My Les Paul got jacked up by the local luthier
Discussion in 'Gibson Les Pauls' started by YoshiJimbo, Nov 4, 2017.
  1. Justin_Case
    Justin_Case Senior Member
    5,781
    3,130
    Apr 29, 2009
  2. Bobby Mahogany
    Bobby Mahogany Senior Member
    17,638
    23,503
    Feb 25, 2012
    I don't doubt they do some restorations.
  3. Justin_Case
    5,781
    3,130
    Apr 29, 2009
    If you can write the check, they will restore anything you want....
    That said, there are people out there that are as good or better; and less expensive, but they don't work for or at Gibson.
  4. YoshiJimbo
    YoshiJimbo Senior Member
    2,622
    2,354
    Nov 8, 2011
    Went by and saw the Les Paul today. I should mention the original neck profile was the slim 60s version. I was expecting to see a huge hole but its actually more like a crack about a quarter inch long. I asked him to fix it best he could without replacing the neck. He originally offered to replace the neck at his cost but at this point i don't want something that extensive done to the guitar.
  5. bluesondoor
    bluesondoor Senior Member
    150
    116
    Jun 2, 2017
    Sounds like you're letting him off easy to me. Up to you
  6. fleahead
    fleahead Senior Member
    2,438
    3,012
    Jan 9, 2012
    Whatever you wanna do. Your guitar. If it fails, you're out a LP.
  7. Macronaut
    Macronaut Silver Supporter
    661
    353
    Nov 23, 2016
    Personally, I would not settle, nor would I let him replace the neck. He should buy you a new (or used) equivalent guitar.
    You are the only one that has to live with your choice of which way to go in this matter.
    azzapeel likes this.
  8. michaelinokc
    michaelinokc Senior Member
    6,772
    9,762
    Jan 27, 2012
    Exactly.
  9. stiff fingers
    stiff fingers Double Platinum Supporter Premium Member
    90
    36
    Jan 1, 2016
    Consider this: you guitar has had a cracked neck for years. the crack is from the truss rod cavity out, it created a slight bulge that you asked to have shaved, and shaving exposed that crack. The luthier really has done nothing wrong.
  10. fleahead
    2,438
    3,012
    Jan 9, 2012
    Have we seen pictures yet? No pictures or it didn't happen.
  11. HardCore Troubadour
    HardCore Troubadour Senior Member
    7,899
    5,553
    Nov 17, 2012
    really, and where did you get this information?
  12. stiff fingers
    90
    36
    Jan 1, 2016
    Just something to consider because it seems the Luthier did not, in fact, shave through to the truss rod groove, but rather stopped shaving when he detected a crack, I think a previous faint crack makes more sense than any person putting enough pressure on a scraper to actually crack a neck. The assumption being that it is a crack, like another poster mentioned, we need photos.
  13. DotStudio
    DotStudio Silver Supporter
    3,439
    5,504
    Nov 13, 2015
    That's just silly.
    bluesondoor and yamariv like this.
  14. bluesondoor
    150
    116
    Jun 2, 2017
    If the luthier was that skilled and knowledgeable he probably should've checked for the hypothetical crack before going to town. According to OP the luthier took responsibility. Clearly he knows he messed up.
    lakeburst likes this.
  15. Kaicho8888
    Kaicho8888 Senior Member
    688
    285
    Jul 27, 2008
    Is it a crack or the trussrod cavity showing?
  16. Leña_Costoso
    Leña_Costoso Senior Member
    469
    367
    Aug 28, 2017
    Personally.... I hate it when my crack shows. It sounds like a it's a very fixable item. The cosmetics of it is another issue. On a solid color neck you never say it. On a stained neck.... I truly invisible repair would be tricky, what a passable repair shouldn't be that difficult.
    I've always wondered about truss-rod grooves and what might happen if there were a pull out from the wood on the inside during the manufacturing process.
  17. nadzab
    nadzab Senior Member
    240
    87
    Aug 26, 2009
    Your liability insurance almost certainly didn't cover faulty work, that's a warranty issue. Commercial liability underwriters assume that you will perform your work proficiently, and if you don't, damage to the work itself - caused by your failure to do it properly - is typically excluded. Otherwise, there would exist what's known in the business as a "moral hazard", in that insureds would have little concern for doing their work properly, knowing that if they screwed up, their insurance would take care of it. Accordingly, most commercial general liability policies contain exclusions for damage to the insured's work and products.
    Sorry for the insurance geek-out, it's what I do.
  18. tzd
    tzd Senior Member
    5,499
    3,289
    Oct 21, 2011
    Why would you even want to shave down a 60s neck in the first place.
  19. Macronaut
    661
    353
    Nov 23, 2016
    That thought crossed my mind as well. Also, that should have given the "luthier" pause when he evaluated the task at hand.
    endial likes this.
  20. sk8rat
    sk8rat Senior Member
    9,487
    11,760
    Sep 28, 2014
    not trying to attack you or anything but how much did you think he was going to be able to take off in the first place? there isnt much wood there as it is.
    it's your guitar and ultimately your decision but I think you are making a mistake by having him just repair the "crack." there may only be one spot where he broke through but Ill bet there are other spots on the neck where there is only a hairs thickness of wood where the truss rod is and it might cause problems in the future. im not an expert but the neck rigidity may be compromised and there will always be a level of uncertainty as to how it will hold up.
    I would tell the guy to reimburse you top market value for the guitar and just buy something new or a reneck (which will probably take a while). it sucks but I dont think you will ever feel happy with that guitar and a halfassed repair.
    lakeburst, Macronaut, Hope and 3 others like this.
