No tone signal after replacing my capacitors.
Discussion in 'Tonefreaks' started by Jackangus, Aug 18, 2017.
  1. Jackangus
    Jackangus Senior Member
    352
    100
    May 27, 2014
    I just replaced my orange drop capacitors with Stewmac golden age treble bleed capacitors.
    The sweep on both volumes on my Les Paul are amazing now compared to the old capacitors, but both tone knobs don't work.
    I am new with the soldering iron, and the only mistake I can see I made was to burn the plastic coating of the white wire going to a pot. Oh, and I gave my self a nice burnt thumb.
    It is a very small burn, I can see the bare wire, but the wire is intact. Also the white wire only goes to one pot, so I can't see that being the problem.
    Any ideas?
  2. moreles
    moreles Senior Member
    2,710
    1,337
    Apr 16, 2011
    Pix of your install would help. Did you replace the old tone capacitors with the treble bleed setup? If so, that's incorrect. The treble bleed gets wired onto the volume pots and the previous tone caps remain.
    Jackangus likes this.
  3. Jackangus
    352
    100
    May 27, 2014
    Sorry for the long delay, Yes I did.
    All sorted now, thanks.
