LPs and Heavy Metal....Namely C# and String gauge...question
Discussion in 'Gibson Les Pauls' started by Macronaut, Oct 6, 2017.
  1. Macronaut
    Macronaut Silver Supporter
    1,036
    896
    Nov 23, 2016
    I recently bought my 2017 LP Tribute to use as a platform for experimenting. My original intention was to try different pick ups but, I decided to go a different direction first...I think.
    I want to set it up for dropped C# tuning for certain Iommi riffs and the like.
    So far I'm thinking perhaps 12-54s for string gauge, so hopefully I won't need to adjust my neck much, if any. If I do this, I will likely need to re-slot my nut (I suppose I should have a spare on hand, just in case...).
    I almost bought some hot pick ups instead but, it seemed to make more sense to go this route first, since I'm not a "Metal Head", it's just that I'm in the mood to express myself that way sometimes so, I don't need to go all out.
    Any thoughts (specially from those that do or have done.....
    Thanks ahead.
  2. Shadow Explorer
    Shadow Explorer Senior Member
    200
    172
    Apr 26, 2017
    Hello I've had 6strings tuned to C for years, 12-54 sounds fine, consider 13-56 as well, after that it's just a matter of preference.
    When I started to downtune, I did it with 11s, needless to say that it was very very soft setup, yet not impossible.
  3. Britbender
    Britbender Senior Member
    291
    352
    Dec 24, 2010
    11-56 is perfect for C#, depending on current setup you'll probably have to tighten the rod a nudge.
  4. Pushead
    Pushead Senior Member
    766
    273
    May 26, 2007
    I play .012-.056 in C standard, and .010-.052 in E standard. For C# I'd probably stick with the 12s.
  5. Strobe
    Strobe Junior Member
    22
    23
    Jul 2, 2017
    I put mine in drop-C for a long time when I was playing in a melodic death metal band (I am a metal head, but I enjoy quite a variety of music). I used the Ernie ball Skinny top / heavy bottom when I did it. That said, I tend to go for a lighter gauge of strings on my standard tuned guitars.
    I think a good general rule is that for every full step you go down from standard, going up a gauge will make it feel about the same. So if you like 10's in E standard, use 12's in C standard. If you like 9's, go 11's, etc. If you want to drop the lowest string as well, consider a hybrid like the skinny top / heavy bottoms - D'addario makes a variety of NYXL's with this sort of profile.
    Iommi himself played 8 gauge strings I recall reading - all tuned down to C# standard. It really comes down to taste in tension. Just remember that if you change the tension a lot, you probably have to change the guitar setup. If you change the string gauge a lot, you might need to re-cut the nut.
    Keep it heavy my friend! Great guitar, enjoy!
  6. Macronaut
    1,036
    896
    Nov 23, 2016
    Thanks everyone for you input. This gives some things to consider.....
  7. Macronaut
    1,036
    896
    Nov 23, 2016
    I did read that Tony used lighter strings. However, I do have some NYXL 12/54s on hand and will start there.
    I started to purchase a guitar (non LP) specifically for this purpose. I was just wondering what some here have accomplished with their LPs concerning dropped C# (or similar) for Metal type sounds/feel.
  8. jojo
    jojo Senior Member
    1,434
    898
    Sep 27, 2009
    Its all personal preference. I've used 10s in drop C for over 20 years.
  9. DarrellV
    DarrellV About as sharp as a bowlin' ball! -NPM Silver Supporter Premium Member
    17,145
    38,980
    Nov 1, 2016
    Maybe this will help in some way...
  10. Macronaut
    1,036
    896
    Nov 23, 2016
    I do, truly appreciate the chart provided. However, I got a head ache trying to make sense of it. I suppose I need it dumbed up a bit.
    DarrellV likes this.
  11. DarrellV
    17,145
    38,980
    Nov 1, 2016
    Ha!
    I was hoping you could figure it out! :laugh2:
    We're in the same boat. :dude:
