Mxr dyna comp?
Discussion in 'Pedals' started by peterjc, Nov 4, 2017.
  1. peterjc
    peterjc Senior Member
    250
    141
    Dec 15, 2013
    Who else uses a dyna comp for that 80’s clean tone with chorus of course? I stick mine in the loop and it sounds great, absolutely nails that 80’s clean tone. I use humbuckers and it almost gives that single coil tone. Also doubles as a nice lead boost with the sensitivity all the way down on a crunch tone!
  2. moreles
    moreles Senior Member
    2,351
    939
    Apr 16, 2011
    I have a Dyna Comp with the "Ross mod" to make it a little squishier, and I like it a lot and use it a lot. I find that it's easy to avoid an over-compressed tone and really like the way it interacts with my other pedals. I especially like having the ability to reduce excessive attack and add a bit more evenness and sustain. Dialed in, it's a great tone. Overdone, and it just sounds too processed. Even the current Dyna-Comps are good pedals, and a good value.
    peterjc likes this.
  3. peterjc
    250
    141
    Dec 15, 2013
    I never thought of using it as a boost but it’s as good as any I’ve tried so far and I sort of stumbled on it. I’ve tried ep booster (sounds good but adds too much bass) mxr cae line/boost ( too thin) and 2 eq pedals . Like you said it has great tone and for leads it thickens single lines without too much bass! I would love to try mxr micro amp as I’ve heard great things but at the moment the dyna comp is it.
  4. sonar
    sonar Senior Member
    2,825
    1,875
    Sep 10, 2008
    Townsend used a Dyna as a boost from the late 70's until the '82 "Farewell Tour."
    I have a MXR Custom Comp dialed in at Dyna settings with the mini trim pots. Nothing does Squishy Chicken pickin' better than a Dyna with a CA3080 "metal can" IC. As classic as any Muff, Clyde Wah or Fuzzface ever produced.
  5. marksoundguitars
    marksoundguitars Chief Paint Sniffer MLP Vendor
    525
    686
    Jan 24, 2017
    I have one. It's always on when I play a Tele. There are other compressors, but this one is it for me. And cheap. I like cheap.
  6. mmd
    mmd Senior Member
    2,308
    2,120
    Sep 24, 2012
    I have one and I use it all the time. I have mine set more like a boost and it is KEY to my tone. When I switched to the Helix, I was thrilled that they modeled the Dyna Comp. It is even a part of my modeled amp tone, lol. One of the best pedals I ever got.
