Minimalism in the Signal Chain
Discussion in 'Amp Modeling' started by Rocco Crocco, May 13, 2017.
  1. Rocco Crocco
    Rocco Crocco Senior Member
    6,573
    7,776
    Feb 8, 2013
    I have become very used to loading up on effects in my signal chain. I always start with a compressor first, and making sure I have reverb and delay at the end of the chain. These effects are, for the most part, always "on".
    Yesterday and today I was messing around with "just an amp" in the chain. I did add distortion/overdrive onto some amps, and hi and low cut EQ is necessary on the Helix, but nothing else other than that. It amazed me how much nuance in the tone is present with no effects in the chain.
    All the Marshalls and the Soldano are just jumping out of the speakers! The "Line 6 Epic" amp model (easily my favorite hi gain amp in Helix) is just crushing! I am going to use these new presets at rehearsal with the band to see how they sit in a live mix, but at home they are fun as hell.
    Pop1655 and Donal like this.
  2. matthew bear
    matthew bear Senior Member
    4,287
    4,819
    Nov 9, 2008
    it's always a good idea to play dry for a while, keeps the chops up!
  3. dissaffected
    dissaffected Senior Member
    624
    740
    Feb 1, 2015
    YES....more is rarely better!
  4. KenG
    KenG Senior Member
    6,266
    3,334
    Sep 13, 2009
    I'm the opposite in that I rarely use any effects at all.
    lunchbox likes this.
  5. lunchbox
    lunchbox Senior Member
    6,668
    8,849
    May 29, 2011
    SG -> Tuner -> Crybaby -> Xotic clean boost -> Orange CR120H.
  6. Donal
    Donal ¯\_(ツ)_/¯ Premium Member
    13,456
    13,075
    Aug 25, 2009
    What I have found is that you can utilise the Amps, Speakers, etc. much better as in getting them to an optimal volume/gain setting and then I put a volume pedal behind the speaker if I want to bring down volume and keep the sound. I found I was using less effects and still had great sounds.
    I changed all mine last week to the above (except my AC/DC sound).
  7. Pwrmac7600
    Pwrmac7600 Premium Member
    7,998
    6,244
    Jun 17, 2014
    Yup! This is exactly how I run my Axe FX. Amp and Cab, VERY rarely I might add a reverb set to a small room/studio verb. But then again, this is how I ran my analog rig as well. IMO Even on a analog rig the more crap you start to add into the signal, the more saturated, and indistinct the tone starts to become. I like to use FX as special FX rather than constants.
