NEW MGL50 Amp NOW AVAILABLE!!
Discussion in 'Mark's Guitar Loft' started by markguitar, Oct 31, 2016.
  1. markguitar
    markguitar MLP Sponsor
    1,038
    2,532
    Mar 31, 2007
    I am now taking orders for the new MGL AmpWorks Lead Master 50 head. Below is the description for the amp. The head is available in either a tolexed Baltic Birch head cab at $2,700.00 or hardwood cab at an upcharge of around $300.00(I have a few being made right now and won't know the exact charge until they are done). A number of tolex colors are available: black, purple, dark green, white, cream(Swanson Cabinets had a roll of cream made for them and it looks like the creamy white that was used on the Plexi era Marshalls). There will also be a matching tolexed 2x12" speaker cab available loaded with Celestion 25w greenback reissue speakers for $800.00. Amp heads and speaker cabs will be made to order and will require a deposit.
    As some of you know, last year I did a run of 20 MGL heads with Greg Germino and they were great amps. But after the 20 Greg decided that he just didn't want to build master volume amps and so that was the end. And I completely respected his decision if his heart wasn't in it. I continued to be contacted by interested customers over the next few months. So about 5 months ago I decided to do a new version of the amp myself along with some long time local friends. First is Guy Harvey who has been building amps on the side for local customers for years and he will be doing the actual builds. My other friend, Evan Cantor, who was half owner and designer for Bedrock amps years ago has been a great help and advisor. Another long time friend and guitar player is a furniture and cabinet builder so he will be making the hardwood head boxes. And Jeff Swanson of Swanson Cabinets will be making the tolexed head boxes and matching speaker cabs.
    The amp is based on my personal Marshall 2204 that I've owned for over 20 years. My amp has always had lower voltage than a typical amp from that period and it has a lot to do with the warmer, fatter and creamy tone that it has. Between my store and personally I've probably had about 75 of the JMP 50w master volume heads and none of them had the voice of this amp. We spent endless hours choosing parts and listening side by side with my original amp. we sourced a lower voltage mains transformer which is producing within a few volts of specs of the original. Listened to a number of the top replacement 784-139 output transformers and decided to use the hand wound Chris Merren version which will be stock in the amp. Chris makes amazing sounding transformers! I had a local metal shop help with the layout and then make custom .090" aluminum chassis with welded and finished ground corners. Then another local business took care of black powder coating and silk screening. The Metropoulos "Zero Loss" effects loop comes stock along with a couple of other extra switches. The mini switch on the front next to the preamp knob allows you to remove the .001 cap on the preamp pot from the circuit. The "Voicing" switch on the back allows you to choose between 2 different negative feedback resistors. The "Classic" position voices the amp like my original and in the "Modern" position it gets a little more aggressive, brighter and a bit more gain. all hand wired and all made locally right here in New Hampshire. Amps will come with reissue Mullard EL34 power tubes and NOS Chinese 12AX7 preamp tubes. I have added a few pictures of the completed circuit and the hardwood head box. Here's a build component list: Custom made .090" aluminum chassis that is powder coated gloss black and then silkscreened with metallic gold ink, Low voltage mains power transformer, hand wound Merren Audio output transformer, mil spec teflon coated 18 AWG stranded silver plated copper wire, JJ filter caps, NOS Amphenol power tube sockets, Belton preamp tube sockets with gold anodized shields, PEC 2W mil spec pots, 9 SoZo caps and 1 Mallory, mostly 1w carbon film resistors, real UK Cliff jacks, Metropoulos "Zero Loss" effects loop, gold plated and knurled brass knobs. Also will be working on a number of various sound clips.
  2. THDNUT
    THDNUT Senior Member
    15,391
    21,702
    Feb 5, 2012
  3. RAG7890
    RAG7890 Premium Member
    14,653
    23,301
    Jul 11, 2010
    :wow: :wow: :wow: :thumb: :applause: :applause: :applause: :applause:
    Good luck with this project Mark.
    Cheers, Rudi
  4. markguitar
    1,038
    2,532
    Mar 31, 2007
    Thank you Rudi!
  5. freebyrd 69
    freebyrd 69 Silver Supporter Premium Member
    10,377
    18,399
    Sep 29, 2011
    Awesome Mark. I hope your wife is doing well too! :thumb:
  6. Fiftywattmafia
    Fiftywattmafia Senior Member
    5,920
    8,646
    Dec 18, 2007
    Amazing! Just unreal. Want.
  7. NHTom
    NHTom Senior Member
    669
    793
    Jun 7, 2014
    Got to check one out in person today and all I can say is WOW!!!!
    Just an amazing sounding amp.
    All the incredible sound of the 2204 it was created after with a couple modern features ("Voicing" switch on the back , cap switch on the front, Metropolus loop, etc) in a beautifully made chasis and head box.
    Really blew me away and I was especially impressed with how well it maintained it's tone even at truly low volumes.
    The controls on it are perfect........Get the sound you want and still tons of adjustment left up or down for certain guitars/rooms/etc. I see this being a very versatile amp with great tone on tap.
    NHTom
  8. Crotch
    Crotch Support MLP Veterans & Vendors Double Platinum Supporter Premium Member
    13,859
    22,556
    Jan 13, 2012
    Beautiful work Mark. GL
  9. chupe442
    chupe442 Confused as ever..... Premium Member
    3,125
    2,578
    Feb 2, 2011
    Wow... Nice!!
  10. markguitar
    1,038
    2,532
    Mar 31, 2007
    This will be MGL serial number "001" for a good friend in custom cream tolex. Matching 2x12" speaker cab also on order.
  11. NHTom
    NHTom Senior Member
    669
    793
    Jun 7, 2014
    I loved the simplicity of the black one, but man that cream one is SO tasty!!!!!
    NHTom
  12. markguitar
    1,038
    2,532
    Mar 31, 2007
    Thanks for the patience all. Still dealing with my poor wife who has been in the hospital for 9 weeks now. Sounds clips are being worked on and will be up very soon!
  13. RAG7890
    14,653
    23,301
    Jul 11, 2010
    :shock:.................gee Mark, really sorry to hear your Wife has been in Hospital for 9 weeks. I hope she fully recovers quickly & that life gets back to normal for you soon. Prayers & best wishes to both of you. :)
    Cheers, Rudi
  14. Curious George
    Curious George Premium Member
    1,335
    1,052
    Nov 23, 2012
    Mark... don't know you but sorry to hear about your wife and hope she is well asap... guessing the other stuff can wait.
    FWIW... amp looks crazy good!
