Made in Japan Neck Profiles
Discussion in 'Other Single-Cuts' started by GammyBird, Sep 10, 2011.
  1. GammyBird
    GammyBird Senior Member
    20,887
    13,999
    Nov 14, 2009
    I have taken some measurements of the necks on my MIL LP's and here's the results....
    PDF attachment.....
    Anybody else have measurements?
    Matty, joebonsai, JVsearch and 5 others like this.
  2. reborn old
    reborn old Senior Member
    2,561
    1,619
    Jul 24, 2010
    Good idea Gammy.
    My two Tokai LS's and late 1980 Greco EGF all have '59 dimensions based on the "original burst averages" table posted below. 22.4 + 24.5 (EGF was 24.25 at 11th fret).
    I was actually amazed at how they are all within such close measurement tolerances everywhere (other than the Greco neck cutaway).
    Deed J and GammyBird like this.
  3. freebird2
    freebird2 Senior Member
    335
    128
    Oct 31, 2010
    Here's what I have collected over the years for "traditional/original" Les Paul shaped MIJ guitars . I did not include data that I have for other MIJ "Gibson-style" guitars. I never measured width, just neck thinkness. In the table you'll see that I've included Gibson Les Paul data. That data comes from the Beauty of the Burst book.
    Backstage and GammyBird like this.
  4. freebird2
    335
    128
    Oct 31, 2010
    Yup, that's the table I'm refering to. Two minute apart posts.
  5. GammyBird
    20,887
    13,999
    Nov 14, 2009
    I'm hoping to collect measurements from different LP's and put it in a table similar to the one in Beauty of the Burst. I got the urge to measure my guitars from all the questions regarding the ObG 59R being a 60's profile neck and not a 59 profile.
  6. freebird2
    335
    128
    Oct 31, 2010
    Just an fyi - all measurements were made using the same Cen-Tech micrometer.
  7. GammyBird
    20,887
    13,999
    Nov 14, 2009
    Thanks. Mind if I borrow your data? :)
  8. jacco
    jacco Senior Member
    4,259
    1,577
    Aug 14, 2010
    I've got a lot of measurements too, but first; where exactly did you guys measure; proximal, distal or on the fret?
  9. slapshot
    slapshot Senior Member
    22,963
    23,648
    Aug 21, 2010
    for you neck measurers .... do you take the ****ing strings OFF when you measure?
  10. wulfman
    wulfman ABB Fan Premium Member
    8,356
    11,432
    Apr 2, 2010
    I measure from the fretboard center, right behind the fret. I also use 100 yen plastic callipers so .5 mm is the most accuracy I get.:)
  11. jacco
    jacco Senior Member
    4,259
    1,577
    Aug 14, 2010
    Can you rephrase that Harold? Do you measure north or south from the fret?
    I measure north from & against the fret, is that the way to go?
  12. wulfman
    8,356
    11,432
    Apr 2, 2010
    I always measure from the fretboard but the position where I measure is right behind the fret (headstock side) as opposed to in front (bridge side). If you mean north is towards the headstock it sounds the same to me.
  13. jacco
    jacco Senior Member
    4,259
    1,577
    Aug 14, 2010
    Thanks, that's were I measure too
  14. JDB
    JDB Senior Member
    6,703
    5,925
    Oct 15, 2010
    would it really make any difference what side of a 2-3mm fret you measured from?
  15. joebonsai
    joebonsai Senior Member
    1,942
    1,149
    Jun 22, 2008
    To make it clear
    This is the measure Mark's Guitar Loft does
    :hippie:
  16. wulfman
    8,356
    11,432
    Apr 2, 2010
    The 11th vs. 12th fret measurement is interesting, any idea behind the reasoning for one or the other?
  17. freebird2
    335
    128
    Oct 31, 2010
    Not at all. Please do.
    GammyBird likes this.
  18. jacco
    jacco Senior Member
    4,259
    1,577
    Aug 14, 2010
    BOTB measures at 1st & 11th, if you want to compare to that, maybe it's best to do the same.
    No, not really, because it's still a hand measurement which won't have repeatable results & most of us don't have professional equipment, making margin of error even bigger. Uniformity helps a little bit though.
  19. GammyBird
    20,887
    13,999
    Nov 14, 2009
    Ha ha....yes! :thumb:
  20. GammyBird
    20,887
    13,999
    Nov 14, 2009
    I did my measurements dead center....should I re-do my measurements?
