Need Amp Suggestions
Discussion in 'The Squawk Box' started by guycalleddave, Sep 14, 2017.
  1. guycalleddave
    guycalleddave Senior Member
    157
    29
    Oct 9, 2011
    Type of Music: Classic Rock, 90s Alternative, Blues, Pop Punk, Surf Rock
    My friend is looking for a channel switching amp that is built like a vintage amp in regards to durability of parts and connections. On board spring reverb would be nice, but not necessary. More marshall flavor than fender. Somewhere are 30 or 40 watts.
    Reliability is key. Your suggestions are appreciated.
  2. hbucker
    hbucker Senior Member
    3,638
    1,242
    Oct 15, 2007
    Peavey Classic 30 or Classic 50.
    Rhust likes this.
  3. guycalleddave
    157
    29
    Oct 9, 2011
    I'm going to say that the Classic 30 isn't a reliable amp. I owned one that I modded, it was sweet, but the tubes kept slipping out of their sockets because the parts the use are sub par. This has to be able to hold up to gigging.
  4. Assault Bacon
    Assault Bacon Gold Supporter
    215
    267
    May 3, 2017
    Peavey Classic 50 is a solid amp and very versatile. I owned an early 2x12.
    Might also try a Mesa 5:50 or a Lonestar combo.
  5. Guitaraxe
    Guitaraxe Senior Member
    727
    335
    Aug 22, 2015
    Weird. Did you buy it new? It should have had tube retainers on there.
    Rhust likes this.
  6. ht-57
    ht-57 Member
    56
    77
    Sep 3, 2017
    I'll bite, its a heavly bias opinon
    Marshall jcm 800 50w 2205
    Vintage- check
    Durable- check
    Channel switching- check
    Spring reverb- check
    Marshall flavor- check
    Reliable- well its been crankin for
    27 or so years for me and it survived recording and @ least one tour of the original owner - I say this because the roadcase i
    Got with it has scars from a very caring highlow driver stuffing
    Gear onto a cargo jett
    The_Nuge and Guitaraxe like this.
  7. mmd
    mmd Senior Member
    2,344
    2,183
    Sep 24, 2012
    Rivera R55-12. Built like a tank, killer "fender" clean channel with a boost to drive into a vintage style grit, and a drive channel that will go from low gain to 90s alternative. It also has onboard, footswitchable reverb and an effects loop. It will EASILY do all you listed and is mega quality. They are only on the used market, but you can get a boutique caliber (90s era) amp for under $750. I have seen some well under that price on Reverb. It is only a combo, though.
  8. mmd
    mmd Senior Member
    2,344
    2,183
    Sep 24, 2012
    Oh, there is also a 30 watt version of that Rivera, the R30-12. VERY hard to find, but it is probably the best amp Rivera made during that time period (92-96).
  9. lung plunger
    lung plunger Senior Member
    786
    1,077
    Mar 20, 2017
    There's a few guys out there that will build exactly what you want, even using old hammond transformers and chassis. Frugal Amps and Organdonor are just a few.
    I went with Frugal Amps. Mark built me a Matchless Spitfire clone on a hammond AO44 chassis. It's flat out badass.
  10. Pwrmac7600
    Pwrmac7600 Premium Member
    7,931
    6,136
    Jun 17, 2014
    Gigged a classic 50 head for the better part of 10 years, never had an issue with tubes slipping out. Great amp.
  11. Soul Tramp
    Soul Tramp Speaker Snob V.I.P. Member MLP Vendor
    5,970
    12,962
    Jul 19, 2012
    Soul Tramp Serenity. Hand-wired turret board construction, tube spring reverb, tube buffered parallel/serial FX loop, foot switch controlled channel switching. All the details are on the website and I can provide more as needed.
  12. sibyrpunk
    sibyrpunk Senior Member
    1,389
    523
    May 1, 2010
  13. EndGame00
    EndGame00 Senior Member
    703
    327
    Sep 1, 2013
    Frenzel Amp.
  14. cybermgk
    13,004
    16,677
    Jul 7, 2011
    Frigendorf 50
  15. Dick Banks
    Dick Banks Senior Member
    394
    391
    Apr 27, 2017
    Well, on this forum, it's like asking "what church should I go to." Not that it's a bad thing, you just get LOTS of opinions...
    So I'll jump in--Vox AC30, or AC15 if you like your neighbors...
  16. The_Nuge
    The_Nuge Senior Member
    1,738
    1,150
    Dec 12, 2010
    I'll second the JCM 800 - the 4210 model would be a prime choice :)
    Well built, lots of good sounds and not too heavy!
    I brought mine to the last few gigs we played, and the other band of the evening used it too - he put his own amp back in the car when he heard it :)
  17. The_Nuge
    1,738
    1,150
    Dec 12, 2010
    Oh, if money was no object, I'd get one of Don's SoulTramps :yesway::)
    Rhust likes this.
  18. Rhust
    Rhust Senior Member
    4,871
    2,868
    Jan 9, 2012
    Soul Tramp or Phaez if I was a lottery winner...
    or Mesa
    "aww man my mesa keeps breaking down" - said no one ever
  19. kakerlak
    kakerlak Senior Member
    1,358
    424
    Feb 5, 2014
    Your list of music, especially with surf thrown into the mix really has me thinking more Fender than Marshall. What sort of budget is he shopping? Your note about "built like a vintage amp in regards to durability of parts and connections" makes me think he's looking to avoid cheaper '90s-current stuff with PCBs and those half-plastic jacks that always get knocked inside the chassis. With a need for channel switching, plus point-to-point wiring, you're probably gonna be shopping modern boutique builders and there's a ton of them. Many of them are more focused on strict vintage clones, though. If your friend is just looking for a reasonably reliable, fairly new jack-of-all-trades amp, I might steer him towards a Blues/Hot Rod DeVille.
