Norlin era laquer vs 90’s vs current
Discussion in 'Norlin Years' started by Heppe, Sep 14, 2018.
  1. Heppe
    Heppe Senior Member
    597
    254
    Jan 14, 2011
    Hello,
    I have two Norlin era Gibsons, one from 95 and a few from the 2010’s
    Have Gibson changed the composition of the laquer over the years or have the formula been consistent?
    As an example my white 1976 Explorer has not yellowed as much as my white 1995 V hence the question.
    Regards
    Henrik
    64FC0C4E-91ED-4B0E-ADF7-DBBE7C351055.jpeg 11C044DD-CC4A-4FAF-8722-67B4C4C8EE4A.jpeg 1EFC6FCC-E7F1-45F1-A601-0FF67C47B3FA.jpeg
  2. jcm800
    jcm800 Member
    79
    100
    Jul 22, 2010
    My 82 and 90 are dark solid colors so I couldn't tell as far as the yellowing goes.
    My 90 is starting to check in the same areas as the 82.....headstock, base of neck, edge of body
    It's just not as pronounced, being 8 years newer. I'd say it's the same formula in that era.
    I
  3. 1981 LPC
    1981 LPC Senior Member
    2,248
    1,657
    Dec 8, 2010
    Norlin era ended in 1986...
    Norton, bblooz and jojo like this.
  4. dspelman
    dspelman Senior Member
    10,250
    6,364
    Apr 30, 2009
    There's a chance that the formulae have changed from year to year, but I haven't seen anything but random anecdotal evidence that would suggest anything definable going on. I have Gibsons from every 10-year period from 1949 up to 2009, and I really don't see a commonality that would make a difference.
  5. jcm800
    jcm800 Member
    79
    100
    Jul 22, 2010
    I was referring to the Norlin / 90's.....;)
  6. Heppe
    Heppe Senior Member
    597
    254
    Jan 14, 2011
    Thanks for the info
    There is actully no checking at all on any of my Gibsons even the two from 76 and 78
    Henrik
  7. ARandall
    ARandall Senior Member
    12,621
    8,310
    Apr 16, 2012
    The formula has probably changed so many times as to have lost count. I'm sure companies back in the day weren't so much of a slave to the current trend of consistent 'upgrades' to sell you the latest and greatest, but the changing environmental regulations over the period would have made for a great number of changes.....some that even Gibson would not have been aware of I'm sure.
    But all of this doesn't even begin to cover the most important effect in lacquer ageing......where the guitar was played, how much, smoke exposure....UV exposure.....temperature changes....humidity changes. These by far will have a greater affect than any nitro formulation.
  8. kakerlak
    kakerlak Senior Member
    1,915
    965
    Feb 5, 2014
    This is a good answer and, anecdotally, I've seen plenty of totally yellowed-out white '70s-'90s Gibsons and lots of newer ones that certainly seem to be headed in that direction. I think the tendency for clear lacquer to yellow is pretty near universal across any differences in formulations, regardless of resistance to checking, etc. Like ARandall said, differences in where/how the guitar was stored and played account for the variation from guitar-to-guitar. Your two examples look pretty darned close, color-wise, to me and both are fairly un-yellowed. However you've been keeping, using, cleaning, them, etc. is doing a good job of inhibiting the yellowing process.
  9. PierM
    PierM Premium Member
    4,296
    7,814
    Aug 19, 2016
    That ES custom I bought last year its yellowing at the speed of the light;
  10. davestp1
    davestp1 Senior Member
    384
    37
    Apr 5, 2009
    The binding on my 78 bb custom is a medium yellow while my 92 black standard looks the same as when it left the factory
  11. Progrocker111
    Progrocker111 Senior Member
    3,400
    2,434
    Oct 30, 2011
    I would say from my observations that there must have been a significant change in approx. 1971/1972, cause since 1972 the classical finish checking and "spider lines" from late 60s are much more scarce, nearly non-existent and the finishes have kinda more plastic feeling, so they perhaps changed the formula with added plasticizers. :hmm:
    Gtarzan81 and LPPILOT like this.
  12. moreles
    moreles Senior Member
    3,175
    1,843
    Apr 16, 2011
    A lot of guitar historians make the blanket claim that the newer general formulations of nitro used on guitars have had increasing % of plasticizers in the formulation, relative to past mixes, in order to resist cracking and checking. The story goes that this reflects an effort to minimize warranty claims for checking. I hear this everywhere, repeated as truth. It is really is true, then more modern nitro would be somewhat less ideal acoustically, while having the crack-resistant quality that plasticizers provide.
  13. LPPILOT
    LPPILOT Senior Member
    1,089
    556
    Jun 22, 2010
    The formula seems more stable the past era from 71 or so on . i see less checking . Also , the thickness applied may have something to do with it or the type of paint underneath .
    Progrocker111 likes this.
  14. efstop
    efstop Gold Supporter
    3,631
    8,545
    May 30, 2015
    Wouldn't plasticizers in the lacquer be better acoustically (as long as the layer is still very thin) because the finish would rise and fall with the wood, instead of the wood being damped by a harder, dried finish? On the other hand, it might only matter on an acoustic. I don't believe the finish on a solid body make one whit of difference because IMO there isn't enough mass in the finish to affect overall tone. If you believe in tone woods, of course :D
    mudface likes this.
  15. ARandall
    12,621
    8,310
    Apr 16, 2012
    The surface doesn't rise and fall. The whole vibrates as one. Anything that moves independently of the whole is a source of energy loss.
    Guitars are an energy system......they are not merely a 1 way loss of energy (as in once it exits the strings its gone) as many seem only to be able to conceive it as.
  16. danny
    danny Senior Member
    140
    152
    Feb 15, 2011
    I dont want to bring you down but !!!!!
    I think both the 95 and the 2000's are not norlins acording to this , I would say vintage but who knows !!!! read this and get you own answers I though tha the norlin era finish in 1985 !!!!
    http://www.mylespaul.com/threads/faq-norlin-history.38456/
    Thumpalumpacus likes this.
  17. Heppe
    Heppe Senior Member
    597
    254
    Jan 14, 2011
    Danny, sorry my post might have been a bit unclear
    What I meant was I have a variety of Gibsons from the different times mentioned
    Two of which are from the 70’s, LP from 78 and Explorer from 76
    The V is a 95 and the rest are from 2012-2016
    KS 5150 likes this.
  18. tjdjr1
    tjdjr1 Member
    59
    9
    Jan 25, 2017
    My 2016 traditional seems to have more fine scratches already vs my 78 deluxe and 80 standard. For me it seems the newer finish is softer than the older one.. my 2 cents.. My 2017 SG still remains pretty clean haven't had it out to may gigs yet.
  19. mudface
    mudface Non-Deadbeat/Non-Prominent Double Platinum Supporter Premium Member
    6,581
    21,349
    Aug 29, 2016
    I don’t think that Gibson has a choice in what the formula is when they purchase the lacquer they use. Gibson does not warrant or guarantee the finish on their guitars. The manufacturer of the nitro changed their formula to fit a variety of uses besides a finish on guitars. I’m sure that Gibson is more concerned with quality and ease of application and the fastest drying and curing time. These are the specifications that Gibson may require from the lacquer they purchase. After all they’re about production. This is just my common sense opinion.:)
    scozz likes this.
  20. elephantrider
    elephantrider Senior Member
    3,143
    3,148
    Oct 23, 2015
    my 75 is very faded, but there is almost zero checking, fwiw...
