variable input voltages, voltage sag option, safety cut to avoid frying your pedals. Voltage sag isn't a biggy for me. If you're handy with a soldering iron you can build one for a few bucks and use it on any power supply. I ended up realising I didn't really feel the need for a voltage sag (muff pedal).
    The DC brick?? I have no experience with this but I understand it is just a glorified onespot. Non isolated outputs put into a nice box. It won't doing anything to help you keep noise down.
    One other power supply I would through into the mix is the BBE Supacharger:
    The BBE is a copy of the PPII, virtually the same unit but without the power sag and the extra AC output. It makes up for this by including 120V/240V power switching. The dimensions are the same as a PP2 so it fits directly onto a pedaltrain board with no hassles using the pedaltrain mounts. I picked up one of these for U$85 and it has worked great. From memory I think there may be some subtle difference with the outputs (voltages and output types) so best to check this and see what you need.
    If you're on a budget, my suggestion would go with the onespot from a retail store that has a good return policy. If that doesn't work out with your rig, return it in good faith and get a BBE supa-charger for half the price of the PP2.
  3. VictorB
    33,346
    65,774
    May 31, 2007
    Thanks Goostah! I've never heard of the BBE SupaCharger, I looked it up on Musician's Friend, it doesn't seem to come with the battery clip converter cable, like the others do. The reviews were mixed as well, but who knows...
    It seems that the PP2 is probably the best bet, even if it is $170.
  4. switchback
    switchback Senior Member
    1,114
    351
    Feb 1, 2010
    Hey ledzep, if you can check into the new CAE power system it can be found on proguitarshop.com It is very impressive a bit costly but very nice and has a lot of options. Good luck
  5. VictorB
    33,346
    65,774
    May 31, 2007
    Wow, it is expensive... It may be overkill for me though, I only have about 5 pedals I need to power.
  6. fatb0t
    fatb0t Senior Member
    1,560
    53
    Dec 19, 2008
    The one spot is a cheap solution for now. If you play out often you'd better upgrade to the voodoo labs psu.
  7. SlapChop
    SlapChop Senior Member
    1,884
    965
    Dec 22, 2009
    I use the Guitar Fetish daisy chain (One Spot knock-off) with great results. The thing was under $20 with shipping... I power 5 pedals with it and run a couple EH pedals and my wah that don't have the same plug size as a boss and I'm totally happy with it. No noise or other issues. I was pleasantly surprised.
    Works for an amatuer like me.
  8. PraXis
    PraXis V.I.P. Member
    24,880
    24,261
    Dec 14, 2007
    PP2 is the best.
    Gigrig is the most versatile (5 amps!) but gets very expensive if you want to isolate.
  9. VictorB
    33,346
    65,774
    May 31, 2007
    I do gig often, it looks like I'll be going with the PP2 and NYC Pedalboards The Six Shot.
  10. switchback
    1,114
    351
    Feb 1, 2010
    I have the NYC gigman with a top tier and I love it, oh and also the CAE is actually going to end up around $195.00 proguitar is at retail other sites have it about $195.00, who knows you may want to expand ! :)
  11. ehamady6
    ehamady6 Senior Member
    3,787
    551
    Sep 4, 2008
    Voodoo Labs PP2
  12. Ayy Itss Daveee
    Ayy Itss Daveee Senior Member
    1,146
    109
    Feb 2, 2009
    I just bought the Dunlop DC Brick. I also have only 5 or 6 pedals at the moment too, and it works just fine for me. No noise or anything, and it also serves as a power conditioner and regulates the outputs.
  13. Goostah
    159
    10
    Feb 4, 2010
    Yeah I guess at that price, $150 for the BBE vs $170, I'd look at the industry standard PP2 also. At least you'd be guaranteed of good company backup from the guys at pedal power should something go wrong.
    Anyway, good luck with it man :cheers:
  14. VictorB
    33,346
    65,774
    May 31, 2007
    Thanks man.
  15. gordonm
    gordonm Senior Member
    115
    6
    Apr 17, 2010
    gigrig generator is one of the best.
  16. NoStatic
    NoStatic Banned
    2,625
    226
    Jan 5, 2010
    The problem I find with all, or most of these systems is that they require mains power to go to a big box on/under the pedal board. Im only aware of one system that puts the power supply and mains power connection away from the board.
    I would try an AMR or One Spot- they are cheap, and ive found pretty good. Unless you decide you really need something else.
  17. tele52
    tele52 Senior Member
    1,280
    146
    Apr 19, 2009
    Buy the Voodoo Labs and be done with it. Very high quality. You won't have to worry about it failing. I know that's the only unit Fulltone recommends it for use with their pedals, other than their own of course.
  18. badhabit
    badhabit Senior Member
    496
    13
    Jul 11, 2007
    +1 - Do yourself a favor and get the PP2- if you don't, like me. you'll end replacing whatever you bought instead. Bite the bullet, buy the best-you won't be sorry. I have two of them for my board. Anything else is noisy.
  19. ReadingOwls
    ReadingOwls Senior Member
    305
    8
    Mar 27, 2010
    I have the Dunlop DC Brick. It's built like a brick, and it comes with all of the wires. Quite cheap for what it is.
  20. Deftone
    Deftone Senior Member
    12,304
    9,567
    Feb 22, 2008
    Based on this link:
    .: adapters/power supplies :.
    and what I read here on MLP, I went with the Voodo Labs PP2+ myself. It's been working great, no issues. I like it.
