Need help mounting a P90 sized humbucker.
Discussion in 'Luthier's Corner' started by Rocco Crocco, Nov 7, 2017.
  1. Rocco Crocco
    Rocco Crocco Senior Member
    6,648
    7,961
    Feb 8, 2013
    As you see, the P90 has two mounting screws in the middle of the pickup.
    I am installing a DiMarzio that has the mounting holes toward the outside, like so...
    The issue I see is that one of the screws to mount the pickup will go through the wiring channel, which is fairly deep. Similar to this (obviously this is a humbucker route, but the channel looks to be the same).
    Is the right thing to do to glue a wood block in the channel, or try to get an extra long screw that will reach the bottom of the channel so I can grab some wood?
    I don't have the pickup yet so I don't know how long the screws are that come in the package.
  2. cybermgk
    13,884
    18,605
    Jul 7, 2011
    Those are Humbucker routs on the guitar? If so, they won't be long enough, and too wide for the P90 sized humbucker. And if so, why would you get a p90 sized pickup to begin with?
  3. ARandall
    ARandall Senior Member
    12,092
    7,578
    Apr 16, 2012
    I thought the same....but re-read and think he's just using the humbucker rout pic as a similar illustration.
    You might have to play it by ear (sorry, bad and slightly obscure pun) when the pickup gets there. P90 screws are quite long usually, and may reach.
    Rocco Crocco likes this.
  4. Rocco Crocco
    6,648
    7,961
    Feb 8, 2013
    The pic is an example. I acknowledged that it is a HB route in the OP. The guitar in question is a Doublecut Special with P90s.
  5. Rocco Crocco
    6,648
    7,961
    Feb 8, 2013
    Good to know. Hopefully they'll be long enough.
  6. ARandall
    12,092
    7,578
    Apr 16, 2012
    The issue I see is that for any extra bit of wood to not split when putting a screw through, it needs to have a certain dimension to it - so hopefully there is space to get wires around that. The second issue is that with a finish on the wood you would need epoxy for your glue.
    The alternative is to find/fabricate a metal insert like the LP Tributes have. This would sit a machine screw thread at rout base depth rather than the channel.
  7. Rocco Crocco
    6,648
    7,961
    Feb 8, 2013
    Actually there is already a metal insert in the route. There's no screw hole in the desired location now, though. Your post has me thinking... I wonder if I could just drill a hole ever so slightly smaller than the mount screws and let the screw tap the threads. I'm just worried I'd screw (pun intended) it up.
  8. efstop
    efstop Senior Member
    2,605
    5,538
    May 30, 2015
  9. Rocco Crocco
    6,648
    7,961
    Feb 8, 2013
  10. charisjapan
    charisjapan Silver Supporter
    1,558
    1,493
    Jul 10, 2011
    But the DiMarzio P90 humbucker mounting screw pitch is very close to those of a mini humbucker.
    Good chance that 1/10th of an inch is not a problem ... in fact, some mini humbuckers are exactly the same dimension, so that mounting bracket could be a great solution to your problem.
    The DiMarzio is 2.925”.
    Cheers!
    mux164 likes this.
  11. Rocco Crocco
    6,648
    7,961
    Feb 8, 2013
    Thanks chris and efstop... I will look into that bracket.
  12. The Ballzz
    The Ballzz Senior Member
    1,485
    991
    Mar 28, 2013
    If you have a drill, bits and the skills to use them, why not just make a set of your own mounting brackets. You could start with a strip of 16 gauge sheet metal (considerably thinner than the Stewmac brackets)drill two holes to munt it to the guitar and two other holes to run some sheet metal screws into for the pickup screws. Simple/pimple, easy/peasy! Of course, you'd also need to know how to read/use a ruler!
    Just My $.02,
    Gene
