NGD - Ernie Ball Music Man Valentine
Discussion in 'Other Guitars' started by cybermgk, Jul 6, 2017.
  1. cybermgk
    13,466
    17,679
    Jul 7, 2011
    I actually got this Sunday, of the 4th weekend. Been to busy enjoying it and getting to know her to make this thread. With the sale, a coupon, trade-in, I got it for a shade uner $1100 (almost half street price).
    I decided to check out the Sam Ash 'Hidden Sale', basically 15% plus I could use coupons. I went primarily to look at the Gretsch Streamliner line. I have 2 Fender Deluxe Roadhouse Strats. The 15' doesn't get the play the 16' does (just love that satin neck). I've been trying to sell it locally for quite awhile, so didn't mind taking a hit on trading in. Unlike Guitar Centers, Sam Ash really take care of the guitars that are out. So, I figured if something else caught my eye, what the heck. US made PRS wasn't out of the question.
    The Streamliner's are nice guitars. I really liked the Jr center block models. I'm just not a big box guitar guy. GREAT bang for the buck. The Broad tron or Broadcaster pickups have a hint of the Gretsch tone. Sound pretty good. But, ultimately, they didn't add a lot to what I already have. It would have been adding another great bang for the buck guitar, that ultimately wouldn't get played a lot.
    Then I saw, that the Sam Ash here, sells Ernie Ball Music Man guitars now. I have a friend on another forum, a phenomonal player, whose opinion I respect a lot. He has nothing but EBMM guitars now, and swears by them. He has sold off some very nice guitars after getting his Music Man. Sam Ash had several of their Thrashy types (long horns), as well as Super Strat and Strat analogs. I'm not big on the long horn look (though I can see the appeal for some). I'd be trading in a VERY versatile Strat, so those didn't seem like a good choice
    But, they also had as their 'Guitar of the Week', an Ernie Ball Music Man Valentine in Trans Maroon. Yes, it is technically a Signature model for James Balentine of Maroon 5. Of that, I really didn't care. What struck me was the Music Man reputation, and the tonal possibilities.
    On first picking it up, you can tell it is a quality instrument. It just feels like quality. It is made from top quality parts, wood, right here in the U.S. The Neck is striking. It's a seriousally flamed, BAKED maple neck that is treated with oil and wax only, except for the head. One of THE most comfortable necks I have ever played. The 'slab' body reminds of a Telecaster, but is a wedge shape. It is thinner at the 'top side, than the bottom. It isn't as comfy as having a scarf, but it beats a Tele.
    Below is the full set of features. There are Stainless Steel Frets, Schaller Locking tuners, Compensated Nut, Individual, vintage steel saddles, string through. The bridge is one of the most solid of this type I have ever come across. Precision adjstment on height, etc. Pots are top notch push push. Even the backplate is coated Aluminum metal for better grounding along with the completely treated cavity with acrylic resin. Sculpted neck joint is very nice too. Tele like Single coil in the Bridge (but in HB sized shell), and a MM Humbucker, that splits in Neck. More on tone later. There is a separate, adjustable 'Silent Circuit' for each pup to remove single coil hum and a built-in 5-20db boost circuit.
    There is attention to detail all over this guitar. This is a phenomonally built guitar. It may cost more, but, you know you have quality in your hands. This guitar allows for as low an action with zero buzz as you can get (even too low, such that bends fret out on half tone bends). It has rock solid tuning. I was abusing the strings and it never budged. Intonation was/is spot on. It's the first guitar I have had with a compensated nut. Not sure if that has anything to do with it. But the individual bridges also have enough travel to get perfect intonation over whole fret bboard. The Valentine is easily the best setup from maker guitar I have ever had.
