Monitor Cables
Discussion in 'Recording Studio' started by Caoimhin, Feb 11, 2017.
  1. Caoimhin
    Caoimhin Senior Member
    8,389
    8,483
    Oct 12, 2009
    What kind of cables should I use to connect some monitors to my interface? Do you just use instrument cables?
  2. LPSGME
    LPSGME Senior Member
    3,804
    3,040
    Oct 1, 2008
    Either will work. But may as well get XRL or TRS if you are buying them.
  3. Caoimhin
    8,389
    8,483
    Oct 12, 2009
    I've had Alesis M1 Active monitors for a long time. It only has XLR jacks to connect the two monitors together but has far and sending sound to them, it has two 1/4 jacks and USB.
  4. Freddy G
    Freddy G V.I.P. Member
    10,837
    21,948
    Mar 18, 2007
    Use a pair of TRS-TRS cables from the interface to the speaker(s)?
    I believe both inputs go to one speaker and then a there is a link (are you sure it's XLR?) from one speaker to the other.
  5. Caoimhin
    8,389
    8,483
    Oct 12, 2009
    Yes, both 1/4 jacks are on one speaker. The two speakers are connected together with an XLR cable.
  6. LPSGME
    3,804
    3,040
    Oct 1, 2008
    The 1/4" speaker input jacks are likely TRS; as are your converter's outputs. So just get some cables with TRS connectors on each end. As to your original question of whether it can use "instrument cables" the answer is yes. And you should also be able to use an unbalanced mono cable.
  7. dspelman
    dspelman Senior Member
    9,803
    5,720
    Apr 30, 2009
    If they're powered monitors, instrument cables will do. If you're driving it with a power amplifier, run speaker wire from the power amp to the speakers.
