NGD!
Discussion in 'Fender' started by Money f'Nuthin, Aug 6, 2017.
  1. Money f'Nuthin
    Money f'Nuthin Junior Member
    29
    58
    Aug 1, 2017
    Just got this today, fresh outa the box and went to work setting it up. The bridge saddles look out of place, because I had to file slots in them to keep the strings from jumping out of place (stupid Jaazzmaster type bridge), but it is actually intonated. I also found out that changing strings on a Bigsby with a tension bar is the very definition of PITA!
    Anyway, after adjusting, tweaking, and some nut filing, it is just the way I like it. Sounds good, plays good. It's a keeper. It's hard to capture on camera, but there is even some flame in the neck.
    So without further ado, presenting my new Squier Vintage Modified Cabronita Tele with Bigsby. :dude:
    Phil W, paruwi, Mule Train and 5 others like this.
  2. rikko
    rikko Senior Member
    3,248
    3,097
    Feb 20, 2013
    Bad A$$!!!
    Money f'Nuthin likes this.
  3. Guitaraxe
    Guitaraxe Senior Member
    727
    337
    Aug 22, 2015
    Cool!
  4. Mule Train
    Mule Train Senior Member
    9,592
    10,435
    Aug 6, 2010
    I love Squiers and that's a super nice one. Congrats!
  5. DarrellV
    DarrellV Make the Switch for the Better! Silver Supporter Premium Member
    10,972
    14,231
    Nov 1, 2016
    :applause::applause::applause:
    Dang man! Blowin' it up in here again! With another NGD! :shock:
    Congrats! Really nice looker!
    ABout the PITA, did you pre-bend the ball end into a hook first? I've read that it helps keep the string from popping off the bar....
  6. e44crowe
    e44crowe Senior Member
    442
    329
    Jan 14, 2012
    I had one of these. Sounded great! I'd have one again but the tuning issues and the strings popping out of the saddles was more than i wanted to deal with.
    Rock on!
  7. Money f'Nuthin
    29
    58
    Aug 1, 2017
    Yeah, did that, it's just that it's hard to keep the ball end on when winding the string on the post without a third hand to keep some tension on the string.
    Someone told me to use a capo. Problem solved. :)
  8. Money f'Nuthin
    29
    58
    Aug 1, 2017
    I filed notches in the saddles, set the bridge down flush on the body so it doesn't rock, raised the saddles for proper string height, re-cut the nut, lubed it properly and; no more strings popping off the saddles, and the tuning stability is great.
    I did have a couple of dead spots, and then I noticed the tailpiece was sitting on four felt washers instead of actually sitting on the body.
    I pulled off the Bigsby, got rid of the washers, and now it sits about 1/8 inch lower. A little more downforce on the bridge, and solid contact with the body. The dead spots are gone, and it now has better sustain all around. Still no tuning issues.
    I have no idea why they would use those stupid felt washers.
  9. DarrellV
    10,972
    14,231
    Nov 1, 2016
    To protect the finish.........of a Squire! :facepalm:
  10. Money f'Nuthin
    29
    58
    Aug 1, 2017
    And apparently to kill the tone and sustain too. And why do you need to protect the finish under the Bigsby? It's not like there aren't 4 big screw hols if you remove it. :facepalm:
    DarrellV likes this.
  11. DarrellV
    10,972
    14,231
    Nov 1, 2016
    Exactly!:dunno::thumb:
  12. Walt_T
    Walt_T Senior Member
    2,850
    2,072
    Apr 3, 2014
    I like it!
  13. DarrellV
    10,972
    14,231
    Nov 1, 2016
    Curious if that's a real TV Jones in the neck, or a knock-off....
  14. Money f'Nuthin
    29
    58
    Aug 1, 2017
    It's a Fender Fidelitron. So I guess a knock off.
    Sounds pretty good though.
