Need help with using proper Line 6 DL4 Power supply
Discussion in 'Pedals' started by lespauldawg, May 5, 2017.
  1. lespauldawg
    lespauldawg Senior Member
    806
    188
    Nov 23, 2014
    I was hoping I could get some help with this problem.
    I recently bought a Line 6 DL4 without a power supply so, I need advice how to power this sucker up without causing damage.
    I have a DC Brick power unit, I read using a certain adapter can be used.
    If anyone has experienced this issue it would be great to hear from you.
    below are the DC Brick specs:
    • 7 - 9V and 3 - 18V outputs Powers up to 10 pedals Fully regulated 1,000mA power Special circuit protection against shorts and overloads
    thank you
    LPD
  2. pillbug
    pillbug Senior Member
    871
    584
    May 29, 2013
    Hey man, I just looked at mine and it is 9v AC 1000ma and says Line 6 made in China. I'd recommend checking with Line6 if this can be bought as a replacement part from them, or else just use batteries.
  3. tzd
    tzd Senior Member
    5,590
    3,427
    Oct 21, 2011
    pillbug likes this.
  4. stryker59
    stryker59 Senior Member
    3,441
    92
    Sep 8, 2007
    a godlyke powerall will power with the adaptor they have for it
  5. Mr Alarm
    Mr Alarm Senior Member
    151
    36
    Sep 10, 2013
    I struggled with the same problem once. Then I soldered a 9Vbattery clip to the DL4's battery department so that I could give it DC power thru it. Many power supplies have a battery clip adaptor, use it. I remember 9V DC were ok. If the Amperes are right...