    How does it sound? In a word, fantastic. The Bridge pickup definitely has a Tele vibe. In Valentine's words, with working with Ernie Ball, he wanted to create a guitar that could cover their whole set, have a classic/vintage 'feel' but be modern. He tried to combine aspects of a Tele with an ES 335. The Bridge has all of that Tele vibe. The Neck as a humbucker is very glassy, VERY balenced across the frequencies, with great bottom end and high end sparkle. BUT, it can also be split by hitting the Tone knob push/push. And unlike any other guitar that does this, it doesn't lose volume or even output. This is from the Neck Pickup Compensation circuit when the the neck is split. It has an adjustable (via trim pot in cavity) boost. So, when you go coil split, single coil, no loss of output or volume, just that single coil tone. You can even set it to be boosted for lead play if you want. Middle position is extremely useable, with a bit of spank. Neck Humbucker and bridge SC work great together, and definitely does split. And then there is a 5-20db boost switcheable with the Volume push push. Trim pot in cavity adjusts the 5-20db. So with all of that, the different configurations, boost, using your knobs, this is almost the one guitar to rule them all. Can't quite get that thick, distorted, humbucker, bridge tone. But, with the boost up, and bridge, you can get pretty much P90 tone.
    These are MM unique pickups, wound in US. I have never had pickups that respond to different strings like these do. I went from the stock Slinkys to Fender Pure Nickel, and you REALLY hear the different Strings, like no other guitar does. Sure, others I can hear a difference, but it was like different pickups or guitar, with different strings. The 'Silent Circuit' works like a champ.. DEAD quiet in single coil settings. I haven't tried the trim pots, which adjusts how much the circuit quiets, to see if the tone is affected. Sounds so damn good now, and is silent, so why?
    And overall, I just think it is a stunning looking guitar. Also comes in Trans black, Satin Natural, Trans Buttermilk.
    About the ONLY complaint I have is the 1 5/8" at the nut width. But it tapers to a normal Les Paul width at last fret. And, it IS expensive
    Specifications Valentine
    Model Valentine
    Size - 13-1/4" wide, 1-3/4" thick, 38-7/16" long (33.7 cm wide, 4.5 cm thick, 97.6 cm long)
    Weight - 8 lbs, 0oz (3.63 kg) - varies slightly
    Body Wood - Ash
    Body Finish - High gloss polyester
    Body Colors - Trans Maroon, Trans Black, Trans Buttermilk, Satin Natural
    Bridge - Music Man® Modern hardtail with vintage bent steel saddles
    Pickguard - Shell
    Scale Length - 25-1/2" (64.8 cm)
    Neck Radius - 10" (25.4 cm)
    Headstock Size - 6-3/8" (16.2 cm) long
    Frets 22 - High profile, medium width, Stainless Steel
    Neck Width - 1-5/8" (41.3 mm) at nut, 2-1/4" (56.9 mm) at last fret
    Neck Wood - Select roasted maple neck
    Fingerboard - Select roasted maple neck
    Fret Markers - 1/4" Black Face dots
    Neck Finish - Gunstock oil and hand-rubbed special wax blend
    Neck Colors Standard – Natural with finished headstock
    Tuning Machines - Schaller M6-IND locking
    Truss Rod Adjustable - no component or string removal
    Neck Attachment 5 bolts - perfect alignment with no shifting; Sculpted neck joint allows smooth access to higher frets
    Electronic Shielding - Graphite acrylic resin coated body cavity and aluminum control cover
    Controls - Custom Music Man® active preamp; push/push volume for gain boost, 500kohm push/push passive tone for custom spilt pickup configurations - .022µF tone capacitor
    Switching - 3-way lever pickup selector
    Pickups - SH - Music Man® custom wound staggered pole piece single coil (bridge) and humbucker with chrome covers (neck)
    Left Handed -No
    Pics don't do the beauty of the neck wood justice, ah well
    Lloyd_m, Malikon, danohat and 14 others like this.
  2. Seven
    Seven Silver Supporter
    2,965
    5,631
    Sep 9, 2009
    Dude that is sweet! :dude:
    cybermgk likes this.
