Nitro on headstock cracking and bubbling
Discussion in 'Gibson Les Pauls' started by Soloshchenko, Dec 5, 2017.
  1. Soloshchenko
    Soloshchenko Senior Member
    259
    181
    Jan 4, 2014
    Hi, how could I fix the cracking and bubbling on the nitro on my Les Paul studio? I was thinking razor blade and or sand paper down while avoiding the logos and then shooting clear to build back up to wet sand flat and polish?
    What IMG_20171115_212933.jpg Do you think?
  2. scozz
    scozz Senior Member
    3,511
    4,118
    Sep 3, 2007
    Wow...what year is that?
  3. Left Paw
    Left Paw Senior Member
    4,056
    2,451
    Dec 29, 2013
    No, that would look re-done in a way that you wouldn't like. Need to strip the headstock and get new logos. Then finish properly.
  4. Soloshchenko
    259
    181
    Jan 4, 2014
    Thought so. It's a 2002 that plays and sounds terrific.
    Gem23 likes this.
  5. T00DEEPBLUE
    T00DEEPBLUE Senior Member
    386
    355
    Nov 25, 2014
    Yeah there's no proper way to repair that without stripping off all the old peeling lacquer and refinishing the headstock face in full. Sanding all the silk screen logos off as you remove the old lacquer is going to be unavoidable, so you'll need to apply new decals as well.
  6. scott1970
    scott1970 Senior Member
    3,375
    7,167
    Oct 22, 2015
    On the plus side, you didn't have to mail it off to someone and spend a ton to have it relic'd.
    Who, Side Burns and Gem23 like this.
  7. Gem23
    Gem23 Senior Member
    164
    83
    Jul 1, 2017
    Mine is like that. Its a 1997 and possibly worse than yours, laquer has cracked and split over most of the body, and a bit of the neck. I'm leaving mine. I probably won't sell it, and like the look of it. I don't want to be refinishing it, although I'm tempted to strip the whole wine off and have it natural, then I would sort the headstock but not before.
  8. Gem23
    Gem23 Senior Member
    164
    83
    Jul 1, 2017
    That fretboard looks quite dry, no?
  9. jc2000
    jc2000 Senior Member
    6,247
    3,011
    Jul 16, 2013
    WoW! that looks bad...... Id have it re done.
  10. Gem23
    Gem23 Senior Member
    164
    83
    Jul 1, 2017
    Who likes this.
  11. dspelman
    dspelman Senior Member
    10,080
    6,116
    Apr 30, 2009
    Get it redone, but use a decent finish this time.
    Who likes this.
  12. Biddlin
    Biddlin Senior Member
    1,565
    1,902
    Aug 21, 2012
    I believe that there is a fiber overlay used on most Nashville Gibson headstocks. My 2003 SG Special has this same disease. Gibson quoted me $1000 to repair it. I like the look just fine now.
  13. ARandall
    ARandall Senior Member
    12,091
    7,577
    Apr 16, 2012
    Its not the fibre that is the issue......the entire Norlin era used them and there is no such issue from that period.
    Whatever prep was done with sealing or black coat it simply didn't adhere well to the top clear.
    lakeburst, winexprt and Who like this.
  14. T22
    T22 Senior Member
    114
    41
    May 24, 2011
    Wow. Shouldn't that be covered by Gibson's guarantee?
    Have you kept it at room temp? You know to let it sit in its case for a while when taking it in from the cold?
  15. moreles
    moreles Senior Member
    2,910
    1,537
    Apr 16, 2011
    Yes, it's a defect in the build. I don't know how the warranty reads. It's not a hard fix at all if you are careful and patient. The fiber overlay finishes just fine, in my experience. There are several possibilities why this finish is no longer adhering, but the only fix I know is to remove it all, clean and sand the fiber properly, lay in new decals, and clear.
  16. Who
    16,692
    30,446
    Mar 15, 2012
    A) Fill jug with acetone
    B) Dip the headstock in the jug
    C) Stir
    D) Let sit
    E) Stir some more.
    Remove and allow to almost completely dry. Spray a good wet coat of nitro, melting it into the remaining slop that is your headstock. Allow to dry.
    Sand that smooth, and topcoat as normal.
    My instructions can't make things worse! ;) :laugh2:
  17. endial
    endial Senior Member
    2,372
    2,153
    Oct 23, 2014
  18. ARandall
    12,091
    7,577
    Apr 16, 2012
    Even if finish durability was ever covered by any Gibson warranty at any time (it has never been to my knowledge), the time elapsed for any finish defect to occur is LONG past. No finish is immune to age, and nitro specifically will check in the normal course of use.
    This effect is as much moisture/temperature as it is the poor bond. Its just that the combo makes the checking only affect the top clear which then lifts.
    Gem23 likes this.
  19. BadMojo
    BadMojo MLP Vendor
    258
    272
    Nov 11, 2017
    Spray it with some blush remover. It should re-melt the nitro. Worth a shot.
    lakeburst and Who like this.
