NGD - Slight mystery Greco, clarification needed.
Discussion in 'Other Single-Cuts' started by Lokkochaa, Mar 5, 2018.
  1. Lokkochaa
    Lokkochaa Senior Member
    136
    53
    May 17, 2012
    So, a number of years ago I purchased a Greco on a friends recommendation, 1977, likely a EG500 or higher. Had a lovely neck and really sweet sounding pickups, I stupidly traded it against something else and have been longing for one ever since.
    Last week i managed to bag one from Japan. Photos were sketchy at best and it was a fair risk on my part, but i loved the colour and it came with a hardcase.
    A big box turned up on Saturday (HEAVY box) and i went at it like a kid at Christmas! Popped the case and went about checking it over and straight into the workshop for a strip down.
    Specs I can work out are
    Pancake body
    Looks like a multi piece maple neck
    Ebony fretboard
    Real MOP inlays
    Two piece full thickness maple cap = looks like a tobacco burst
    Original pickups and pots (and strings by the look of them) hardwear looks original too.
    No serial number.
    So, my guess is is that its a 1974, a very late 74. Pickups i think date it to December 12th 1974, could someone clarify what pickups these are?
    Sounds and plays killer after a damn good clean and fret polish. Bridge pickup sounds a little weaker than the neck so ill need to do a bit of messing with pickup heights. IMG_20180303_113341.jpg IMG_20180303_113652.jpg IMG_20180303_113658.jpg IMG_20180303_133723.jpg IMG_20180303_133728.jpg IMG_20180303_133848.jpg IMG_20180303_134442.jpg IMG_20180303_141559.jpg
    truckermde and brokentoeswalker like this.
  2. Roxy13
    Roxy13 Senior Member
    3,703
    13,582
    Dec 27, 2017
    I'm probably not qualified to help you, but nice guitar, congrats!
  3. Lokkochaa
    136
    53
    May 17, 2012
    Thanks man :)
  4. Troy McClure
    Troy McClure Senior Member
    445
    182
    May 4, 2016
    Are you sure it's a full thickness two piece maple cap? Those pics make it look very much reminiscent of the plywood topped early Greco's but I guess photos can be misleading because of the angle etc. Pots and pups may have been changed as that soldering doesn't really look factory standard. There's a load of Greco catalogs around so shouldn't be too hard to drill it down to the likely model
  5. bluesriffdev
    bluesriffdev Senior Member
    428
    307
    Mar 10, 2014
    Probably mid 70s. Does it have a bolt on neck? That'll help identify whether it is early-mid 70s or mid-late 70s. I'm not familiar with those pot codes, unfortunately, but I'm sure someone here is. It does have pickup routes that are similar to many plywood-topped Grecos... Does the pickup cavity have solid walls just like a Les Paul should have, or can you feel around underneath it?
  6. Lokkochaa
    136
    53
    May 17, 2012
    Yup, 100% sure its a 2 piece maple cap, will upload a few better pics, had to take an iron to it to reconnect the earl wire as it had popped lose.
  7. Lokkochaa
    136
    53
    May 17, 2012
    Nope its a set neck. Definitely a soild top, its not hollow under there and it weighs 10.5 lbs
  8. Lokkochaa
    136
    53
    May 17, 2012
  9. Troy McClure
    445
    182
    May 4, 2016
    Thanks, does it have a belly cut? The pup routes made it look like one of the lower end plywood topped ones as they were plain with sycamore tops made to look two piece. As that's not one of those maybe a EG650 or above.
    There are catalogs here you could look thru http://brochures.yokochou.com/en_index.html . There can't be many standards with the block inlays and plain topped, as opposed to flamed, so hopfully should be easy to spot especially as the later stuff ,1975?, had serial numbers.
  10. Lokkochaa
    136
    53
    May 17, 2012
    Yeah it has the belly cut. Get what you mean about the pup routes. I'm pretty sure it's an early one, 1974. The only one that's that age with the block inlays and tobacco burst is the EG800.
  11. Caretaker
    Caretaker Senior Member
    5,705
    3,619
    Mar 27, 2007
    The tuners are old 70`s Ibanez star tuners.
    scott 351 wins likes this.
  12. Lokkochaa
    136
    53
    May 17, 2012
    I thought that (had a 74 ibanez Scruggs) but they have the G on them? Very nice tuners actually
  13. Troy McClure
    445
    182
    May 4, 2016
    Yep, everything points to late 74 EG800, the 650's were hollow bodied, they switched to the two hole TRC's in 75 and the belly cut disappeared that year too I think.
  14. scott 351 wins
    scott 351 wins Senior Member
    1,421
    2,104
    Jan 31, 2009
    More like thanks groovy chick!! Lol
    truckermde and Roxy13 like this.
  15. Roxy13
    3,703
    13,582
    Dec 27, 2017
    I think I've seen 2 other women here. There are more women on the tractor forums!
    truckermde and scott 351 wins like this.
  16. chasenblues
    chasenblues Senior Member
    21,171
    31,825
    Apr 2, 2007
  17. Lokkochaa
    136
    53
    May 17, 2012
    Haha apologies, I normally hang around the Luthiers corner :)
    Roxy13 likes this.
  18. Lokkochaa
    136
    53
    May 17, 2012
    Yeah thats what i was thinking/hoping. I really wish i knew what the translation under the original Greco advert, havent been able to find that online. Do we have anyone Japanese in the house?
  19. bertrand4070
    bertrand4070 Senior Member
    1,041
    354
    Jul 28, 2012
    can someone show what is a belly cut ? never heard about. thanks.
    truckermde likes this.
  20. truckermde
    truckermde Senior Member
    13,813
    14,588
    Oct 21, 2012
    Here ya go buddy. More common on Fender types than LPs...
    bertrand4070 likes this.
