NGD: Kramer Cheapo Deluxe
Discussion in 'Other Guitars' started by efstop, Jul 29, 2017.
  1. efstop
    efstop Senior Member
    1,946
    3,575
    May 30, 2015
    Well, OK, it's actually a Baretta Special, and it doesn't look especially cheap. Not sure I'll keep the pickup, but I haven't ran it through any pedals yet, just my AmPlug. I would also like to set the trem for raising pitch as well as lowering. I read that's a balancing act and it might be more than I want to fck with.
    So, here it is, lying on the Gibson bag I brought it home in, with the tools, sticker and 10' cord that will look good in my audio parts box.
    Thanks again for all the input on my previous thread!
    acstorfer, bungle, Who and 5 others like this.
  2. Zarg
    Zarg Senior Member
    441
    118
    Jun 29, 2016
    awesome! that's what I wanted to buy recently too, it will eventually happen.... its just too cool!
    efstop likes this.
  3. DarrellV
    15,410
    32,756
    Nov 1, 2016
    Eddie rocked the world with one pickup and knob, on a Kramer cheapo. Time for you to take it to the next level with yours!
    :dude::jam:
    thatF-INGflyingVguy and efstop like this.
  4. efstop
    1,946
    3,575
    May 30, 2015
    It's quite cool, simple, too!
    I don't think I'll make it to Level "Eddie" :jam:
  5. guidothepimmp
    guidothepimmp Senior Member
    584
    545
    Sep 8, 2012
    single pup fiddles for the win, congrats, cool guitar
    efstop likes this.
  6. truckermde
    truckermde Senior Member
    14,209
    18,081
    Oct 21, 2012
    ALL about the business :thumb:
  7. Benjammin
    Benjammin Senior Member
    19,301
    13,251
    Jul 4, 2009
    So, what's the verdict? These guitars have come up in discussion a few times around here, but I think you're the first to buy one. Hows the build quality (frets, etc)? Whats the neck like?
  8. efstop
    1,946
    3,575
    May 30, 2015
    The build quality is very good overall; frets are smooth, the neck is wide and slim and has a nice satin finish. No paint errors on the body, and the action may be a bit high but I don't know what to do with really low action :D
    The nut may need some minor filing and/or lubing. A couple of strings stuck sharp after using the vibrato, but giving them a firm snap brought them down again. On the other hand, a nut replacement might be in the future.
    I don't think I like the pickup all that much, as it's wound quite hot, and has a treble bleed on the lone volume pot. Easy enough to disable, and I have yet to try the guitar through the wah or any of my pedals.
    I wasn't expecting much, really, but I think it's a good guitar that needs a small amount of adjusting.
    Benjammin likes this.
  9. Benjammin
    19,301
    13,251
    Jul 4, 2009
    I use pencil graphite in the nut slots the first few times I change strings, that tends to help (unless there is a bigger issue at work). Glad you like it :thumb: I maybe bite the bullet and order a white one
    efstop likes this.
  10. howlermonkey
    howlermonkey Senior Member
    202
    178
    Nov 19, 2013
    If you plan to float the tremolo, I have a solution I recently e.mailed to floyd rose himself as an upgrade to his tremolo stop lock so you can still have a stable tremolo that won't go sharp when you palm it but still allows pulling up.
    Add this..........
    To this..........
    The trick is finding the correct spring pressure and distance from the fulcrum point of the tremolo.
    They come in tons of spring rates.
    What you want is the tremolo to gently stop on the ball and then tighten the tremolo springs slightly but not enough to push the ball in.
    Even better.....get rid of the lock nut (not shown in pic) and use a spring between block and head of bolt to keep it from turning.
    Spring will also pull the head away and remove any slack in the threads.
    The design really needs to be thicker where it is threaded because it sure looks weak.
    efstop likes this.
  11. efstop
    1,946
    3,575
    May 30, 2015
    Thanks for the tips! I'm not sure I want to mess with the trem just yet. It's a Kramer design; looks like a Strat trem but I've never seen one of those up close. Trem guitars are new to me, if we don't count the '63 Jazzmaster I owned for a short time forty years ago. The guitar is cheap enough that I will no doubt tinker with it
  12. Donal
    Donal ¯\_(ツ)_/¯ Premium Member
    13,456
    13,075
    Aug 25, 2009
    Cool Guitar :thumb:
    Congrats and HNGD :applause:
    efstop likes this.
