MLP/Bartlett Retrospec Giveaway!
Discussion in 'Luthier's Corner' started by alk-3, Apr 29, 2013.
  1. gmack73
    gmack73 Senior Member
    1,300
    1,126
    Mar 9, 2013
    Sweet looking tone boxes. I'd feel unworthy to even touch one.
  2. parts
    parts Senior Member
    12,765
    23,735
    Oct 13, 2010
    Fantastic shop..and beautiful guitars...
    I'm sure they play like they look..incredible..
  3. TOMMYTHUNDERS
    TOMMYTHUNDERS Senior Member
    14,449
    25,535
    Jul 15, 2009
  4. Hack
    Hack Senior Member
    16,168
    43,546
    Jul 15, 2010
    This is great!
    That looks like a great piece of work. I would love to put my hands on one.
    One small question though... why wouldnt you be doing a Les Paul on here?
  5. Shadowplayer
    Shadowplayer Senior Member
    8,657
    5,538
    Nov 1, 2012
    That guitar in sunburst is amazing!
    2 people like this.
  6. Roman4405
    Roman4405 Senior Member
    5,278
    8,552
    Mar 21, 2012
    Very cool
  7. Chicago John
    Chicago John Senior Member
    4,781
    7,046
    Feb 9, 2009
    Beeyootiful :thumb:
  8. alk-3
    alk-3 MLP Sponsor
    2,050
    3,242
    Jan 8, 2008
    Okay, on with the build!
    So the first thing i always do is decide on the tonal range i want the guitar to land in. i decide if i want it to be bright, or thick, or a mix with a mid punch.. The best way i know how to determine the outcome is selecting lumber that plays well together. If I'm going for a mid range boost, I will select lumber that does not have a fast decay when tapped hard with another board, or even with my knuckles. I want it to ring out, and have a good punchy resonance.
    I start with the body wood, and select the best piece from my collection for the job, then I move on to select the rest of the pieces that will complement it.
    Today I will deal with the fingerboard.
    I start by sawing up the piece of lumber into rough fretboard sized pieces.
    I have a selection of Cocobolo, and Brazilian rosewood. For this guitar I have decided to go with the cocobolo for a variety of reasons, but alongside this build, I will be completing a les Paul, and that will get Brazilian Rosewood.
    The tone of this piece is really exactly what I like to find. A good solid even tap tone up and down the whole board. I want the board to be suitably dried out, which means old growth lumber is a must here. It needs to be stable, and have the pitch and resins hardened in a way that only time can accomplish.
    You can see how vibrant the freshly sawn and dressed boards are. This red will fade very quickly, and become the characteristic rosewood brown, even before the guitar is finished.
    Now I lay a metal template over the board, to be sure I have a piece that will have no defects, or inclusions that would cause any issues down the line. These boards are all well over sized, and very clean, so no issues here.
    Now I crosscut to length. This is still of course quite over sized.
    I do the same with the Brazilian rosewood. This stuff is pretty amazing.
    I get a lot of questions about this stuff, and how to tell if itÂ’s real. The only way to actually tell is to smell it. There are so many rosewoods that can look identical to this stuff, but none of it smells anything even remotely like Brazilian. The best way I can describe the smell is to say it smells like root beer. If you cut a piece of this, the entire shop will almost instantly smell very strongly. There is no mistaking it.
    Here is the piece directly after re-sawing into blanks:
    And here is the end grain. You can see the distinct difference between the white sapwood and the dark heartwood. The darker part of the wood is actually dead, and it turns dark as it stands as a tree. The whiter surrounding wood carries the nutrients to the leaves, and as such, is called sapwood. This is true of all lumber. There is always a sapwood outer layer. With rosewood, and with most woods, this inner heartwood is what is used as lumber, with the outer sapwood being discarded.
    This is opposite with maple however. Maple heartwood is brown, and undesirable, which leaves the outer layer as the sapwood.
    Now before I get too ahead of myself here, I need to make up a few test boards. This will allow me to setup the machinery along the way with a board that will never be used.. If anything goes wrong, I do not lose a valuable fretboard.
    I use maple for this, because it is a hardwood, and I have plenty of it around.
    The next step is to construct a set of fixtures that will help me to rough out the radius on the fretboard. I start by making a plywood guide system, and I will show you how it works.
    Here is picture of my surface planer. Its 13" across, and does a good job if flattening boards that have been jointed. This one, however, does a second function as well, which I will be utilizing now.. It takes a bit of work to set it up properly.
    I remove the top of the machine to expose the inner workings.
    I loosen all the Allen fittings to release the long planer blade. They just slide out, one at a time. There are three of them.
    In the centre there is a small block, with two small spacers that lock the centre of the blade in place. I need to remove these.
    And then the larger spacer
    I also remove the two large spacers on either side, and those get stored away. They are only needed when the planer is set up for thickness planing.
    I ordered some custom cut knives for this machine from a local place that cuts these for custom molding applications.
    Here is one side
    And the other side
    And all three together
    14 people like this.
  9. alk-3
    alk-3 MLP Sponsor
    2,050
    3,242
    Jan 8, 2008
    I set them into the machine loosely, and measure to be sure they are exactly in the centre, and all of them are exactly lined up.
    I lightly tighten the screws to hold them in place.
    Once I'm satisfied they are all lined up, a really crank them down tight. We don’t want this thing flying out at high speed!
    Now I can adjust the dust guard down right up against the blade. We want maximum dust removal for this step. Any loose shaving left unnoticed can seriously damage the fretboard by changing the clearance between the board and the cutters.
    Now we can finally make the first cut.
    Here is the result on one of those scrap pieces of maple. Not bad!
    Now I mount the real board onto the guide.
    I like to apply a light coating of fretboard oil to soften the brittle fibers, and reduce potential tearout.
    And here is the Brazilian board for the Les Paul. This is un-oiled, because Brazilian does not tend to tear out the same way the Cocobolo does.
    And away we go!
    19 people like this.
  10. BillB1960
    BillB1960 Senior Member
    15,908
    21,224
    Jun 1, 2008
    I love build threads! :applause:
    8 people like this.
  11. alk-3
    alk-3 MLP Sponsor
    2,050
    3,242
    Jan 8, 2008
    Thank you guys!
    I will be doing touching on a Les Paul build alongside this one, but the raffle guitar is a Retrospec.
    2 people like this.
  12. corbo
    corbo Senior Member
    1,037
    769
    Feb 23, 2012
    liking this thread, thanks
    1 person likes this.
  13. ehs5mw
    ehs5mw Senior Member
    1,856
    918
    Feb 24, 2010
    This thread is sweet.
  14. Shadowplayer
    8,657
    5,538
    Nov 1, 2012
    Aw yea, pictures!
  15. SLewis
    SLewis Senior Member
    2,084
    3,359
    Oct 18, 2010
    This is awesome. :thumb:
  16. Malikon
    Malikon Henshin! V.I.P. Member
    65,663
    180,552
    Jan 21, 2010
    Sweet. Great shop pics. Thanks for posting them.
  17. decoy205
    decoy205 Senior Member
    7,889
    1,879
    Sep 10, 2007
    Looks awesome thanks for sharing!
  18. bscenefilms
    bscenefilms Premium Member
    8,748
    18,958
    Nov 13, 2009
    Love the shop pics and the step by step. Bravo, sir. Very cool!
  19. Thundergod
    Thundergod Senior Member
    10,818
    10,993
    Sep 11, 2008
    I want in.
  20. confused
    confused Senior Member
    725
    626
    Sep 4, 2012
    Oooh, wow! Excited already!
    It's great for you to do this for the forum.
