Neck pickup not working
Discussion in 'Epiphone Les Pauls' started by I Break Things, Aug 19, 2017.
  1. I Break Things
    I Break Things Senior Member
    3,493
    6,778
    Nov 27, 2016
    15031592084541452675895.jpg 1503159238072764058598.jpg 15031589794871245395762.jpg So my neck pickup is extremely quiet when I first switch to it, but later goes to full volume after fidgeting with it a bit and it will toggle fine after that initial "break-in" it seems. Can anyone tell me what is causing this and how to fix it? Here are some pictures of the control cavities.
  2. irocdave12
    irocdave12 Senior Member
    2,374
    2,884
    Jun 22, 2011
    My 55 outfit does same thing. Sometimes the neck is super weak when I switch to it. I rock the switch back n forth vigorously and it comes to life. It's a bad switch or dirty contacts.
  3. leifpaul
    leifpaul Senior Member
    952
    482
    Sep 25, 2007
    The switch is junk. Switchcraft should've been standard on epi lp in the highend range.
    C_Becker and fumblefinger like this.
  4. I Break Things
    3,493
    6,778
    Nov 27, 2016
    Seems to be working better now that I've been using it a little more, so dirty contacts seem likely. How would I go about cleaning it safely?
  5. 61LPSG
    61LPSG Senior Member
    1,679
    436
    Oct 31, 2007
    IBT,
    Those switches are shall we say "less than stellar". I been able to fix a few by cleaning the contacts.
    Loosen the switch nut on the face of the guitar- CAREFULLY pull the switch out through the back. There should be enough wire to clear the rout. Check all the solder joints while it's out. Now fold a small piece of wet/dry sandpaper (black) between the contacts and give it a few swipes. Clean with some alcohol or naptha and plug it in and try it.
    YMMV...Good luck.
  6. fumblefinger
    fumblefinger Senior Member
    1,205
    491
    May 10, 2012
  7. C_Becker
    C_Becker Dat Gibson smell
    1,871
    1,753
    Jul 7, 2015
    Typical weak points on Epis - switch and jack are often crappy.
    I have Gibson switches in all my Epis now. They are overpriced, but problem free so far.
  8. VicodinDream
    VicodinDream Senior Member
    219
    82
    Jan 5, 2015
    I'd just replace the switch. Switchcraft has never given me any issues. Except a little lighter wallet. But you get what you pay for.
