LP Special, T.O.M or wraparound?
Discussion in 'Gibson Les Pauls' started by Jakatone, Jun 11, 2017.
  1. Jakatone
    Jakatone Member
    54
    19
    Feb 14, 2012
    Hi guys, so long story short, i recently recorded with a original 57' single cut special and it was hands down the best sounding guitar i have ever played. Since then I've been trying to get something similar, be it Gibson or a handmade. The original had:
    - unpotted P90's ( obviously )
    - very lightweight aluminum wraparound.
    The pickups are relatively easy to get with all the boutique stuff, the tailpiece is a major decision since it's hard to turn a TOM into a wraparound and vice versa.
    What are your thoughts about the wraparound playing a big role in the sound of a Special?
  2. Cjsinla
    Cjsinla Senior Member
    3,273
    2,405
    Jul 7, 2014
    I would think that the all mahogany construction and the P90's are bigger contributors to the tone than anything else. I have owned a number of P90 equipped guitars with and without TOM/ABR bridges and they have all sounded great.
  3. Jakatone
    Jakatone Member
    54
    19
    Feb 14, 2012
    Also a big contributing factor, I agree. Did you hear any audible difference between the two bridges? The 57' had a very raw, airy, woody, 3D sound, i suspect it was the sum of all the parts, that's why I have second thoughts about which bridge to choose.
  4. Wailing
    Wailing Senior Member
    249
    356
    Dec 22, 2014
    I have two juniors, one with wraparound, the other with a TOM. They both sound great, however there is a 'grit' edge to the wraparound, so I go to either guitar according to the sound I want to hear. I guess that means... You need two Specials ?? BTW I have a 97 DC Special with a TOM, and that covers nearly all of the bases. Happy hunting
    endial and northernguitarguy like this.
  5. Roshy Boy
    Roshy Boy Senior Member
    1,055
    572
    Nov 7, 2012
    My 60's DC Special is a wrap around and sounds fantastic. Thinking about it, with just a tail piece for the strings to go around, it's as close to a string through body as you can get. That may help add to the tone.
    Although, what I found with mine is Pickup pole adjustment plays a huge factor in how it sounds. Tail piece height does too. I can't deck mine, but can come close. Then I raise and lowerpole pieces to taste.
    Jakatone likes this.
  6. Jakatone
    Jakatone Member
    54
    19
    Feb 14, 2012
    That grit is exactly what I'm looking for! I have enough guitars to cover all other bases.
  7. Jakatone
    Jakatone Member
    54
    19
    Feb 14, 2012
    The more research i do the more sense it makes that the P90/wraparound is the right combination for a special/jr.
    yamariv likes this.
  8. syrinx
    syrinx Senior Member
    152
    108
    Nov 26, 2015
    I prefer the sound of the wrap around- I have both styles.
  9. bossaddict
    bossaddict @david.beason on IG Premium Member
    6,477
    8,399
    Apr 4, 2013
    I would go with a wraparound bridge as well. I feel they have more of a snap to them and if you're trying to replicate the sound of the '57 as closely as possible, that seems like a good way to get that much closer.
    d1m1 and Jakatone like this.
  10. Jakatone
    Jakatone Member
    54
    19
    Feb 14, 2012
    That was my original thought also. Trying to get close to the one i played and putting a different bridge doesn't seem right.
    bossaddict likes this.
  11. d1m1
    d1m1 Senior Member
    2,357
    2,538
    Oct 30, 2012
    i would also go with wraptail. imo they sound better, have better response, have a snap, twang and honk you dont get with a tom.
  12. Wailing
    249
    356
    Dec 22, 2014
    What did you buy ???
