My Les Paul got jacked up by the local luthier
Discussion in 'Gibson Les Pauls' started by YoshiJimbo, Nov 4, 2017.
  1. YoshiJimbo
    YoshiJimbo Senior Member
    2,656
    2,397
    Nov 8, 2011
    I took my 2012 Les Paul Traditional Pro in to have the neck profile reduced. After 3 weeks the guy calls to say he cut through to the truss rod and would have to replace the neck. I'm shocked and heartbroken.
    I bought the guitar new 5 years ago and it's been an absolute joy.
    brianbzed likes this.
  2. Subterfuge
    Subterfuge Senior Member
    627
    862
    Aug 18, 2017
    ouch that's gotta' hurt ...
  3. ClashCityRocker
    ClashCityRocker Senior Member
    182
    144
    Mar 17, 2015
    youch! is it an independent repair guy or is he affiliated with a larger company?
    Pretty heavy since the resell value has pretty much plummeted, however if you were shaving it down anyway it doesn't seem like that was an issue for you. I would imagine the conversation being rather awkward if you propositioned him to send it to Gibson for a proper factory reneck.
    Otherwise I would be hoping for free service and then some (not sure exactly what).
    Is this easy to do (cutting through to the rod)? I guess as you get closer to the nut the profile is thinner....but still, really shocking.
  4. HardCore Troubadour
    HardCore Troubadour Senior Member
    8,286
    6,066
    Nov 17, 2012
    man I hate that for you, but I do have a question......if it has been such a joy, what was the point of shaving the neck???
    there are plenty of them out there, tell him to pay you for it and go hunting.
  5. Thumpalumpacus
    Thumpalumpacus Senior Member
    75,202
    182,762
    Nov 28, 2010
    Yuck. He needs to reneck it on his own dime, and hopefully you can find a new luthier. Best of luck, YJ.
  6. Bobby Mahogany
    Bobby Mahogany Senior Member
    19,785
    28,228
    Feb 25, 2012
    Wow, that's too bad.
    If he went through the neck to the truss rod,
    is he really the guy to install a new neck?
    Are we talking about a new Gibson neck?
    Why not let Gibson handle it (with the right profile neck for you)
    and the so-called luthier pay for it?
    Maybe he should give you the guitar back as it is and you find the right person to fix it
    and he pays for it?
    I would try to have him on record ("Call recal"l is a free mobile app that lets you record conversations...)
    saying that he fucked up and then you'd have a "handle" on him.
    This thing might go to small claims court eventually.
    Let us know what happens.
    Take control.
  7. YoshiJimbo
    2,656
    2,397
    Nov 8, 2011
    An independent.
    Ah, I didn't know having Gibson repair it was an option. Thanks!
  8. Bobby Mahogany
    19,785
    28,228
    Feb 25, 2012
    Gibson is not a repair shop but in some cases they will repair an instrument.
    I think it would at least be worth asking.
  9. cherrysunburst00
    cherrysunburst00 Senior Member
    13,736
    23,885
    Mar 15, 2015
    That really hurts. Im very sorry for you.
  10. Biddlin
    Biddlin Senior Member
    1,543
    1,865
    Aug 21, 2012
    I hope that your luthier is paying for whatever the solution may turn out to be. When I worked as a repair tech, I had liability insurance, though gratefully never needed to use it. Gibson might do a new neck, but they are very expensive. I got a quote from them on a much simpler headstock overlay repair that was nearly $1k!
    fleahead likes this.
  11. brianbzed
    brianbzed Senior Member
    2,162
    969
    Aug 14, 2008
    Sheeeit man.......sheeeit...
    He should pay for a replacement
    J
  12. endial
    endial Senior Member
    2,235
    1,925
    Oct 23, 2014
    The trick to not shaving through to the truss rod is NOT a well-kept secret. You take a fine drill bit to the back of the neck straight in until you meet the truss rod (-or break through to the void. You can feel that.), pull the drill bit from the drill, and use it as a depth gauge to see how far you have to go. Easy as pie. A small hole is easily plugged, and quite unnoticeable.
