Nut width too small, will it cause problems?
Discussion in 'Epiphone Les Pauls' started by mentaldisorder3, Sep 10, 2017.
  1. mentaldisorder3
    mentaldisorder3 Junior Member
    11
    2
    Aug 28, 2017
    I ordered this but but apperantly it doesn't fit. There is a small gap as you can see. All the string will fit on it but, would that small gap cause problems?
  2. GRASS
    GRASS Senior Member
    330
    120
    Jan 3, 2011
    My advice would be get one that fits.
  3. JohnnyN
    JohnnyN Old School Premium Member
    4,420
    12,454
    May 15, 2010
    +1
  4. Charlize
    Charlize Member
    32
    9
    Dec 1, 2016
    Yes will be problem.
    Will be more difficult to add a fitting shim than to replace the incorrect one you have. Do not waste your time on a part that is little money.
    mentaldisorder3 likes this.
  5. Guitarmaniac5150
    Guitarmaniac5150 Junior Member
    7
    3
    Aug 16, 2017
    I installed a tusq nut on my standard and it fit perfect out of the package.
    mentaldisorder3 and Malikon like this.
  6. mentaldisorder3
    11
    2
    Aug 28, 2017
    Cool. Do you have a link for it?
  7. stiff fingers
    stiff fingers Double Platinum Supporter Premium Member
    117
    68
    Jan 1, 2016
    tusq xl nut. perfect fit with IMG_2796.JPG no sanding or fitting.
    GuitarMechanic likes this.
  8. PierM
    PierM Black & Gold Premium Member
    2,849
    4,320
    Aug 19, 2016
    Bought this nut for my Epi Custom, and does fit perfectly but it's too low, so I now need a shim.
  9. Guitarmaniac5150
    7
    3
    Aug 16, 2017
    The best thing to do is measure the L x W x H with venier calipers. Their website has alot of different sizes.
  10. chasenblues
    chasenblues Senior Member
    20,803
    30,786
    Apr 2, 2007
  11. moreles
    moreles Senior Member
    2,711
    1,339
    Apr 16, 2011
    As other say: yes, it is a potential (not probable, but definitely possible) problem, and it looks terrible, too. Glad you're replacing it. Just measure and get the right size. Fitting a nut, even when it's the right size, can be tricky, as the slot heights are critical. But there's no way around it, and getting a proper nut is really worth it.
  12. howardlo
    howardlo Senior Member
    111
    42
    Jul 6, 2015
    The 6061 nut is made to fit 2014 and newer Epis. That was the year they changed their nut slots. The 6060 fits Epis made prior to 2014. Been through that. It was quite a while before they began making the ones to fit the newer ones.
    stiff fingers likes this.
  13. SwisherSweets
    SwisherSweets Senior Member
    162
    84
    Apr 11, 2012
    Get a nut that fits. Tusq brand or WD music pre slotted epiphone nuts work.
