Melody Maker to Custom Conversion
Discussion in 'The Custom Shop' started by maxsmart2003, Jul 9, 2016.
  1. maxsmart2003
    maxsmart2003 Member
    45
    59
    Apr 11, 2016
    Hi All, Not a new member but my first post. I am taking a 2014 Melody Maker and doing a conversion to a single pickup, Black Custom. I will post pics and stuff. Here is how she started out, (well, I repainted it once already) Hope you enjoy
    2 people like this.
  2. maxsmart2003
    maxsmart2003 Member
    45
    59
    Apr 11, 2016
    Steaming off the fretboard.
  3. maxsmart2003
    maxsmart2003 Member
    45
    59
    Apr 11, 2016
    Fret board is off and now to steam off the neck. I used a Wagner wallpaper steamer and a basketball needle to build a steamer. Drilled some holes to inject steam into the mortise joint
    Drfredo, Geronimo and Who like this.
  4. maxsmart2003
    maxsmart2003 Member
    45
    59
    Apr 11, 2016
    Clamped the neck down to keep it from warping while the steam dried out. Maybe overkill but what the heck...
    1 person likes this.
  5. maxsmart2003
    maxsmart2003 Member
    45
    59
    Apr 11, 2016
    Stripping the body. I like to use Citristrip since it doesn't stink the place up.
    2 people like this.
  6. maxsmart2003
    maxsmart2003 Member
    45
    59
    Apr 11, 2016
    Need to plug the P90, control and switch holes...
  7. maxsmart2003
    maxsmart2003 Member
    45
    59
    Apr 11, 2016
    Now to route the bridge PU in the correct location...
    2 people like this.
  8. maxsmart2003
    maxsmart2003 Member
    45
    59
    Apr 11, 2016
    Starting on the new fret board, ebony. Some help from a template made by one of the forum members. A special thanks to Peter and Tom for hooking me up! That's it for now. I can post some pick of the binding channel routing jig I built if anyone is interested. I included a Before and After of another MM conversion below which I have detailed pics of if anyone is interested. Thanks for checking it out.
    2 people like this.
  9. maxsmart2003
    maxsmart2003 Member
    45
    59
    Apr 11, 2016
    Before and After
  10. Troy McClure
    Troy McClure Senior Member
    472
    218
    May 4, 2016
    Love these conversion type threads. Are you going to thicken the body at all? And if not will bother doing back binding as I guess it'd look a little odd having both bindings so close to each other.
    Plus another quick question, do witness lines show thru where the neck pickup rout has been filled or is there some trick to stop it eventually showing up. I'm considering doing the opposite of converting the pups from humbuckers to p90 on one of my old guitars.
  11. maxsmart2003
    maxsmart2003 Member
    45
    59
    Apr 11, 2016
    Hi Troy
    I am going to keep the body thin as I am too old to hold up the thick ones anymore! I have a Custom Lite that is just right and they sound great too! SO no binding on the back side.
    I filled the lines with some CA glue and sanded since it will be black when complete. Seamless to a razor blade so I believe it will be all good. Thick CA did the trick.
    Jim
    steveb63 and Troy McClure like this.
  12. TheZ
    TheZ Senior Member
    996
    609
    Nov 9, 2009
    Nice work so far! Thanks for sharing!
  13. kezian
    kezian Senior Member
    312
    76
    Dec 31, 2009
    a melody maker with a sunburst, maple top, and binding? never seen one like that before
    THE N.E.M.O likes this.
  14. maxsmart2003
    maxsmart2003 Member
    45
    59
    Apr 11, 2016
    Hi Kezian,
    It wasn't like that at first :)
  15. maxsmart2003
    maxsmart2003 Member
    45
    59
    Apr 11, 2016
    I Completely Ripped this design concept for the binding router off another member. I apologize I do not remember who, but if they claim it, I will give them credit. Sorry I did not keep track at the time. My Most humble apologies.
    Anyway, this design works amazingly well and rides the contour of the body much better than trying to keep it level by hand.
    Used a couple of ball bearing drawer glides and some plywood to make this jig. There are some credits I need to come up with but do not have right now. Lost a computer and some links. But will try and find them.
    I could not have done any of this without the information from this forum. Thank You All!
    Mfontanella likes this.
  16. maxsmart2003
    maxsmart2003 Member
    45
    59
    Apr 11, 2016
    Trying to cut the headstock for binding. %$#&^$% Decided to try a purfling cutter as the binding cutter seemed like it would really be hard to use and cause more repairs than I expect already :)
    2 people like this.
  17. maxsmart2003
    maxsmart2003 Member
    45
    59
    Apr 11, 2016
    So.... If you ever decide you want to bind an unbound headstock, try "String Theory" instead! It's gonna work out and I will post some pics, but it is much, much more work than I thought and I will have to do some fairly minor repairs. Keep your chisels sharp and back off when you first sharpen them! :wow:
  18. Mr. Beef
    Mr. Beef Custom Refins/Restoration Premium Member
    355
    448
    Sep 15, 2015
    Looking good! I had success with a dremel for the headstock binding... do you think your method is easier?
  19. cdscarter
    cdscarter Senior Member
    222
    160
    Oct 22, 2012
    Can I just ask, would it not have been easier to remove the veneer of the headstock and make a new one from scratch?
  20. maxsmart2003
    maxsmart2003 Member
    45
    59
    Apr 11, 2016
    To answer both Mr. Beef and cdscarter in order. Yes the dremal would most likely be easier, and removing the veneer and replacing with a slice of holly I have would also be easier. However, I am doing this the hard way to learn all I can. I do not have much experience with chisels and this is an opportunity to do some detailed work (sort of). Yes I am making mistakes and gouges that I did not plan on, but, this also gives me the opportunity to repair those and lean even more. I enjoy the challenge. I SOOO wanted to do it the ways you both suggested and would have been most likely finished with this part, I however, just wanted to do it the hard was at least once. Sucker for punishment :)
    Thank you both for checking it out!
    Jim
