Maple Top Weight
Discussion in 'Historics & Reissues' started by JUNAE9, Oct 5, 2017.
  1. L96A1
    L96A1 Senior Member
    422
    417
    Oct 8, 2012
    Not sure about figure and plain, hope this helps.
    jojo and RAG7890 like this.
  2. PierM
    PierM Black & Gold Premium Member
    3,317
    5,315
    Aug 19, 2016
    Unless it's Hard Maple, it's all Bigleaf/Silver Maple, doesn't matter if flame or plain (figure in the grain are not related to species).
  3. L96A1
    L96A1 Senior Member
    422
    417
    Oct 8, 2012
    I’ve always wondered if plain tops and those with the mineral steaks can be soft maple.
  4. PierM
    3,317
    5,315
    Aug 19, 2016
    I'm pretty sure I've seen hard maple with streaks before.
  5. L96A1
    L96A1 Senior Member
    422
    417
    Oct 8, 2012
    Sorry for my poor English, I meant we hear people say eastern hard maple tend to have the streaks, and I wondered if the westerns have streaks too, just less.
    PierM likes this.
  6. Wingtip4
    Wingtip4 Senior Member
    296
    92
    Jun 8, 2009
    The answer is yes, there is hard maple and softer maple that might weigh differently, he might be saying that Gibson mamy times skimps On the top thickness, but back in the day it was “8 poinds, 8 ohms.” As rule of thumb.
  7. Sowtondevil
    Sowtondevil Junior Member
    1
    2
    Nov 6, 2013
    As a luthier I believe the figuring to be a red herring when considering the weight of your finished instrument. The density of the tone wood and hence its weight when when fully seasoned is determined by the rate of growth i.e. the closeness of the annual rings or grain. But in the overall scheme of things the difference in weight is marginal. Select finely figured Maple if that is the look you are after - don't get too hung up about the weight.
    PierM and RAG7890 like this.
  8. vlammie
    vlammie Junior Member
    10
    9
    Aug 3, 2016
    I can't believe this is my first post here, very long-time reader though. :)
    I think I can add some thoughts to this topic. My experience is not with historic gibsons, but I have been playing a couple of months with 12 prototypes of a guitar that's not on the market yet.
    The tops on these guitars are in 3 categories:
    Solid AAA flame top
    Solid plain top
    Laminated plain/flame top (AAA on top of course)
    The maple used for the plain tops (and the lower part of the laminated tops) is more dense than the AAA flame maple.
    The difference in weight between all these guitars is very clear. All the solid AAA's are below 4kg, all plain tops and laminated tops are at least 500 grams heavier, some closer to 1kg.
    These prototypes are all made in the same factoy in Japan, with the same 1 piece mahogany backs, same pickups, etc. The top wood has the same impact on weight and sound on all of them, although there are always minor differences of course. FYI, all of them are chambered, but not a lot. Definitely less than a chambered gibson, or a gretsch duo jet.
    In general, the lighter ones with solid AAA top sound more 'airy' and even have some semi-acoustic properties when played unplugged.
    The ones with a plain top or laminated top sound more 'solid', and exhibit less of the semi-acoustic properties.
    I didn't expect a big difference in different types of maple, but it's very distinctive in my limited experience.
    L96A1 likes this.
  9. Pleximan
    Pleximan Senior Member
    418
    413
    Aug 9, 2013
    I've never built my own guitar. I do have a pretty good ear for tone though. The tap test isn't always a good indicator of tone on wood, but it often will give you an idea of if you have a lively piece of wood. The resonance and piano key like quality of wood; when struck is something to look for. From my own experience heavier les pauls usually (over 9.5lbs) are very midrangey and chunky in the low end. Lightweight Les Pauls (under 8lbs) usually are very airy, and bright in the high end, and the mid range isn't very strong, the lows are fairly subdued and quacky. That's my experience. You could probably find examples of just the opposite of what I said, but. This is coming from a guy who's played tons of Les Pauls. I think a good weight is in the 8lbs range. Imo
    L96A1 likes this.
  10. freebyrd 69
    freebyrd 69 Silver Supporter Premium Member
    10,202
    18,063
    Sep 29, 2011
    In this case you are comparing different types of Maple used in completely different ways (laminating). Do all of the pickups read the same? How about the harnesses?
    Not to be a downer, but acoustic properties mean little or nothing on an electric guitar.
  11. L96A1
    L96A1 Senior Member
    422
    417
    Oct 8, 2012
    Agree to this.
    vlammie and Pleximan like this.
  12. freebyrd 69
    10,202
    18,063
    Sep 29, 2011
    I've got two over 9 that are stellar. Weird.
    PierM likes this.
  13. THDNUT
    THDNUT Senior Member
    15,312
    21,534
    Feb 5, 2012
    This is my best sounding R9. It weighs 9 1/2 lbs. I ignored the weight and bought it because it sounds stellar.
    L96A1, Bobby Mahogany and RAG7890 like this.
  14. Pleximan
    418
    413
    Aug 9, 2013
    I'm sure there are some stellar 9 pound plus Les Pauls. For me 9.5 lbs seems to be about the cut off. When it comes to comfort under 9 lbs is where I'd like to be. A LP much under 8 just didn't sound right to me. Thin comes to mind, and nasally.
  15. freebyrd 69
    10,202
    18,063
    Sep 29, 2011
    Looks stellar too!!
    THDNUT likes this.
  16. vlammie
    10
    9
    Aug 3, 2016
    I know, you are right of course, stuff like pickup height, how old the strings are, etc. all matter.
    But this was a rare case of 12 almost identical guitars, with identical pickups, and everything else, the only difference was the type of maple used for the top.
    And it is a noticeable difference, acoustically and (to a lesser degree) amplified.
    freebyrd 69 likes this.
  17. scovell001
    scovell001 Senior Member
    197
    100
    Sep 3, 2015
    Just to put things into perspective:
    Doug & Pat's gold top weighs 8lb
    Mark Knopflers 1958 weighs 7.90lbs
    The Seven Decades 1958 85495 weighs 8.1lbs
    There's 'nothing' wanting about the tone in 'any' of those guitars - go figure.
    vlammie and DanD like this.
  18. RAG7890
    RAG7890 Premium Member
    14,477
    22,950
    Jul 11, 2010
    May as well Post this one in here.
    :cheers2:
    L96A1 and vlammie like this.
  19. BBD
    BBD Senior Member
    2,042
    8,071
    Jan 16, 2017
    Sure, because there's no strong correlation between tone and weight.
