Mylar 50's Bumble Bee Capacitors, Not Paper In Oil?????
Discussion in 'Vendor Classifieds' started by jonesy, Nov 19, 2011.
  1. BillyBlades
    BillyBlades Junior Member
    17
    8
    Apr 3, 2013
    Hi everyone.
    Just a quick question..
    Is there any modern equivilent to the bumblebees?
    Antique electronics or Angela instruments.
    Just wondering.
    Also... the "drift in capacitance???
    Has there been a notable drift in some of the more famous 59models?
    Wondering if going for a cap that Matches or "comes close " to the most desirable ones found.
  2. cooljuk
    14,414
    19,012
    Mar 12, 2009
    The Angela/Jensen copper foil in oil caps are quite possibly my favorite modern cap in a guitar tone circuit. I blind-tested myself a while back and those stood out to me as having a bigger sound and more character.
    Can someone please post a photo of the inside of a PIO bumblebee compared to the inside of a mylar bumblebee? It would be a wonderful addition to this thread!
    3 people like this.
  3. BillyBlades
    17
    8
    Apr 3, 2013
    Hi James.. i heard about your pups. We 're in the same state..
    I had the opportunity to.hear your buckers thru my modded Marshalls! Nice job!
  4. cooljuk
    14,414
    19,012
    Mar 12, 2009
    Nice, man! Who's pickups were they? I've been getting a good bit of local business lately.
    You're welcome to drop by the shop anytime. Just give me a ring first to make sure I'm around and listening for the bell. I can't hear it if I'm running some of my machines.
  5. BillyBlades
    17
    8
    Apr 3, 2013
    John.. from Belair. (50wattplexi) on the Marshall forum.
  6. jonesy
    17,188
    4,411
    Mar 28, 2008
    Bump to the top :)
  7. jaik
    jaik Senior Member
    651
    607
    Jan 8, 2012
    OK now hold on a sec , I'm totally corn-fused. :dunno:
    There's another thread on here where it is claimed there is no such thing as a Mylar Bumblee Bee :
    http://www.mylespaul.com/forums/mem...e-bumblee-bee-caps-paper-oil.html#post5668812
    where even the same fellow in this very thread says :
    and further I have someone else offering to sell me a set of BumbleBees without the little filler tube who makes the same assertion,: that there were no Mylar bumblebees, that they are all PIO.
    So which is it ? I'm trying to restore a 1957 Les Paul Special (at least internally). Don't get me wrong, I am not at all calling anyone's honesty into question whatsoever, there just seems to be some confusion on this issue.
    Can we clear this up definitively ?
  8. jonesy
    17,188
    4,411
    Mar 28, 2008
    This topic has been some what of a train wreck on this forum...all I can say is that I have cut open lot's of Bees and some have the brown Paper in oil construction and others are dry with the clear Mylar film and foil.
    1 person likes this.
  9. 79standard
    79standard Senior Member
    9,446
    66,407
    Feb 10, 2011
    I liked that thread, and I learned a lot while it lasted. Also, If I remember correctly, some wiseguy even posted a picture of a paper container of chicken in olive oil. :applause:
  10. jaik
    jaik Senior Member
    651
    607
    Jan 8, 2012
    if you've seen clear Mylar film in a Bumble Bee, that should pretty much resolve it. I think the thing to do is take 2 Bees, one with a spout, and one with out , cut them both open and show the photos.
    if the polyester Mylar stuff is actually clear , that should make it easy to ID and this could be settled.
    Its just kind of a drag not knowing what's what when trying to restore a 50s Les Paul, especially when prices are so inflated on what may or may not be a PIO cap
  11. jonesy
    17,188
    4,411
    Mar 28, 2008
    Mylar/Polyester came out around 1945 and was put into use in the electronics industry shortly after.
    Seems that there was a problem with the acid in the oil saturated Paper causing it to break down and shorting out the plates so Sprague changed over to Mylar sometime in the late 50's.
    More on the Sprague 160Ps
    http://www.paintedpostcards.com/misc2/BlackBeauties.pdf
  12. jaik
    jaik Senior Member
    651
    607
    Jan 8, 2012
    Matt at Martin6string is insisting in this thread that all Bumble Bees are PIO & are identical internally regardless of whether there is an eyelet spout or not.
    http://www.mylespaul.com/forums/ven...on-sprague-capacitor-origin-construction.html
    you should chime in on there, I think I saw somewhere on the forum that you cut open a few of these and took pictures didn't you?
    This issue might be settled once & for all by a little old fashioned Archaeology.
  13. jonesy
    17,188
    4,411
    Mar 28, 2008
    No thanks, not going to be posting anything on that MSC thread :cool:
    Best for us vendors not to comment on each others threads, it just leads to petty arguments and then the mods start to censor posts to try and keep the peace.
    My threads about capacitors were originally in the Tone Freaks sections as sticky threads, but because of all this bickering they were actually deleted at one point and then brought back in the vendor section.
    jonesy
    2 people like this.
  14. jaik
    jaik Senior Member
    651
    607
    Jan 8, 2012
    hahaha right on, well I appreciate both of your perspectives. I'm just hoping someone actually slices a couple of these open and takes pictures so we can see.
    I want to restore my 1957 les paul special, the caps I think would have been PIO eyelet version bumblebees , if there's some question at all whether the non-eyelet version is PIO or Mylar makes it hard to justify the inflated prices they're selling for. Oh well.
  15. jonesy
    17,188
    4,411
    Mar 28, 2008
    Lot's of info here on the Dr. Vintage website about the two different types of Bumble Bees, Mylar & Paper in Oil...just scroll down page past the switches...
    Dr. Vintage -1950's Gibson Electricals
  16. jonesy
    17,188
    4,411
    Mar 28, 2008
    Bump to the top from page 6 :)
  17. littlejon
    littlejon Senior Member
    105
    32
    Mar 3, 2012
    I just use a "Sweet Potato" Now
    Jonesy do you remember that video I laughed my butt off watching you do this!!
  18. littlejon
    105
    32
    Mar 3, 2012
    "Spud Tone"
  19. jonesy
    17,188
    4,411
    Mar 28, 2008
    OMG :laugh2:
    Yeah I was talking to a guy from the UK the other day on the phone and we were discussing caps in great detail and I brought that up. I smile every time I think about using that potato for a tone cap :)
  20. cooljuk
    14,414
    19,012
    Mar 12, 2009
    I opt for tater tots for a little more sizzle on the top end. :D
