Need a little help with static in the amp
Discussion in 'Tonefreaks' started by whomeno, Mar 3, 2018.
  1. whomeno
    whomeno Senior Member
    151
    52
    Nov 21, 2008
    Hi all
    I need a little help with static after an upgrade in electronics, wired it up with the 50's style wiring.
    Now I have quite a bit of static coming from the amp. Looking for some help to get rid of it please.
    The upgrade was done on a gibson 2017 tribute les paul. took out pcb borad and added new pots and wiring.
    Thanks
  2. ehb
    ehb Chief Discombobulator Premium Member
    24,021
    111,326
    Feb 20, 2013
    Touch strings/metal and then clear body from metal. Is there a difference?
    If it doesn't quieten when touched, I would check all grounds.
    I have found 50's wiring to exhibit a slight touch more noise under high gain conditions...
    It is not an issue with me as I do not play with nuclear gain and m hands are usually always touching strings or anchored at top bridge end with heel of hand or fingers...
    As Philbertius is fond of saying, what does it matter once the drummer comes in.....
  3. bulletproof
    10,139
    21,612
    Jun 1, 2011
    +1......this right here
    whomeno likes this.
  4. whomeno
    151
    52
    Nov 21, 2008
    checked all grounds and they are all good. I don't use much distortion. I run clean amp and 4 gain and 5 master vol on my tube monster pedal. it just started all of a sudden.
    bulletproof likes this.
  5. bulletproof
    10,139
    21,612
    Jun 1, 2011
    Okay brother,take a good look at your input jack.....is it constant or intermittent? Does the volume knobs affect it? I.e.,turning up or down causes noise....
    whomeno likes this.
  6. bulletproof
    10,139
    21,612
    Jun 1, 2011
    Forgot to ask as well.....can y’all get pictures of the cavity?
    And please done think I’m being a condescending dick,but,have you ruled out the amp?
    whomeno likes this.
  7. Thumpalumpacus
    Thumpalumpacus Senior Member
    74,918
    181,395
    Nov 28, 2010
    Bad solder somewhere?
  8. whomeno
    151
    52
    Nov 21, 2008
    ok an aswner to the frist question when i touch the stings it gets quit. when I take hand off it gets louder. the sound is constant.
  9. whomeno
    151
    52
    Nov 21, 2008
  10. whomeno
    151
    52
    Nov 21, 2008
    when I turn volume up and down .in the middle at 5 it gets louder
  11. bulletproof
    10,139
    21,612
    Jun 1, 2011
    Okay,so we’ve got ruled out the amp,right? Everything looks as it should it the cavity,so, I have to go with Thump on this. Check all yer solder points to make sure no cold soldering shenanigans are going on.
    For a bit of reference,though....my pickups are not potted at all and do bring on some noise if my hands completely leave the guitar...what type pickups do y’all have in the ole girl?
    whomeno likes this.
  12. whomeno
    151
    52
    Nov 21, 2008
    gibson 490t and 490r here is what gibson says on them
    Tonal & Resonant Advancements: Better Hum canceling w/rev polarity
  13. whomeno
    151
    52
    Nov 21, 2008
    wired up red hot white green together black and bare go to ground
  14. Thumpalumpacus
    74,918
    181,395
    Nov 28, 2010
    Grounding issue.
    Matt_Krush, bulletproof and whomeno like this.
  15. whomeno
    151
    52
    Nov 21, 2008
    I got it!! my fuzz pedal went out. unhooked it and all noise gone.
    Thanks for the help
    Now I feel stupid
  16. bulletproof
    10,139
    21,612
    Jun 1, 2011
    Happens to the best of us,brother!!!! :laugh2::laugh2::laugh2::laugh2:
    JohnnyN and whomeno like this.
