Need some guidance with my next pickups
Discussion in 'Pickups' started by ccrandall88, Aug 23, 2017.
  1. ccrandall88
    ccrandall88 Member
    34
    22
    Sep 15, 2013
    Hey all. I'm looking at replacing my pickups in my 2013 LP standard. I'm a bit torn between a pair of Pearly Gates, 57 Classics, or BK Mules. What I'm really looking for is something that has some great touch sensitivity. I want something that has a vintageish voice, will respond to how soft or hard I'm playing, and have some sizzle to it. I have narrowed down it down to those 3, but am having a hard time deciding. Does anyone have any pointers or recommendations? Currently I have a WLH set in, and, they just arent doing it for me. They are great pickups but they have a tendancy to sound a bit flat and muddy to my ears.
  2. scovell001
    scovell001 Senior Member
    196
    97
    Sep 3, 2015
    All solid choices, I would probably go pearly gates if it were me, but the 57 classics can certainly turn on the juice as can the bk mules
    ccrandall88 likes this.
  3. ccrandall88
    ccrandall88 Member
    34
    22
    Sep 15, 2013
    Thanks! Ya I'm leaning Pearly Gates as well, but its a little nerve wracking having never played a set. I've listened to a bunch of videos, but what I'm most concerned about is the "feel." The best pair of pickups I've ever played had this amazing touch response. When I played soft, they cleaned up so well, and when I dug in, they had an amazing sizzle. I was dumb enough to not figure out what the hell they were :\
  4. Bobby Mahogany
    Bobby Mahogany Senior Member
    19,785
    28,227
    Feb 25, 2012
    A no-nonsense easy choice is Seymour Duncan's '59s.
    I personally don't like the "sizzle" (for lack of a better word) of the Pearly Gates.
    The '59s are pretty versatile for a good variety of tones.
    Still, if you go for the Pearly, consider a '59 for the neck.
    But as with everything, to each his own!
    :D
  5. Antigua
    Antigua Senior Member
    504
    150
    Oct 15, 2016
    IMO, you lose those qualities when you trade in an AlNiCo 5 for AlNiCo 2 (or AlNiCo 4), but they're also qualities that are much easier to achieve with the settings on your amp or gain pedal, that being "sizzle", touch dynamics, etc. Pickups lean a certain way, but the gain stage between the guitar and speaker are most responsible for that.
    That being said, thw WLH is a slightly hotter PAF with AlNiCo 5, so if you were going to change the pickups to trend away from a muddy tone, the SH-1 '59 set is the next logical step.
  6. ccrandall88
    ccrandall88 Member
    34
    22
    Sep 15, 2013
    Thanks for the input! In my (very limited) pickup experience I assumed the opposite, that you lost those qualities with an AlNiCo 5 and gained them with a 2 or 4. And I totally hear you on the amp part. I think my issue is the WLH has always had this muddy quality to them I don't love. That's not to say they aren't great pickups, they totally are, but for me I haven't been able to shake the feeling that they are lacking.
  7. Stuff
    Stuff Senior Member
    639
    622
    Jul 28, 2013
    I've not had a lot of success with SD pups for touch responsiveness. The sets I've tried have either had no sizzle, or a lot of compression when compared to other PAF-like sets. The only set of Classic 57s I've had were unpleasant - an emphasis in the highs rather than the upper mids, making them harsh and ice-picky.
    I've recently put a set of BK Rebel Yell pups into an all-mahogany LP copy, and been very impressed with them. I'm more likely to try a set of BK Mules as a result.
    HTH
  8. chunktone
    chunktone Member
    78
    21
    May 11, 2011
    I'd go with the BK's, but it's kind of an apples to oranges comparison imo. The BK's are twice as much as SD's, but if that's not a concern, then I'd go with the BK's. There are plenty of other brands that are great, but that's a topic for another time.
  9. northernguitarguy
    northernguitarguy SWeAT hOg
    27,479
    44,729
    Feb 22, 2009
    IMO, 57 Classics have the sizzle of warm yogurt. Personally, I think OP should go the 'boutique' route. And as usual, I'm going to recommend Vineham Pickups. At $65USD for a custom wound pup, how can you go wrong?
    http://www.vineham.com/humbucker_pickups.html
    Rhust and bulletproof like this.
  10. Jymbopalyse
    Jymbopalyse Senior Member
    2,133
    4,402
    Oct 3, 2016
    57 Classics are a great pickup but I don't think they will have the sizzle you are looking for. The 57's IMHO are great for clean and shine at doing that.
    I was looking at the PG not so long ago. I ended up with a T-Top clone that is simply SPECTACULAR !!! I think they would be a good fit for you, and a fraction of the cost! Here is the thread
    http://www.mylespaul.com/threads/npd-vineham-6070s-finally.393873/
    Northernguitarguy (above) actually turned me on to the Vineham Pickups.
    It's worth a look.
    northernguitarguy likes this.
  11. Wizard of Ozz
    Wizard of Ozz Senior Member
    112
    74
    May 6, 2011
  12. ARandall
    ARandall Senior Member
    11,796
    7,188
    Apr 16, 2012
    I've had sizzle with all mag types. Quite frankly for those experienced in winding pickups (and once you have experienced a variety of pickups and swapped mags in them) it is clear that the wind is by far the more important element.......something repeated many times here on this forum by those who actually wind pickups for a living.
    Adding to the Vineham recommendation, I'd put in Tysontone and Sigil in there too as affordable options - especially if BKP's are in the budget.
    bulletproof likes this.
  13. ccrandall88
    ccrandall88 Member
    34
    22
    Sep 15, 2013
    Wow, thanks all for the great input, lots to chew on here! Cost is def not much of a factor (within reason). I think at this point I've taken the 57s out of the running. They sound good but after everything I've read and listened too, I don't think they are exactly what I'm looking for. I'm leaning towards the PGs now. I suspect the Mules might be better, but I get the impression that the cost you're paying vs the upgrade in quality is pretty negligible.
  14. Playforfun
    Playforfun Member
    93
    114
    Feb 10, 2014
    Suhr Doug Aldrich will get you there
  15. Starman
    Starman Senior Member
    227
    129
    Mar 16, 2014
    If you have the extra $$ the SD Custom Shop Pearly Gates set is phenomenal.
  16. Jock
    Jock Senior Member
    128
    84
    Jul 9, 2010
    Be prepared to try a few, the wood makes all the difference. Take time and try as many as you can, after a few years I settled on a SD Jazz because my guitar was darker sounding than my other one. Both the same maker both the same model, only difference was the weight.. over 1lb difference. One worked with Seth Lovers the other did not. I used a 57 and a Pearly gates and a Seth but util I put in the Jazz it was always too dark. Now it sings.
  17. RayTorvalds
    RayTorvalds Senior Member
    1,066
    878
    Apr 29, 2015
    Amber Spirit of 59. No affiliation with the company but I think you might like those from what you describe you're looking for. Those are actually made by Wolfgang van Damm who designed the Gibson P94 when he was still working for Gibson.
    They sound amazing.
    http://www.amberpickups.com/index.php?hb#
  18. grayd8
    grayd8 Senior Member
    1,370
    1,107
    May 5, 2014
    Your list of desired features describes a set of Ox4 low winds, at least in my experience.
  19. MW110
    MW110 Junior Member
    13
    6
    Nov 2, 2016
    Hey cc, l don't know your budget and I don't want to open a new can....but I think Throbak pups would do the job perfectly. Look at those to get an impression.
  20. AJK1
    AJK1 Senior Member
    698
    221
    Apr 19, 2014
    Totally
    But most youngsters here won't buy them as they have no money
