Neck Angle / Stop Piece Height
Discussion in 'Gibson Les Pauls' started by Rookie59, Dec 10, 2018.
  1. Rookie59
    Rookie59 Junior Member
    28
    34
    Dec 10, 2018
    968014E2-4367-4136-A696-07B20DB30BDF.jpeg Hi. I have a new 2018 Les Paul and I wanted some opinions on the neck angle and stop piece height. I’ve just set it up and I am kind of concerned about the height I had to adjust the stop piece and even at this height the low E is still slightly touching. Does this seem extreme? I really don’t want to top wrap, I think it’s ugly and spoils the look. I’ve seen a couple other posts for a gotoh piece that looks good - if it’s still available - or are there any other suggestions. Tho didn’t think I’d be looking for a solution like this for a brand new guitar.
  2. Rookie59
    28
    34
    Dec 10, 2018
    8507A6C8-37A6-4B78-983C-E8F76C9B2071.jpeg another pic...
  3. Pappy58
    Pappy58 Senior Member
    2,363
    4,738
    Dec 2, 2014
    You can try flipping the saddle. Next best option would be upgrade the Nashville to ABR-1. I agree with you on top wrapping....but I'm also not all hat ate up if the string grounds the bridge a little. Gibson certainly does not consider it an issue.
    If it's a recent new purchase maybe contact the dealer and see what they have to say.
  4. Rookie59
    28
    34
    Dec 10, 2018
    Hi. Thanks for your reply. I may take it back to the dealer to see what they have to say. However, I’ll also think about flipping the saddle and see if it helps.
  5. ARandall
    ARandall Senior Member
    12,462
    8,076
    Apr 16, 2012
    Each guitar is a little different. Most of the models will list neck angle with a small tolerance. If your dealer offers returns based on you simply not liking the look then maybe that is something to consider. There is certainly no function issue.
    endial likes this.
  6. Cjsinla
    Cjsinla Senior Member
    3,710
    3,050
    Jul 7, 2014
    Doesn’t look like a problem to me. Your neck angle is fine, look at how low the bridge is. Even if you could deck that bridge it will never be low enough to avoid hitting the strings if you lower the tailpiece all the way.
  7. kaputme
    kaputme Senior Member
    295
    222
    Mar 2, 2016
    Ahhh, i don't see a neck to check the neck angle ;)
  8. Fugazi39
    Fugazi39 Member
    58
    93
    May 29, 2018
    That is almost exactly how mine looks. No problem IMO.
