Naphta substitute for cleaning the finish
Discussion in 'Luthier's Corner' started by hoshino, Jun 13, 2018.
Tags:
  1. hoshino
    hoshino Junior Member
    1
    0
    Dec 24, 2015
    Hi all.
    One guy brought to me his guitar for some work and maintenance, and it's covered in unbelievable amount of that gunk made of grease, sweat, dust, cigarette smoke and whatewer it could be else. Never seen that much.
    So, everywhere on the net they say to use naphtha to remove this gunk, but in my country I actually never heard of a "naphta" and I can't find it. What's the best and safest substitute for it? Some sources says it's a petroleum spirit between benzene and kerosene, some says it's actually a white spirit, another ones - that it's a regular lighter fluid. Which of these I can safely use instead a naphtha to clean off this thick layer of grease without worrying about ruining the guitar finish?
    All that I've tried up until now (various clean&polish stuff) seems to be little help or building up cloudy stuff on the finish.
    Thanks in advance.
  2. w666
    w666 Senior Member
    1,951
    492
    Nov 25, 2009
    Lighter fluid=naptha
  3. northernguitarguy
    northernguitarguy SWeAT hOg
    29,436
    49,829
    Feb 22, 2009
    @w666 I thought the same, mostly because my old bottle of Ronsonol Lighter Fluid says 'Contains naphtha'. However, I was under the impression that they no longer use naphtha. Is that the case?
    FWIW, Coleman Camp Fuel is 100% naphtha.
    fumblefinger and LtDave32 like this.
  4. jkes01
    jkes01 Senior Member
    2,488
    1,442
    Jan 10, 2011
    Can you get Simple Green? Not a solvent, but will clean most gunk off a guitar and won’t hurt the finish.
  5. Freddy G
    Freddy G V.I.P. Member
    12,082
    26,452
    Mar 18, 2007
  6. fatdaddypreacher
    5,931
    3,922
    Feb 5, 2011
    whlatever you try....be sure you test in a pup cavity or something....just in case
    C_Becker likes this.
  7. C_Becker
    C_Becker Dat Gibson smell
    2,058
    2,063
    Jul 7, 2015
    Does zippo lighter fluid still contain naphta ? You might be able to get that.
    I have a bottle of regular lighter fluid (some supermarket off-brand) here, and it says naphta as well.
  8. Pappy58
    Pappy58 Senior Member
    2,336
    4,673
    Dec 2, 2014
    Most of the lighter fluids now state "petroleum distillate" but I believe for all intent and purpose its the same stuff. Any "white gas" camp fuel type stuff will do the trick!
    LtDave32 and northernguitarguy like this.
  9. madmusicltd
    madmusicltd Senior Member
    1,734
    1,797
    Feb 11, 2014
  10. northernguitarguy
    29,436
    49,829
    Feb 22, 2009
    Not advisable.
    Mindfrigg likes this.
  11. Al Walker
    Al Walker Senior Member
    1,233
    1,282
    Sep 14, 2014
    Mineral Spirits. I've never had any problems.
  12. LtDave32
    LtDave32 Desert Star Guitars Super Mod Premium Member MLP Vendor
    30,544
    93,354
    Mar 19, 2010
    Coleman camp fuel. Otherwise known as "white gas". Also known as naptha. It's a fuel, not a solvent. You can run it all over a lacquer finish and it won't hurt a thing.
    What it will do is remove all the old wax, gunk, human goo and whatever happens on a good Saturday night off of your guitar.
    I keep a gallon can under my bench, and I use it constantly. Sometimes when I'm wet sanding a fresh lacquer job I recently sprayed, and I'm a bit worried about water getting into an unfinished crevice, I'll use it as the sandpaper lubricant instead of water.
    Never had a problem.
    And on waxing a guitar, this I could never understand; why people will take fresh wax and rub it onto a guitar with old wax on it.
    All you're doing is pushing around the old wax. Get that crap off of there, and apply fresh wax.
    you can find this stuff (naptha, or naptha "substitute" or whatever semantic is popular now) in any liquor store that sells Ronson lighter fuel.
    Get a can of that. Flip up the little red spout. Apply some to a soft rag, and wipe that funky crap off your fret board.
    Extra tip:
    If you've got an unfinished fret board such as rosewood or ebony, with the strings off (of course), rub some Kiwi brown (for rosewood) or black (for ebony) shoe polish (in the tin, not the bottle) over that board. Then buff it real good with a soft, dry rag.
    -After you've cleaned it with (you guessed it), "naptha".
  13. LtDave32
    30,544
    93,354
    Mar 19, 2010
    Wal Mart brand "white gas" is only about 12 bucks a gallon. Beats the dickens out of a 5 ounce bottle at the liquor store.
    Pappy58 likes this.
  14. charisjapan
    charisjapan Senior Member
    1,565
    1,504
    Jul 10, 2011
    Hey @hoshino, where are you? In Japan, we call it White Gasoline, and 4L is about $20 on AmazonJP. Coleman fuel is nearly the same thing. Lighter fluid is also nearly the same thing, but expensive in those little Zippo cans.
  15. Mindfrigg
    Mindfrigg Senior Member
    57,879
    314,423
    Dec 28, 2010
    I use mineral spirits. Cotton rags. Used it for 45 years, to clean centuries old finishes. The wetness of the rag or brush depends on the fragility of the finish. Never had any problems. Removing rosin from an old violin is especially stubborn. But works. Doesn't leave a matte look like naphtha sometimes does.
    Also good for removing silica contaminants between rub downs of coats if you're experiencing fish eyeing or orange peeling. Or before touch ups or over spraying. After drying of course.
