Need a LP 50s Wiring Diagram with Independent Volume Controls
Discussion in 'Tonefreaks' started by 52dedhed, Jun 10, 2017.
  1. 52dedhed
    52dedhed Junior Member
    8
    2
    Mar 13, 2017
    I have a 1970's MIJ LP that I want to modify using the '50s style wiring, but with the volume controls independent when the switch is in the center position. I've seen a couple of different versions of this, but so far they aren't working. Does anyone have a DEFINITIVE wiring diagram so I can get the results I want?
  2. ARandall
    ARandall Senior Member
    11,717
    7,044
    Apr 16, 2012
    Stickys on this page have the details.
    They will work.....if not, its your work thats the culprit.
  3. korus
    korus Senior Member
    1,064
    356
    Apr 10, 2007
    And, independent volumes do not sound well bellow 10. No electric guitar should sound like that and that is why you do not see independent volumes on production guitars. But, if you do not hear the problem, enjoy it.
  4. 52dedhed
    8
    2
    Mar 13, 2017
    Well it would be my fault. Thanks!
  5. ARandall
    11,717
    7,044
    Apr 16, 2012
    Have you sorted the issue.
    If not then a pic of the wiring could help find anything obvious.
  6. barchiola
    barchiola Senior Member
    266
    101
    Dec 11, 2008
    I'm pursuing a similar set up, 50's style with independent volumes. Wouldn't treble bleeds on each volume pot fix the tone issues? I assume that's what you're referring to in saying they don't sound well below 10? My old Gretsch was like that, it drove me crazy.
  7. Norton
    Norton Senior Member
    396
    302
    Dec 12, 2013
  8. korus
    korus Senior Member
    1,064
    356
    Apr 10, 2007
    As in Norton's post, here's the video
    Tremendous instant and irrepairable treble loss as soon as volume is rolled off just a bit, and narrow usable range of vol pot. Obvious inherent fault in design overbearing the dubious benefit. Just a learning tool, never to be used on a proper instrument as it degrades it. But, general population plays quiet, through anything but tube amp and does not hear good enough so anything goes, even a dead wrong wiring concept. Hence, we are discussing it although it makes no sense on a proper electric guitar played loud through a tube amp, as originally designed.
  9. barchiola
    266
    101
    Dec 11, 2008
    he explained around 11:25 why it worked on the Gretsch I had, the Gretsch also had a third master volume knob that made the independent volumes work correctly.
    thanks for posting that, very helpful