  3. cybermgk
    13,466
    17,679
    Jul 7, 2011
    Some Review Vids
  4. mmd
    mmd Senior Member
    2,426
    2,344
    Sep 24, 2012
    Congrats. That is an AWESOME guitar!!!!!
  5. HeartString
    HeartString Slag Eater Premium Member
    10,109
    32,398
    Jan 20, 2013
    Music Man guitars are the bomb!!! HNGD!! She's a beauty!!
  6. truckermde
    truckermde Senior Member
    14,122
    17,118
    Oct 21, 2012
    Oh, kikass!!
    HNGD :cheers2:
  7. HeartString
    10,109
    32,398
    Jan 20, 2013
    This is the sweeetest intro to a Demo I've ever heard.
    endial and cybermgk like this.
  8. Victek
    Victek Senior Member
    1,293
    468
    Mar 4, 2013
    That's a fine looking guitar :) Really nice blend of color and natural wood finish.
    What's the deal with having staggered pole pieces on the bridge pickup? :hmm:
    HNGD :thumb:
  9. Frogfur
    Frogfur Senior Member
    15,566
    25,486
    Jan 18, 2013
    Holly Cow cyber! That is sweet! I like that.
  10. cybermgk
    13,466
    17,679
    Jul 7, 2011
    It's a slant Single Coil in HB container. Also has individual magnet slugs, compensated for radius.
    Victek and Frogfur like this.
  11. Frogfur
    15,566
    25,486
    Jan 18, 2013
    All that stuff inside..wow that is neat.
  12. Victek
    1,293
    468
    Mar 4, 2013
    Interesting; does it alter the tone much compared with the usual p/u with pole pieces that are straight across? :hmm:
  13. cybermgk
    13,466
    17,679
    Jul 7, 2011
    Remember, it's a Single Coil pickup. It's a just like a Tele that does the same thing (or a Night hawk with the slant HB split.) EB and Valentine did that so that the Bridge had a Tele tone. Now, 'they' say, Leo did it originally on Telecasters (and Strats) to get thicker bass tones (closer to nut, and more pronounced highs, father from the nut.
    DarrellV and Victek like this.
  14. drew365
    drew365 Senior Member
    1,233
    870
    Oct 23, 2011
    Both of your recent NGD's are high on my list of wants. When I first read about the Valantine, it checked all the right boxes for me. What is the neck profile like?
    Concerning the angle of the bridge pup, if I was setting up my own custom build, I'd probably angle it the opposite of what Leo did. Goes to show what I know. That's one nice thing about my Variax and the workbench software, is you can play with stuff like that without a router involved. Great time to be an amateur guitarist.
  15. DarrellV
    14,590
    28,142
    Nov 1, 2016
    Way to go Cyber! Break from the crowd, explore new worlds, all that good stuff!
    HNGD!
    Love natural woods myself, and if i ever get some money ahead, MM is on my list to get!
  16. cybermgk
    13,466
    17,679
    Jul 7, 2011
    Ugh, just noticed you asked this.
    It's C shaped, like most teles. In LP terms it feels a lot like a 59 C neck.
    endial likes this.
  17. frankv
    14,522
    12,899
    Aug 25, 2011
    Well my friend you know how i feel about Music Man. The only guitars I will play or buy. Good luck with yours. Valentine is my next purchase
  18. kevinpaul
    kevinpaul Senior Member
    17,664
    27,233
    Apr 7, 2011
    That is beautiful, one of the nicest guitars I have ever seen.
    danohat and cybermgk like this.
  19. pillbug
    pillbug Senior Member
    867
    582
    May 29, 2013
    Damn, I've wanted one of these since they came out. Afraid to play one because I'll have to buy it. After your post though, I won't be able to pay more than $1100 for one. You scored there.
  20. Niloy63
    Niloy63 Senior Member
    152
    120
    Feb 8, 2013
    HNGD! That roasted maple neck is stunning. I have a buddy who raves about those Music Man pickups. I wonder what output they're rated at and what magnets they use.
