Mojoaxe Compensated vs Pigtail Adjustable Wraparound on '56 Les Paul Junior
Discussion in 'Vintage Les Pauls' started by jailbreakrose, Apr 8, 2017.
  1. jailbreakrose
    jailbreakrose Junior Member
    1
    2
    Apr 8, 2017
    I have a 1956 Les Paul Junior that I added a Pigtail wraparound adjustable bridge to address the intonation problems I was having, as well as a little sitar buzz on the first string (I also added TonePros locking studs as well as new extra long bushings). While it fixed the problems I was having to a degree, I was wondering if I could take it a step further. The frets are original, and I know it could use a fret job, but I was wondering about the bridge, specifically. Do any of you have experiences with the Mojoaxe CWT (designed for the offset studs) vs. the Pigtail? Anyone done a 1:1 comparison with those two bridges for a 50's Gibson with the offset studs?
    Paul_Cat and RevWillie like this.
  2. RAG7890
    RAG7890 Premium Member
    14,096
    22,053
    Jul 11, 2010
    I have the Mojoaxe on my '54 Replica. It's awesome. :thumb:
    A friend (Liam) played it, prior to shipping & liked the Mojoaxe so much that he ordered several to put on his Vintage Juniors / Special. He said it removed the Sitar thing that happens with the Vintage Wraparounds & helped with intonation.
    I would drop him a PM & ask his opinion, as he's way more qualified than I am. He's also a great bloke who's happy to help fellow members. :thumb:
    Good luck & mention I sent you. :)
    BTW, welcome to MLPF. :)
    Cheers, Rudi.
  3. bossaddict
    bossaddict @david.beason on IG Premium Member
    6,481
    8,406
    Apr 4, 2013
    :welcome: to the forum!
    Copying and pasting my response from TGP...
    No experience with the adjustable Pigtail, but I've got a MojoAxe on my '57 Special and am very happy with it. Very close on intonation and it just looks so much better (IMO).
    Gratuitous pic. ;)
  4. NotScott
    NotScott Silver Supporter
    1,869
    3,871
    Nov 25, 2012
    I have the MojoAxe on my R4JB. It sounds great, looks great and has zero intonation issues. I can't imagine using anything else.
  5. yeti
    yeti Senior Member
    3,453
    3,348
    Aug 19, 2008
    Mojoaxe on my '56 junior, perfekt.
  6. d1m1
    d1m1 Senior Member
    2,357
    2,538
    Oct 30, 2012
    i´m not a fan of the adjustable ones. you just loose tone and sustain the more moving parts you have. i definitely prefer one piece wraptails and in this case imo mojoaxe has the best one. my R5´s have both the compensated mojoaxe.
    i also had the tonepros locking studs and switched to good one piece steel studs for the same reason. more moving parts, more connections, less tone..
  7. korus
    korus Senior Member
    1,068
    364
    Apr 10, 2007
    No adjustable wrap around (Pigtail, Tonepro, ... whichever) has the tone of originals, as it is physically impossible - the construction and weight are different. OTOH Mojoaxe is the same like originals, it has the tone of originals AND solves the tuning issue originals were not designed to solve. On a guitar that replicates vintage design ... you get it. Case closed.
  8. deadlyweasel
    deadlyweasel Silver Supporter
    1,440
    1,101
    Mar 25, 2011
    I have mojoaxe on the two juniors I've built and I have one on my 59' special. Accept no substitute for perfection. Dan is the man, his products are second to none.
  9. Kris Ford
    Kris Ford Senior Member
    4,754
    4,035
    Dec 17, 2011
    Pigtail just seems to be a streamlined Leo Quan Badass..Mojoaxe is the more elegant solution.
  10. Britbender
    Britbender Senior Member
    287
    349
    Dec 24, 2010
    Nothing hurts my eyes like a Badass on a junior...butt uglii
  11. drugprowlingwolf
    drugprowlingwolf Senior Member
    1,473
    619
    Apr 16, 2012
    I've had both - Mojoaxe all day. Looks better and feels better under my palm. Also the pigtail imparted a steely upper harmonic thing that I just didn't like - it exaggerated the guitars voice too much.
    I'd even grab a gibson historic wrap around on the cheap before a pigtail just because I prefer to keep a more natural voice to the guitar. Maybe I got a bad one? The workmanship looks great but the sound just isn't for me. I've tried it on a 50s junior and a historic lp special - both got that weird upper mid thing going on.
    Dan at mojoaxe is really easy to deal with too.
  12. jeggz
    jeggz Senior Member
    3,499
    2,918
    Aug 19, 2008
    Mojoaxe.
  13. crashbelt
    crashbelt Junior Member
    16
    40
    Mar 25, 2016
    Mojoaxe all the way. Put them on my 50s Junior and Special. They work great and look cool. Dan is great to deal with too.
  14. Seahawk2982
    Seahawk2982 Senior Member
    157
    18
    Jul 30, 2013
    I have tried both the straight compensated Mohoaxe and the regular Pigtail wraptail on my '57 Junior. The original wraptail was gone way before I got it. Both bridges solve the sitar buzz problem and the strings ring clear. The Mojoaxe gets near perfect intonation with 10s or 11s from standard down to Eb. I found the Pigtail to be a bit brighter and maybe a tad richer sounding than the Mojoaxe But both sound excellent. The Pigtail just might be a bit truer sounding to the originals since Pigtail analyzed the old bridges and uses the exact same alloy but the Monoaxe intonates better so that's what I have on there now.
  15. NachoMan77
    NachoMan77 Junior Member
    5
    0
    Jan 6, 2016
    Another MojoAxe believer here... Dan is the Man!
  16. Ph03n1x
    Ph03n1x Senior Member
    1,547
    900
    Dec 29, 2009
    How much does nickel plating cost? I've got a grinder and figure I could make similar ridges on a wraptail...
  17. charlie chitlins
    charlie chitlins Senior Member
    2,698
    2,100
    Feb 8, 2011
    Plating is getting shockingly expensive and aggressive polishing and buffing could easily undermine your work getting the right profile. I'd polish and buff myself an ask someone to plate it as is. And a good plater will do copper first.
  18. stilwel
    stilwel Senior Member
    160
    224
    May 19, 2009
    Mojoaxe...
    They just work and everything else looks wrong.
    My Grandad's '59 Special
  19. jaik
    jaik Senior Member
    651
    607
    Jan 8, 2012
    I had a Leo Quan Badass bridge on my 57 LP Special for decades (like the adjustable pigtail in your pic) , I replaced it last year with a Mojoaxe because my Junior & Goldtop had much ballsier sounds, and the mojoaxe did impart a bit more lows and immediacy. The feel changed a bit and I was so used to how it was that I'm not sure it was a trade off I should have made. But if you aren't mega attached to the feel (ala you think it needs a fret job etc) then go for it. I think its best, for my taste, to have the least number of moving parts between the string and the wood, and a solid wraptail gets that done.
    I also did a similar swap with another adjustable bridge on a 60s SG Jr , something with all kinds of hideous "fine tuners" etc, that I replaced with a solid Faber wraptail, and it made a massive improvement for that guitar.
