[NGD] Wildkat. Bridge pickup doesn't work
Discussion in 'Epiphone Les Pauls' started by Azathoth, Aug 23, 2012.
  1. Azathoth
    Azathoth Senior Member
    338
    47
    May 18, 2009
    Wildkats have no back panel, so you can't get to the pots to check their wiring.
    Has anyone done any work on a Wildkat?
    [edit] There's a tiny bit of volume coming out of the bridge pickup that's barely audible. When the guitar arrived, the tone pot was loose, which makes me think it's probably a pot or wiring issue.
    [edit 2] Got it to work. It's the tone pot. I stick a finger in the f hole and tweak the wires, using the skills I learned from fiddling with my anose while texting my 39-year-old lady.
    [ame]http://www.youtube.com/watch?v=iAUJyWnevkM[/ame]
    [NSFW language]
  2. drpietrzak
    drpietrzak Senior Member
    2,192
    929
    May 19, 2010
    Like a 335 you use the pickup holes and F holes to work on them. Party it is!
    1 person likes this.
  3. Azathoth
    338
    47
    May 18, 2009
  4. fullspectrum
    fullspectrum Senior Member
    961
    929
    Apr 26, 2012
    HNGD...where did you get it? I'm guessing you didn't get it brand new or you'd be sending it back for another one because of the wiring issue...
  5. Azathoth
    338
    47
    May 18, 2009
    I got it on ebay. It is brand new and still has the plastic sticker covers on the pickups. There's a 30 day return policy, but I've decided to keep it and try to fix it myself. It's pretty gol' dang sexy.
  6. fullspectrum
    961
    929
    Apr 26, 2012
    The problem is...no access covers. Soldering is easy...but through those cutouts??? I know...pain in the ass sending it back. Been there done that.
  7. SessionGuy
    SessionGuy Junior Member
    10
    4
    Sep 4, 2012
    Hi, this is nothing to do with your problem, but I'm trying to spread the word on a fix for the Wildkat's dire tone problems, after fixing my own recently. You can read about it here: http://www.award-session.com/pdfs/Epiphone_WildKat_Tone_Problem.pdf
    You may find that this wiring upgrade will benefit many LPs too, although not to the same degree as the Wildkat as it has so much coax cable.
    Good luck.
