My Les Paul, Refinished and Aged by Tony Berrington
Discussion in 'Other Single-Cuts' started by Chakalawaka, Oct 31, 2017.
  1. Ayrton
    Ayrton Senior Member
    237
    32
    Jul 16, 2008
    Looks fantastic! The name on the headstock doesn’t make the sound, the player does.
    NJDevil, jimmyjames and Chakalawaka like this.
  2. Chakalawaka
    Chakalawaka Senior Member
    139
    202
    Feb 23, 2017
    This is where the surprise is! It's just a veneer (There's a dark spot near the bridge tone pot, where Tony accidentally went through the veneer). What surprised me is that even though it's a veneer, it still reacts to the light like a maple top, which really makes it special :) I guess the ol' nitrocellulose helps.
    Thank you very much! And thanks for the recommandations! I've heard about the Seth Lover, it's a shame though that they aren't wax-potted... But I'll definitely have a look into it :)
  3. blues360
    blues360 Junior Member
    22
    7
    Dec 17, 2013
    Nice job on the electrics side did you swap out the switch and pots and rewire 50,s style with PIO caps to get it as close to a 59 wireing wise?
    Chakalawaka likes this.
  4. Chakalawaka
    139
    202
    Feb 23, 2017
    Good question! Not yet, this will be for the next project, which is changing the pickups :)
  5. Zoobiedood
    Zoobiedood Senior Member
    877
    308
    Sep 1, 2015
    They can be ordered wax potted, if you like.
  6. Chakalawaka
    139
    202
    Feb 23, 2017
    Nice! I've watched the Seymour Duncan video on their youtube channel and I was quite impressed, I don't know which version they had installed on the guitar but oh my it sounds heavenly!
    Zoobiedood likes this.
  7. edouglaspratt
    edouglaspratt Junior Member
    24
    19
    Dec 20, 2011
    That's my opinion too, NZ. This is subtle and very beautiful. Congratulations Chak!
  8. gkelm
    gkelm Senior Member
    1,016
    224
    Nov 16, 2009
    If you want a classic PAF tone at a reasonable price, look into a used Dimarzio 36th Anniversary...really great pickup.
  9. solderjunkie
    solderjunkie Senior Member
    134
    206
    Dec 15, 2014
    Can you please explain your process for removing the old finish? Thanks!
  10. NJDevil
    NJDevil Senior Member
    265
    132
    Mar 30, 2014
    Great project and even better results. She definitely is a looker and I agree w/ the Seth Lover idea if you have the extra cash. Great job....Congratulations!
  11. Chakalawaka
    139
    202
    Feb 23, 2017
    Thanks for the tip I'll have a look into it today :)
    The only solution for the polyurethane lacquer/varnish that this guitar had was sanding... And a lot of patience, carefulness and control! Polys are very strong, dry and thick lacquers, so expect a fight with it if you're intending to the the same. With nitrocellulose it's much easier, you just need a heat gun and a scrapper, it will come right off!
    Thank you! :) The Seth Lover is quite expensive indeed but it might be worth putting a little extra cash and get a killer tone ;) I mean at this point anything will be better than the stock pickups anyway!
  12. bluesriffdev
    bluesriffdev Senior Member
    435
    309
    Mar 10, 2014
    You've got it mixed up. Nitrocellulose finishes can be sanded off, whereas poly finishes need the heatgun and scraping (although you can sand them... it just takes forever). Nitrocellulose finishes 'burn in', attaching to the layer preceding it, whereas poly sort of solidifies. It's the reason finishing with nitro is more friendly to beginners; it's easier to correct your mistakes, it just takes a lot longer to set.
    Beautiful guitar.
  13. Chakalawaka
    139
    202
    Feb 23, 2017
    Oups my bad! You're absolutely right!
    But in this particular case, the poly just wouldn't come off with the heat gun, all it did was scorching the surface, so in this instance sanding had to be done in order to get it right (see in the picture attached the first steps of the poly off, you can see black spots from the heat gun).
      File size:
      48.2 KB
      18
    bluesriffdev likes this.
