LP custom attempt.... My furlough project...
Discussion in 'Luthier's Corner' started by scottop1972, Jul 12, 2013.
  1. mux164
    mux164 Senior Member
    2,618
    1,869
    Sep 1, 2012
    using foam earplugs to block the holes will help prevent the need to re drill holes, i found it best to push them in from underneath
    1 person likes this.
  2. scottop1972
    scottop1972 Premium Member
    949
    412
    Jul 8, 2013
    ^ that is a great idea! i even have some of those around here.... I wish I would have though about that....
    So..... I found another 490R... this time I paid 40. But i brought my meter with me and it metered out right and the pole pieces matched....
    The pick ups metered out at 14.18 and 14.15 on the 498T's and 7.85 and 7.82 on the 490R's....
    also checked all the pots... and they all measured out from 520 to 530 range...
    found an issue with a couple of my pots.... i got 2 Gibson pots from one of the guys i bought hum buckers from locally, the sprocket part on the twist knob of the pot is shorter on the gibson than on the CTS pots... this might be an issue as the speed knobs don't seem as solid when put on the gibson pots.... I might end up going to buy 2 more CTS pots just to be sure that the knobs are all secure...
    another issue is that i did not route the inside of the cavity, i didn't think it would be an issue as i was using long shaft pots.... BUT the pots don't sit right since the top is not parallel to the cavity base.... i think i will just angle the area where the pots sit with a forstner bit to make the knobs/ pots sit right.
    then i still need 2 gold covers... both bridge spacing... this will hold me up.... as i will probably have to wait for shipping
  3. Ronsonic
    Ronsonic Senior Member
    416
    151
    Apr 30, 2010
    Hand Reamer.
    I like using a tuning fork for testing pickups - more informative than a tap test and it'll detect phase problems if you hold it between the coils of a humbucker. A pair of clip leads connected to a phone plug will let you test with an amp before install.
  4. scottop1972
    949
    412
    Jul 8, 2013
    holes deepened.... switches in good position...
    i ended up using a forstner bit on the back side of the maple cap and reamed out a bit of the back side at an angle to match the top...
    i was fearful to widen the potentiometer hole, as i was afraid it might not seat right... but i realized that having a bit of sideways play for the pot shaft was actually a good idea so i re drilled each hole and was able to make the angle. the lock washer on the bottom side of the potentiometer helped hold the angle as i tightened down the upper assembly.... now the pots and knobs are at the right angle with the top...
    after doing the first guitar, i just ended up widening the holes for the mahogany topped one.... and i seemed to be able to hit the angle easily...
    now i am waiting for the guitar store to open so i can get 2 more CTS pots so I know that all are the same.... and the knobs will fit better...
  5. scottop1972
    949
    412
    Jul 8, 2013
    all this wood work has put more scratches on the body that i will have to polish out...
    I am relic'ing the guitar without even playing it :/
  6. scottop1972
    949
    412
    Jul 8, 2013
    how the pickups measured out.... i wrote it on the back of the pup...
  7. scottop1972
    949
    412
    Jul 8, 2013
    backside of the green one.... maple cap... maple is a pain in the a**.....
  8. scottop1972
    949
    412
    Jul 8, 2013
    front side with the pot shafts at the correct angle to the top....
  9. scottop1972
    949
    412
    Jul 8, 2013
    the broken "490R" thing just started to fall apart when i tried to open it up a bit....
  10. scottop1972
    949
    412
    Jul 8, 2013
    more work later today.....
  11. scottop1972
    949
    412
    Jul 8, 2013
    AAAAAAAARRRRRRRGGGGGGHHHH!!!!!!! MY KINGDOM FOR 2 CTS POTS AND 2 GOLD PUP COVERS!!!!!!
    on hold.... more to follow...
  12. lowatter
    lowatter Senior Member
    1,214
    663
    Oct 1, 2009
    I wouldn't give up the whole kingdom for guitar parts...well maybe half a kingdom.:hmm:
    Lokking AWESOME as usual. Your skills and playing abilities are VERY inspiring...."Carry-on"
  13. scottop1972
    949
    412
    Jul 8, 2013
    ^ just frustrated as i had 4 days off and was hoping to finish the electrical work, so all i had to do was set it up.....
  14. scottop1972
    949
    412
    Jul 8, 2013
    Now the guitars are in the corner sitting and laughing at me....
    THE FINAL SPECS WILL BE AS FOLLOWS.... (will adjust later if i don't like it)
    guitar one
    LP CUSTOM CLONE REPLICA.... WHATEVER...
    solid mahogany body (african) non weight relieved
    honduran mahogany one piece neck
    AA (grading by my eyes) flamed maple cap
    multi ply binding front and back
    deep set neck tenon
    ebony board
    multi ply binding headstock with NOS plate pegasus inlay
    bone nut
    Gotoh tuners (gold)
    Gotoh bridge (gold)
    Gibson 498T bridge pickup
    Gibson 490R neck pickup
    black speed knobs
    CTS Switch
    CTS Pots 500K all around
    .22 orange drop caps
    50's wiring
    Guitar 2
    exact same except mahogany top
    and the neck is a little thinner.....
    pics coming soon when all is done....
  15. scottop1972
    949
    412
    Jul 8, 2013
    $tew mac order placed this AM.... now back to waiting.
    at least I have MLP to entertain me while I wait....
  16. scottop1972
    949
    412
    Jul 8, 2013
    got my order yesterday after work....
    pots are in, just put the speed knobs on this AM.
    Tonight..... Pickup covers and pup install....
    electronics friday.... I hope...
  17. scottop1972
    949
    412
    Jul 8, 2013
    wiring done.... i think... 50's style with orange drops.
    here are a couple of pics....
  18. scottop1972
    949
    412
    Jul 8, 2013
    will try to clean them up and take a couple of pics outside.
    next up.... set up....
  19. scottop1972
    949
    412
    Jul 8, 2013
    made it outside..... here are some pics... no bridge or truss rod cover on yet. I hope they play well.... that would really suck if they were unplayable.... I put the G logo on it because i wanted to..... i will try my hand at something different next time......
  20. scottop1972
    949
    412
    Jul 8, 2013
