Modified R8 Les Paul Control Cavity help!
Discussion in 'Historics & Reissues' started by ssuper1, Jul 26, 2017.
  1. ssuper1
    ssuper1 Junior Member
    5
    2
    Jul 26, 2017
    Hello,
    First post... so go easy on me.
    So I got this pre owned 2007 R8 Les Paul VOS and am trying to figure out what the previous owner did with the modifying of the control cavity. I'd like to know what is stock and what is mod. I'd like some insight into what the mods might be trying to achieve in the sense of tone or utility.
    I'd also like to know if it 50's wired or modern?
    Any help, thoughts are welcome.
    Sorry having a little trouble getting these up with 3rd party hosting [​IMG]
    ... here are temporary links for the photos needed for viewing.
    https://cvws.icloud-content.com/B/AX...YSsfh-pUA&cd=i
    https://cvws.icloud-content.com/B/Ae...eE7JkO7Xk&cd=i
    Pappy58 likes this.
  2. DanD
    DanD Senior Member
    481
    407
    Feb 23, 2009
    Looks like they updated the pots and caps with 50s style wiring. Looks to have a .015 cap in the neck spot and a stock value .022 in the bridge.
    The .015 in the neck adds a little brightness to neck position.
    Mods looks to be well done. Caps look like RS's paper in oil style.
    It looks to be better than what came in there from Gibson and many folks do exactly this mod to their Rs.
    XpensiveWino likes this.
  3. ssuper1
    5
    2
    Jul 26, 2017
    Thanks Dan, I was considering dropping in 1956-1960 Luxe Oil-Filled .022mF Bumble Bee Capacitors
    at $ 59.00. What would you suggest?
    Also what does 50's wiring do for the tone?
  4. Mr. Pickles
    Mr. Pickles Mr. Pickles loves you. Mwah! ♥ Premium Member
    3,661
    2,676
    Jul 6, 2015
    Mr. Pickles likes this thread.
  5. Oranjeaap
    Oranjeaap Senior Member
    8,145
    3,723
    Feb 25, 2010
    Leave it as is, you're wasting money.
    Frogfur and PierM like this.
  6. THDNUT
    THDNUT Senior Member
    14,642
    20,038
    Feb 5, 2012
    Hey ssuper1, we don't beat up on new people around here. What ever gave you that idea? :rofl:
    Welcome to the forum.
    As for your question, I have no idea. All my LPs have stock wiring.
    DarrellV and Frogfur like this.
  7. LP Traditional
    LP Traditional Senior Member
    491
    467
    Oct 11, 2012
    It makes the guitar retain some treble when you turn down the volume pot on the guitar.
    Modern wiring gets a little darker when you turn down.
  8. rclausen
    rclausen Senior Member
    2,587
    1,985
    Nov 9, 2011
    Yep, looks like an RS Guitarworks harness. There's no need to change a thing
    framos likes this.
  9. DarrellV
    DarrellV Make the Switch for the Better! Silver Supporter Premium Member
    10,916
    14,122
    Nov 1, 2016
    THDNUT and bulletproof like this.
  10. DanD
    DanD Senior Member
    481
    407
    Feb 23, 2009
    As has been posted I'd leave it as is. The Luxe set is just a different brand of the same thing you already have.
    As to what 50s wiring does for tone? You can compare the effects of 50s wiring in your guitar to a late model LP Standard. The late model STDs use modern wiring and Burstbuckers. The pups may not sound the same but you should be able to hear a subtle difference in the tonal response when changing the level of the volume knobs. As was posted above you should notice that as you remove volume on the modern wired guitar it's tone will get darker. Your guitar should retain more high end as the volume is lowered.
    Some like 50s wiring some like modern. The only way to tell is to play some of each and see which arrangement you prefer. :thumb:
  11. rockinlespaul
    rockinlespaul Oxblood Addict V.I.P. Member
    8,959
    7,969
    Aug 12, 2007
    Its been upgraded with good stuff...leave it.
  12. bulletproof
    bulletproof aka tarddoggy V.I.P. Member
    6,835
    11,090
    Jun 1, 2011
    +1
  13. GT40
    GT40 Senior Member
    155
    238
    Jul 1, 2017
    But you loose some volume when you roll back the tone.
    It's a passive tone/volume circuit with minuscule signal passing through. There are tradeoffs no matter how you wire the controls.
  14. JMB1984
    JMB1984 Premium Member
    4,701
    2,873
    Feb 26, 2011
    Very true. Though I personally find it easier to compensate for the volume loss with a clean boost if I absolutely feel the need to. It can be more difficult to have to compensate for the modern wiring darkness. All depends on playing style and how the player uses the controls though.
  15. Sct13
    16,716
    19,296
    Sep 18, 2011
    welcome to the forum...
    Play it awhile and experiment with the controls, now that the secrets of tonal bliss are uncovered for you, it is you that must decide what is right for your ears.
  16. jamman
    jamman Premium Member
    9,027
    7,251
    Oct 1, 2010
    Looks like a Stock RS harness . Me , I'd be keeping that as I've found I like the older RS pots more then the newer 1's ... But to each , their own . But if you don't care for it , swap it out , since the guitar has already been modified , it makes no difference now .
    Nice Axe ,btw :cheers:
