New Amp Build: V2 Caldera
Discussion in 'The Squawk Box' started by V2, Mar 6, 2016.
  1. V2
    V2 V.I.P. Member
    2,233
    2,424
    May 30, 2011
    The amp sports a pair of EL34s (or whatever big-bottle octal tubes you desire) running in push-pull with a transformer set that delivers only 10-15W of power. Kind of like a hard-wired power scaling. :)
  2. V2
    V2 V.I.P. Member
    2,233
    2,424
    May 30, 2011
    OK, I just tweaked the power amp a bit after the OT swap. Now the amp sounds HUGE. I think I'll have to listen to this "little" 15W amp next to some 2xEL84 amps, like the Friedman offerings. I'm sure the Friedmans will sound amazing, but I can't see how they will match this Caldera in the low-end grunt.
  3. cherrysunburst00
    cherrysunburst00 Senior Member
    13,722
    23,853
    Mar 15, 2015
    OK, I just reread the thread (hey, it rhymes!). I didn't realize when you alluded to a second one, that it was totally different--ie, 50 watts vs 10-15 watts.
  4. V2
    V2 V.I.P. Member
    2,233
    2,424
    May 30, 2011
    Yeah, the earlier posts were about the 50W Caldera, but recently I built (and posted about) a 15W version. The preamp is similar in the low-power model, and 2xEL34s are in both the low power model and the 50W model.
    Here's a very short snippet of the 15W Caldera, recorded with an iPad. Keep in mind that I can't play, record, or use an iPad. :)
    [SC]https://soundcloud.com/v2-jmcd/caldera-15w[/SC]
  5. cherrysunburst00
    13,722
    23,853
    Mar 15, 2015
    Very nice. There was a 10 second snippet and then a 44 or so second clip titled "V2 Cutter Sample 3". Was that the 15 Caldera? It appeared to be labeled as such, but I thought to verify.
    Any idea of the dbs? If not a specific db rating, how about a point of reference like "normal conversation speech" ?
    I'm now headed over to see if I can find your build thread on this 15 watter.
  6. V2
    V2 V.I.P. Member
    2,233
    2,424
    May 30, 2011
    - The V2 Cutter was a different amp (my 10W Phaez Daisycutter).
    - Unfortunately, there's no build thread on the 15W Caldera.
    - about 100 dB, measured 3 feet in front of the speaker cab.
  7. V2
    V2 V.I.P. Member
    2,233
    2,424
    May 30, 2011
    Another short clip:
    [SC]https://soundcloud.com/v2-jmcd/caldera-gold-unchained[/SC]
  8. Marshall & Moonshine
    Marshall & Moonshine Senior Member
    20,483
    34,698
    Jul 21, 2010
    Those sound cool! I bet that amp is so fun. :)
  9. V2
    V2 V.I.P. Member
    2,233
    2,424
    May 30, 2011
    A tale of two tube amps. Same overall topology but with different tunings. Top amp has a more vintage tone (ballpark of a JCM800, but with more versatility); bottom amp has a more modern tone (but still not too gainy). Eventually, I'll pick a design (currently favouring the more vintage one) and let these 'prototypes' go.
    BlueCajun likes this.
  10. Marshall & Moonshine
    20,483
    34,698
    Jul 21, 2010
    Fwiw, I'm all about the vintage version, from a 2204 owner's perspective. That way, I can step on a boost of my liking to goose it further up from what I consider to be "high-medium gain". It's a wildly different sound, between my Beano Boost and my CompCut pedal. I don't know that the difference would be as pronounced with a higher gain platform, but with that much gain on tap, maybe you wouldn't need a boost, although it would give up a little versatility. I guess it depends on what people want.
    My 2204 isn't the gainiest amp in the world, but it covers everything, from country to blues to classic rock, no problem. I can't speak for modern metal/rock as I don't play any.
    V2 likes this.
  11. V2
    V2 V.I.P. Member
    2,233
    2,424
    May 30, 2011
    I built the vintage version after I built a Ceriatone 2204. I really liked the tone, and so I wondered if I could get the Caldera into that ballpark with minimal tweaking. I think it turned out well. I can still flip the punch switch for some added gain (particularly useful when in the lower-gain mode). Anyway, I think it sounds pretty darn good.
  12. V2
    V2 V.I.P. Member
    2,233
    2,424
    May 30, 2011
    two Calderas have been listed in the classified section...
  13. Soul Tramp
    Soul Tramp Speaker Snob V.I.P. Member MLP Vendor
    6,472
    14,874
    Jul 19, 2012
    Outstanding! nice work, V2.
    RAG7890 and V2 like this.
  14. V2
    V2 V.I.P. Member
    2,233
    2,424
    May 30, 2011
    Thanks, Don. I think I'll make a 20W Caldera with 6V6s next...
    ac/dcfan87 and RAG7890 like this.
  15. Soul Tramp
    6,472
    14,874
    Jul 19, 2012
    I took my EL84 Tremor and redesigned it with 6V6 tubes and additional gain stages. It is much nicer!
    The Beam Tetrodes are just smoother sounder than the Power Pentodes, and they don't suffer the nasty 3rd order harmonics when spiked.
    My guess is that you'll be very happy the 6V6 tubes.
    RAG7890 likes this.
  16. RAG7890
    RAG7890 Premium Member
    14,083
    22,020
    Jul 11, 2010
    ........Don & John. :love:
    :D
    The Calderas look great. :thumbs: :applause: :applause:
    :cheers2:
  17. V2
    V2 V.I.P. Member
    2,233
    2,424
    May 30, 2011
    Thanks guys.
    RAG7890 likes this.
  18. V2
    V2 V.I.P. Member
    2,233
    2,424
    May 30, 2011
    So this past year was chaotic, and I didn't have much time to play or build. One of the Calderas - the one with chicken-head knobs - sat atop of my 2x12 speaker cab, so it was my go-to amp whenever I did have time to play. Yesterday, I plugged into the other Caldera (with the Davies 1510 style knobs that are on a bunch of amps these days). Wow it sounded great! Super tight low end, and a very focused tone with no hint of fizz. I didn't think much of it until I opened up the chassis to do some final cleaning of the parts board. At that point I realized/recalled that this Caldera was different than the other one! This one is closer to the usual Jose-type amps, especially the Friedman Smallbox. (although the Caldera has a little less gain on tap than most of these amps). With the preamp gain at 3:00 and the volume/master at 9:00, it is KILLER.
    ac/dcfan87 and matthew bear like this.
  19. ac/dcfan87
    ac/dcfan87 Senior Member
    1,889
    1,425
    Feb 5, 2013
    Hey V2 - any clips of the Caldera? Maybe I missed it?
    By the way great work my friend. Keep it up. Love to see people with a passion like yours. It's quite evident.
  20. V2
    V2 V.I.P. Member
    2,233
    2,424
    May 30, 2011
    Thanks for the kind words!
    No published clips yet, but I'm hoping to get some from some local guitarists who like the amp and want to play it some more... :)
    I did make a crappy recording of some crappy playing of the 10W Caldera. But my crap won't help sell amps :)
