Mini humbucker conversion question
Discussion in 'The Custom Shop' started by irocdave12, Apr 19, 2017.
  1. irocdave12
    irocdave12 Senior Member
    2,354
    2,850
    Jun 22, 2011
    If I bought a 2017 p90 equipped tribute could I just buy mini humbuckers and just bolt them in? Or is wood work involved and if so what?
  2. MSB
    MSB Senior Member
    1,523
    1,212
    Jan 21, 2015
    it should have the metal plate in the bottom of the pickup cavity that should allow you to install the mini hums w/o any routing
  3. MSB
    MSB Senior Member
    1,523
    1,212
    Jan 21, 2015
    should look like this
  4. kevinpaul
    kevinpaul Senior Member
    17,663
    27,230
    Apr 7, 2011
    I just put them on my Firebird, you will need rinds for the mini humbuckers. You will need to drill four holes to mount the rings that hold the mini humbuckers on the guitar.
  5. irocdave12
    2,354
    2,850
    Jun 22, 2011
    MSB you're the man thanks tells me everything I was looking for
  6. IGRocker
    IGRocker Senior Member
    491
    304
    Mar 17, 2013
    Mounting them in a les Paul will be different than in a firebird. Far less modification required :thumb:
  7. chasenblues
    chasenblues Senior Member
    20,398
    29,670
    Apr 2, 2007
  8. Kris Ford
    Kris Ford Senior Member
    4,754
    4,033
    Dec 17, 2011
  9. chasenblues
    20,398
    29,670
    Apr 2, 2007
    Are those other style of mounting brackets commercially available?
    Other than through someone selling them on Reverb/Flebay.
  10. Kris Ford
    4,754
    4,033
    Dec 17, 2011
    Not sure man...might just be the parts places when they strip 'em out.
