My 1st Guitar Build: A Les Paul... (duh)!
Discussion in 'Luthier's Corner' started by nuance97, Jul 6, 2011.
  1. nuance97
    nuance97 Premium Member
    2,172
    1,231
    Feb 26, 2009
    You are very kind. Thank you.
  2. fatdaddypreacher
    5,777
    3,787
    Feb 5, 2011
    great job, nu. that top is really nice, and the burst compliments it well. clear and polish will really make it pop.
    1 person likes this.
  3. jbrybar
    jbrybar Senior Member
    310
    166
    May 4, 2011
    Looks great! Better than my first burst.. Glad to see you making progress.. I finished my first build early summer and spent all the warm days playing.. Now it's getting cold I'm ready to start building again and will as soon as I can get some heat in my garage.. :) Can't wait to see her complete.. It's always inspiring to see a beauty like this come together.. :thumb:
    Jason,
  4. tnt423
    tnt423 Senior Member
    1,368
    913
    Jan 26, 2010
    Very nice, while I'm not am huge fan of the cherry burst, that works well! Did you use a light fast toner or will it fade?
  5. nuance97
    2,172
    1,231
    Feb 26, 2009
    It is aniline so it will fade. :thumb:
  6. cocorico
    cocorico Junior Member
    6
    2
    Dec 23, 2013
    Hi Nuance,
    Great thread and great work. Congratulations for the results!
    I've got a question: what are the dimensions of the piece of wood you used to obtain two necks?
    Thanks again for all
  7. LPBR
    LPBR Senior Member
    1,203
    978
    Dec 1, 2011
    Fantastic, fantastic, FANTASTIC thread!
    This is one of the best build threads I ever seen, from the point of view of the begginer (myself)! You expose so many details that reveal the solution for several misteries.
    I loved your jigs (and their simplicity) and liked specially the one to radius the fretboard.
    Thanks for sharing and congratulations for excellent work!
  8. nuance97
    2,172
    1,231
    Feb 26, 2009
    You'd have to start with a blank that's 3x4x32".
  9. jbrybar
    310
    166
    May 4, 2011
    I was able to get 2 out of a 3x3x32 after planing.. I didn't have as much left over from the center.. Just barely had enough for the ears.. :) I would much rather and also recommend having a 3x4x32, but that was what I had and fortunately made it work..
  10. cocorico
    6
    2
    Dec 23, 2013
    Thank you very much for ALL. :thumb:
  11. Stoj
    Stoj Senior Member
    3,350
    2,025
    May 23, 2007
    You are making awesome progress & the results look great, excellent work :cheers:
  12. nuance97
    2,172
    1,231
    Feb 26, 2009
  13. Rodolphe
    Rodolphe Senior Member
    1,429
    636
    Jan 31, 2010
    Waoow, didn't see this before.
    great work.
    how long have you been working on those LPs?
  14. nuance97
    2,172
    1,231
    Feb 26, 2009
    Forever it seems...and they're still not done. I have just about decided that I'm gonna pay somebody else to spray the finishes. I'm set up to do woodwork, and I feel very competent doing that. The finishing process however I'm not set up to do, and I have no desire to do it. It's just not fun to me.
    Thanks, BTW
  15. KeyserSoze
    KeyserSoze Senior Member
    131
    34
    Sep 5, 2008
    Progress pics if you do any more work, or get them finished? :fingersx:
  16. nuance97
    2,172
    1,231
    Feb 26, 2009
    Absolutely
  17. frankencat
    frankencat Senior Member
    655
    344
    Jun 27, 2008
    I don't mean to derail the thread but can someone explain why you need to angle the control cavity route? Also is the switch cavity angled as well? I have never noticed this before. Thanks -Frank
  18. nuance97
    2,172
    1,231
    Feb 26, 2009
    It needs the angle so the inside of the cavity roughly follows the contour of the top carve. Without relieving the inside of the cavity the shaft of the neck vol/tone potentiometers would not reach through the holes.
    Similar story on the selector switch. The angle of the inner hole is so that it roughly follows what the carve is doing.
  19. frankencat
    655
    344
    Jun 27, 2008
    Got it. So the switch cavity is the same angle as the control cavity?
  20. nuance97
    2,172
    1,231
    Feb 26, 2009
    The angle of the switch cavity is less than the control cavity. I'm not sure what the angle is exactly, but it is quite a bit less as the carve in the switch area is less steep than the lower bout around the knobs.
