My 1st Guitar Build: A Les Paul... (duh)!
Discussion in 'Luthier's Corner' started by nuance97, Jul 6, 2011.
  1. nuance97
    nuance97 Premium Member
    2,172
    1,231
    Feb 26, 2009
    Well I have been hanging around here for years...at least one before I joined. I feel like I've have learned more here than I could have anywhere else, and I say THANK YOU to all of the ridiculously talented luthiers that post here. It is my turn to add something to the forum of some entertainment/educational value.
    I was willed a fully outfitted wood shop by my late father-in-law who passed two years ago due to cancer. He knew that I had interest in guitar building even though I have never built anything before. The shop is full of a lot of hobbyist-grade tools, but if you are careful I've found that they'll do a more than adequate job. The power tools I am using are:
    9" band saw (bench top)
    Floor mount drill press
    Miter saw
    6" bench top jointer
    router table
    fixed base router
    Cheapo plunge router (used only for pickup 'Legs')
    Just bought a Ridged oscillating spindle sander AWESOME TOOL!
    Two laminate trim routers
    Though I have no real-world wood working experience I have been obsessed for years with the topic. I have watched every episode of The New Yankee Workshop along with every other show on the subject I could find. I have also read several books, dozens of magazines, and other internet material concerning woodworking. I had a good understanding of the tools and how to use them safely. THIS IS A MUST!
    Lets get to the build! I chose to go with the Bartlett Plan because is it the most accurate. I had several copies made and glued the various parts to 1/4" hardboard with spray-on adhesive
    rough cut on the band saw
    sand to the lines.
    I use the hardboard template to make templates out of 1/2" or 3/4" MDF. I like to make templates for my templates so I can have a backup when I ruin one.
    I ended up remaking these with the Bartlett update with revised headstock and pickup routes
    My Templates were designed to be used with template bits that have shank mounted bearings.
    n32, CaptainT, gplayer and 11 others like this.
  2. fatdaddypreacher
    5,774
    3,781
    Feb 5, 2011
    well, nu. glad to see you take the pllunge. i ain't much of a bettin' kinda guy, but by the looks of the neatness and precision of your work on jigs and templates, i bet we're fixin' to see one of the best first builds we have seen. you first timers kill me with you passion and tenacity. best of luck and stay safe. count me in.
    EthanB likes this.
  3. nuance97
    2,172
    1,231
    Feb 26, 2009
    Glad to have you along FDP!!!!!:thumb:
  4. nuance97
    2,172
    1,231
    Feb 26, 2009
    This beast was fun to make. It was inspired by Fletch/preeb.
    n32 likes this.
  5. dickjonesify
    dickjonesify Senior Member
    4,742
    4,615
    Apr 16, 2010
    Sweet :dude:
    Excellent jiggery and templatery! You're gonna do just fine. Nice to see you throwing your hat in the ring. :h5:
    nuance97 likes this.
  6. nuance97
    2,172
    1,231
    Feb 26, 2009
    Thanks Daniel!:slash:
    dickjonesify likes this.
  7. Bruiser74
    Bruiser74 Senior Member
    1,086
    283
    Jan 8, 2010
    Great so far, love that neck jig.
  8. 52trapeze
    52trapeze Senior Member
    982
    125
    Feb 22, 2011
    Your going to do a awesome job man! When i get the cash i want you to finish my other replica body!
  9. nuance97
    2,172
    1,231
    Feb 26, 2009
    Time to cut some real wood...
    Rough cut on bandsaw
    Attach template #1
    End result
    I could mention that I am not just building one, but three:wow:WTF am I thinking?!?
    Got some tear-out on one of them (Damn!) I couldn't find the chunk that flew out so I dug out the waste piece from the rough cut and cut a piece from the same spot so the grain would match and glued 'er in. This is the one and only spot that gets anything but Hot Hide Glue.
    It will be invisible in the end.:fingersx:
    Frack, n32 and Udonitron like this.
  10. Bob1
    Bob1 Senior Member
    724
    77
    Nov 22, 2009
    Looking good!
  11. nuance97
    2,172
    1,231
    Feb 26, 2009
    Thanks man. Your build is splendid!:applause:
    Thanks. You know where to find me. ;)
    Appreciated! BTW I'm liking the Skylark.
  12. Claymore
    Claymore Senior Member
    1,020
    383
    Feb 5, 2011
    Nice progress!
    Not your first go-around with wood-working tools, methinks!
    Show us your nude tops!
  13. captcoolaid
    captcoolaid Senior Member
    11,412
    3,906
    Nov 29, 2008
    Wow the tear out repair came out amazing.
  14. Barnaby
    Barnaby Senior Member
    8,588
    10,024
    Nov 5, 2010
    Wow! :applause:
    This is going to be a brilliant guitar. Like FDP, I'm not a betting man, but I'd bet on this one turning out beautifully for sure. :thumb:
  15. nuance97
    2,172
    1,231
    Feb 26, 2009
    Drill out control cavity/toggle waste with drill press and forstner bit.
    then clamp template to it.
    Looks good.
    Next template
    Looks good. Definitely good to have full body outline on each template. There is no problem lining everything up. It's foolproof.
    Sand out router marks
    Round over with 3/16" round over bit.
    Remember that tear out?
    Frack and n32 like this.
  16. dickjonesify
    4,742
    4,615
    Apr 16, 2010
    Man! These are perfect, Dan. You've been holding out :dude:
  17. fatdaddypreacher
    5,774
    3,781
    Feb 5, 2011
    crisp, clean, neat, precise...this is gonna be fun!
  18. nuance97
    2,172
    1,231
    Feb 26, 2009
    Believe it or not it is my first go-'round...with almost all of these tools. I've used a skill saw and hammer before doing some real rough carpentry work, but nothing even close to this...
    Thanks. See the above photo.;)
    Thanks Barn! I really hope you're right!!:laugh2:
  19. nuance97
    2,172
    1,231
    Feb 26, 2009
    I've been piddlin' on these for a while.
    It has been thus far...
  20. nuance97
    2,172
    1,231
    Feb 26, 2009
    Edit** I did find a few progress shots of my necks.
    Re-saw a blank to get the least amount of grain run out.
    Rough cut neck outta one side
    Flip and repeat.
    Here you can see one of my neck after the neck fixture.
    After rough cut clamp to side 1 of fixture route 17* headstock angle smooth, clean up at jointer, then route side 2 of fixture to get back profile of the neck.:thumb:
    n32 likes this.
