New and Improved Carve Templates
Discussion in 'Luthier's Corner' started by ExNihilo, Jan 31, 2017.
  1. ExNihilo
    ExNihilo Senior Member
    1,605
    1,756
    Nov 21, 2008
    Yesterday I worked on a new set of carve templates and then began using the new set on a new build.
    Here are the new lines from the templates.
    Once I've routed all the steps, I mark the bottom step with pen to make sure I don't hit it while I sand out the other steps with the orbital sander.
    Then, I start sanding down the steps. I try to do it evenly. Here you see just the corners being knocked off.
    And then a bit more.
    Getting closer. Notice I have just barely hit the bottom step. That is what the pen lines are for, to tell you to stop.
    Now I redraw the pen lines and begin sanding the valley of the recurve area. I start in the center of the bottom step and gradually make it wider until it eventually blends altogether.
    And here is what it looks like when you smooth it all out.
    This is just the first stage of shaping the carve. The second stage happens after I cut the neck and pick up planes. The third stage happens after I put the binding on. And then the last perfecting stage happens just before finishing.
    But, I think it's looking pretty cool after stage one. Love the top on this one. Although, it's going to be a heavier guitar. This body, as it is now weighs 6 lbs 10 oz. (My complete unloaded scrap wood LP weighs 6.11!). I am also very happy with the new and improved template set. If anyone is interested, I will try to make another PDF file of this set when I get time.
  2. D'tar
    D'tar Senior Member
    333
    140
    Sep 23, 2014
    Great looking build there Scott. Thanks for your contributions. I have used your previous templates and looking forward to checking these out.
  3. ARandall
    ARandall Senior Member
    11,521
    6,772
    Apr 16, 2012
    I've taken to making an extra template. Its the biggest one and basically its outer is precisely where you start to sand into the scribblings.
    I rout this extra step a bit shallower.......as in the outer perimeter is the same but there is a shallow step halfway and the 'official' largest template is now a shallower step.
    I was finding with the steps as shown above I was struggling to remove that lowest step without a trench. The extra template for me seems to soften the transition into the recurve much more easily.
  4. SlingBlader
    SlingBlader Premium Member
    268
    191
    Dec 7, 2013
    Thanks for posting this, Scott!
  5. Skyjerk
    5,432
    6,140
    Feb 9, 2014
    That's exactly what I did with my own first LP build. And I mean exactly :)
    Used Scott's templates and made one more that extends halfway between Scotts largest and the outer edge. I prefer to have little-to-no recurve and a gentler overall flow to the carve.
    Of course I'm not looking for anything resembling vintage accuracy
  6. timgman
    timgman Senior Member
    1,774
    385
    May 6, 2008
    I'm certainly interested in the pdf's
    Great work and thank you for your contributions!
  7. ARandall
    11,521
    6,772
    Apr 16, 2012
    Funnily enough my mod was to make it easier to get the right vintage recurve.
  8. pshupe
    pshupe Senior Member
    3,268
    2,112
    Jan 19, 2012
    Me 2! -
    Cheers Peter.
  9. hdoilcan
    hdoilcan Member
    73
    7
    Sep 20, 2011
    Very nice. Thanks for sharing.
    I'm also interested in the new pdf's.
  10. JKHamby
    JKHamby Junior Member
    11
    0
    Mar 17, 2017
    + 1 on the top carve templates.
    Please let me know if there is a cost I will be glad to pay for the excellent work you did, ExNihilo.
    I really appreciate the trailblazing.
  11. bhmcintosh
    bhmcintosh Les Pauls, Telcasters, and 12strings Premium Member
    381
    228
    Apr 20, 2009
    Aw, I just made a set to the old drawings! :) How different are the new guys? Just straighter across the upper bouts?
  12. gsd903
    gsd903 Junior Member
    1
    0
    Apr 19, 2017
    What are the chances of getting a set of those carving templates? Would gladly pay.
  13. ARandall
    11,521
    6,772
    Apr 16, 2012
    The 'ex nihilo vintage burst build' thread has the original templates on them as a pdf which prints full size.
    The newer template pattern simply doesn't fan out on the neck side of the waist......just use the pics above to see where the steps are.
  14. VancoD
    VancoD Junior Member
    23
    38
    Jan 26, 2016
    Forgive my ignorance - but what are folks using for these routes? A standard 1/2" or 3/4" straight pattern bit?
  15. nuance97
    nuance97 Premium Member
    2,164
    1,218
    Feb 26, 2009
    Either
    VancoD likes this.
  16. kylerj133
    kylerj133 Member
    64
    7
    Sep 22, 2010
    any chance you got this into a pdf? I would really like to have these even if I had to pay!
  17. Brewdude
    Brewdude Senior Member
    937
    1,772
    Jun 26, 2014
    Hope this works!
