Noisy pedals
Discussion in 'Pedals' started by ttl100, Dec 21, 2007.
  1. ttl100
    ttl100 Member
    34
    2
    Dec 3, 2007
    Hi. I need some help here. I got myself a Korg 600mA 9V AC-DC convertor for my effect pedals. The problem is the moment I plugged in the power my amp picks up the mains 50hz cycle. It's very annoying. I daisy chained the power supply from one source coming from the convertor using the adapter. I switched guitars between single coil pup to humbuckers and the annoying noise is still there. I tried next to disconnect power one pedal at a time. It is still noisy up to 2 pedals. But when I am down to one pedal, the noise disappeared completely.
    How can I solve this problem? I was told not to daisy chain but if I don't daisy chain how do I power up all my pedals? Is there any secrets to this? Please advise.
    TQ
  2. ZoomZilla
    ZoomZilla V.I.P. Member
    6,263
    2,827
    Dec 1, 2007
    You can probably find something cheaper than this, but something like this is what you need if you want to run multiple pedals and are getting interference.
    Pedal Pad MPS-Lite Pedal Board and more Guitar Effects at GuitarCenter.com.
  3. ttl100
    ttl100 Member
    34
    2
    Dec 3, 2007
    I don't want to get any of these cos I like to customize. I have seen many people have used my method and even daisy chain with no problem. What is the secret here? Hmmmm ....... please help. Thanks!
  4. coldsteal2
    coldsteal2 V.I.P. Member
    37,066
    14,418
    Sep 6, 2007
    making sure everything is grounded has alot to do with it
    and some times you need to reverse your dc converter plugin
