Need a solid shaft pot and only have the split type.... worry not!
Discussion in 'Fender' started by 5F6-A, Nov 19, 2017.
  1. 5F6-A
    5F6-A Senior Member
    9,512
    2,035
    Aug 16, 2007
    I came up wtih a trick that worked quite well for me. I needed a solid shat pot and I only had a split shat CTS pot. Uhmm... I could align the gap with the screw but then the knob would not be in the right place. I needed another solution... I decide to fill-in the gap/middle with some card to avoid any movement of the shaft and then place a piece of heat shrink tubing over the shaft to cover the whole thing. Snipped off the excess of the tubing from the top using a Stanley knife and presto! solid shaft is is now. Totally reversible mod too.
    MooCheng likes this.
  2. 5F6-A
    5F6-A Senior Member
    9,512
    2,035
    Aug 16, 2007
    Forgot to mention the last step: applying some heat to the tubing at the end of the process really secures it round the shaft. No wiggle at all.
    The Refugee likes this.
  3. 5F6-A
    5F6-A Senior Member
    9,512
    2,035
    Aug 16, 2007
    Thanks guys!
