New Replacement Bridge
Discussion in 'Vintage Les Pauls' started by jrawjraw, Jun 27, 2017.
  1. jrawjraw
    jrawjraw Junior Member
    1
    0
    Mar 29, 2017
  2. VictorB
    VictorB Formerly LZF Super Mod
    33,570
    67,169
    May 31, 2007
    This wouldn't happen to be your company, would it?
    radiomatts, Droog, Thermionik and 3 others like this.
  3. stilwel
    stilwel Senior Member
    202
    342
    May 19, 2009
    I saw this just today. Actually looks very interesting and they have some heavy players on board
  4. stilwel
    202
    342
    May 19, 2009
    Has anyone tried one of these Stud Finder bridges?
  5. deadlyweasel
    deadlyweasel Silver Supporter
    1,505
    1,149
    Mar 25, 2011
    Looks like an ugly version of Dan's mojoaxe bridge....
  6. stilwel
    202
    342
    May 19, 2009
    The additional material that makes contact with the treble-side stud makes sense to my engineering brain. Also curious about the offset string holes which allegedly put the strings directly over the pickup pole pieces. I have Mojoaxe bridges on both of my Specials. Strings are aligned fine on my '59, but they're way off on the '74.
  7. Thermionik
    Thermionik Senior Member
    11,038
    33,074
    Jan 20, 2010
    When you say "Dan's mojoaxe bridge...", is the implication that "Dan" of MojoAxe is around MLP at all?
    If he is, I want to shake (metaphorically) his hand. My '52 was excellent before I fitted a MojoAxe.
    But after fitting it, playability and sound became sublime. What an astonishingly good product :applause:
    RevWillie, ehb, RAG7890 and 1 other person like this.
  8. bufbills
    bufbills Senior Member
    3,920
    2,080
    Feb 26, 2009
    Danelectro is Dan. Great product!!
    deadlyweasel and Thermionik like this.
  9. Thermionik
    11,038
    33,074
    Jan 20, 2010
    gedoudahere...
    I had no idea, not a clue (even in the name)
    @Danelectro - man, big, big, big, big, big, big thanks and respect.
    A great product which does a great job.
    ehb and deadlyweasel like this.
  10. deadlyweasel
    1,505
    1,149
    Mar 25, 2011
    Thatbis because in the early 60s gibson moved the bridge studs and went to the lightning bolt style bridge.
  11. lewis_grey
    lewis_grey Senior Member
    278
    242
    Jan 11, 2010
    Looks like a development of the Mojoaxe concept, further sacrificing the vintage correct look to have more metal to metal contact at the studs.
    I have the Mojoaxe on my ‘56 Special and am happy with the balance between aesthetic and improvement in intonation and tone, but I do have it raked out fairly on the treble side still and I can see the possible benefit of this design...I’d like to see how it looks on a vintage wrap tail Gibson.
    stilwel likes this.
  12. stilwel
    202
    342
    May 19, 2009
    I agree, the design changes make sense to me. I'm surprised this hasn't gotten more traction here.
    Did you watch the video? Tom Bukovac (Nashville session player) has one on a mid 50's Jr. Looks fine to me.
    lewis_grey likes this.
  13. lewis_grey
    278
    242
    Jan 11, 2010
    Ah yes, just saw that. It certainly isn’t an eye sore but it’s more obvious than the Mojoaxe. I think if I didn’t have the Mojoaxe I’d certainly consider this but I highly doubt there’s going to be enough difference between the two to justify the purchase for me.
  14. stilwel
    202
    342
    May 19, 2009
    I have the Mojoaxe CWT on both of these, the 59 is aligned pretty well, but the 74 is way off.
  15. Kris Ford
    Kris Ford Senior Member
    4,754
    4,056
    Dec 17, 2011
    ..you guys mean a Leo Quan Bad Ass isn't the answer?
    :iough:
    (It CERTAINLY was at one time..FACT)
  16. ehb
    ehb Chief Discombobulator Gold Supporter Premium Member
    27,160
    123,464
    Feb 20, 2013
    Redoing an early sixties Melody Maker and ordered a bridge from Dan...
    Thermionik and deadlyweasel like this.
  17. stilwel
    202
    342
    May 19, 2009
    I have a Stud Finder enroute...should be here Friday. Will report back in with my thoughts.
  18. zombiwoof
    zombiwoof Senior Member
    384
    290
    Feb 24, 2008
    The '74 may do better with a Lightning Bar bridge, since the angle is almost straight. Either that or a good adjustable bridge/TP.
    Al
  19. stilwel
    202
    342
    May 19, 2009
    Actually it’s not very straight. I have the set screw turned in quite a bit. The bridge is hardly making contact with the stud.
  20. stilwel
    202
    342
    May 19, 2009
    MojoAxe string alignment on my '74 LP Special
    Note how the ball ends are offset from the string path & pole pieces.
    Music City Bridge string alignment on '74 LP Special
    Note how strings align with pole pieces.
    Bridge leans a bit in the Mojoaxe posts, but I had the same problem with the Mojoaxe bridge.
    The lower profile of the MCB required me to raise the bridge studs a fair amount but once I got it up where it needed to be it setup easily and intonated just great.
    I'm really happy with the purchase.
    FWIW...I also have a Mojoaxe CWT on my '59 LP Special and it works great on that guitar. Strings are aligned with pole pieces just fine and it sits perfectly in the original bridge studs without any leaning. I'm planning to leave the Mojoaxe bridge on that guitar. If it ain't broke, don't break it.