    If this guy didn't know that, well...
    jcsk8, YoshiJimbo, DADGAD and 2 others like this.
  13. 2manyGuitars
    2manyGuitars Senior Member
    5,819
    14,314
    Feb 15, 2008
    Malikon, TheZ, Lloyd_m and 4 others like this.
  14. Kitsune
    Kitsune Member
    49
    64
    Oct 1, 2010
    Really sorry for your guitar but I'd put pressure on the guy that ruined it and ask for a damn new one or at least a replacement if I were you.
    No way I would accept a repaired neck or let this guy near my guitar again! I can understand having a repair if I drop my guitar or if I damaged it myself but not so in this case.
  15. Donal
    Donal ¯\_(ツ)_/¯ Premium Member
    13,456
    13,075
    Aug 25, 2009
    WOW, that`s awfull .... really wtf :hyper:
  16. PierM
    PierM Black & Gold Premium Member
    2,862
    4,369
    Aug 19, 2016
    I'm very sorry to hear that, but IIRC isn't that model having a Slim Taper profile? I mean, there is not really room to shave that neck, especially at the vertex, since the trussrod does sit just under 0.35/0.39" of wood. He should have shaved just the taper, not really the vertex.
  17. Pop1655
    Pop1655 Premium Member
    6,547
    12,301
    Aug 25, 2014
    "The local luthier". That's a scary phrase around my parts. I agree with the sentiments expressed above, but also fully realize that if that happened to me I'd just be SOL. Can't squeeze blood from a turnip. I hope it ends better for you. I know how it would end for me.
  18. Filipem
    Filipem Senior Member
    686
    546
    Apr 8, 2013
    Man that sucks. I feel for you. Yeah I'd try to get the value of the guitar from the luthier and buy another one. Plenty of trads to choose from in the used market.
  19. Justin_Case
    Justin_Case Senior Member
    5,941
    3,361
    Apr 29, 2009
    JHMO - Don't let this guy do the re-neck. Find someone like Greg at BCR Music & Sound with a proven track record of stellar repair work = 300 S 3rd St, Lemoyne, PA 17043 -(717) 730-9775
    I spent many years in the insurance industry, and from that vantage point, the guitar is an " Economic Total ". The cost and time to repair it with a neck replacement and the associated paint / finish work is not worth fixing for the end result.
    From an adjuster's point of view, to spend the money to fix, when the end result may not be acceptable, and the value of the guitar will be substantially lower due to the re-neck, is simply a bad financial decision.
    Numbers:
    Replacement value of a Trad Pro II is $1250 to $1500 tops.
    Part out the original guitar BallPark - Case $100, Pickups+Electronics $200. Grovers - $50. Husk - $50
    Delta = $1375 average cost to replace - $400 = $975
    Parts and Labor from a qualified / reputable repair shop?? $500 I would think be on the very low end in light of all the labor involved. Cost of a Neck from Gibson? Color matching the neck or a whole new paint job?
    Value of the " Re-Necked " Trad Pro assuming the repair is disclosed = $750 to $1000, assuming a perfect repair; no playability or fit and finish issues.
    Also from an adjuster's point of view, you are out a guitar to play, no different than when a car would be in a shop after an accident, the cost of a rental guitar while the repairs are being done would have to factored in - cost / value ????
    The downside risk of the repair not going right could easily cost more in the long run than getting replacement guitar. In this case, an insurance company will " cut bait " and call it a total loss. Pay for a replacement, recoup as much as possible in salvage value, and close the file.
    BBD, Howard2k, gnappi and 3 others like this.
  20. fleahead
    fleahead Senior Member
    2,797
    3,822
    Jan 9, 2012
    So, what's the word from this guy?
